Reply 960 of 1165, by PC@LIVE
- Oldbie
For today it is scheduled, a test with the Chicony iDX4-100 PC, I found a 4 cm fan 🌬, which I will connect directly to the molex of the drives, unfortunately in this type of motherboards, there is no socket for the 3 PIN FAN connector, or 2 PIN, these appeared if I'm not mistaken on the S.7, in short, a few years after the 93-94, of course anyway at a certain point, the higher CPU speed, made the PCs louder because the fan was essential for operation without any problem, but initially the systems for hooking the Heat sink, they were not the best, some could easily disengage, because in fact there were four clips, and they had to be hooked directly to the CPU, many then did not use the thermal paste.
For the test I will use a game like Duke3D, currently I have loaded the drivers of the SB Vibra16XV, in DOS everything is fine maybe I should just turn up the volume a little, but I can no longer access Windows 3.1, I will have to try to understand if there is a problem, sometimes I remember that you had to do several tests to be able to make the audio work on Windows 3.1, from this point of view the subsequent Windows work better, and indeed for this kind of sound cards, the drivers are already included, and you don't have to load any floppy.
Among the DOS driver files that I installed, there should be a configuration and test program, which could be very useful, first I should see the current configuration, and this could be useful, in case there is a conflict with something else, in that case it would explain why Windows no longer works.
I'll try the same audio drivers on the PCCHIPS M912, although I don't remember if the audio already works, and therefore in that case it wouldn't be necessary to load them, because initially I didn't connect the speaker jack, but once I'm done with the file transfers, I'm trying to make all the installed HW work better, unfortunately for some things, since it's a dated HW, in case of operating problems, you have to try another one that is definitely working, and if the result is a problem with the card (audio, video, etc...), getting the spare parts today, it would be very expensive, some cards like the video ones, can Be very difficult to find for sale.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
