Reply 1700 of 1885, by DarcTangent
PicoIDE is a day one buy for me. Can't wait to see what it offers. 😀
Reply 1701 of 1885, by polpo
fosterwj03 wrote on 2025-11-20, 01:08:
Quick question on the PicoIDE: has it been tested with an ISA-based IDE adapter, either a strand alone card or one on a sound card? I've had trouble with newer IDE optical drives on ISA adapters, and I've considered going all solid state on my retro PC's instead of fighting with older drives. Thanks.
We should probably move to this thread: Gotek like Optical Driver Emulator - Is it possible? or create a new one for PicoIDE discussion, but to answer this question, I did my initial prototyping on a basic ISA-based IDE adapter and continue to test on one as well as newer PCI and PIIX-compatible IDE/ATA controllers.
creator of PicoGUS and PicoIDE
Reply 1702 of 1885, by britelite
justin1985 wrote on 2025-11-19, 18:18:
But the same "No PicoGUS Detected" message every time. I'm pretty confident I've ruled out soldering issues, or damage from the extensive fiddling with the first board.
One thing that crosses my mind is that a few of the small ICs (U4, U5) were off-brand copies rather than the specified TI parts because of stock at the time of ordering. Could this make a difference? The pin-out of the TI part (https://www.lcsc.com/datasheet/C7803.pdf) and the off-brand one (https://doc.chipmall.com/datasheet/rev_250308 … d_c63245304.pdf) seem to be identical.
Might the Cyrix MediaGX chipset just be incompatible? I've tried two boards but both have the same chipset. I've noticed comments further up this thread about the Vortex86 and some other oddball chipsets being incompatible. Has anyone tested the PicoGUS with a MediaGX desktop board?
I also had problems with a previous pc/104 edition of the PicoGUS in that it wouldn't get recognized for some reason unless I had Rasteris Crystal-based pc/104 soundcard connected at the same time on a Vortex86 based board. The PicoGUS in question only had the 8bit portion of the pc/104 connector connected, so might have been a completely different issue from what you're having.
As I mentioned earlier I would be happy to test out a card, but I'm unfortunately unable to send or reply to PM's because of my low post count on the forum.
Reply 1703 of 1885, by fosterwj03
polpo wrote on 2025-11-20, 04:53:
Awesome! Thanks. I look forward to seeing the device in a marketplace.
Reply 1704 of 1885, by justin1985
LSS10999 wrote on 2025-11-20, 02:03:
PicoGUS uses ports 1D0-1D2 for configuration. Can you check if these addresses are accessible on the PC/104 bus?
I haven't seen a real MediaGX myself so I'm not sure, but I recall reading that MediaGX has something called VSA which the CPU traps certain I/O ports to emulate certain functionalities. It is possible that VSA might have captured the I/O cycles meant for PicoGUS...
Thanks for this - I've done a bit of checking, although I'm not too confident reading hex numbers ... according to the motherboard manual (Advantech PCM-5824), the only 1xx IO addresses that are documented are:
170- 178 2nd fixed disk for CompactFlash
1F0-1F8 1st fixed disk
I also found the MediaGX datasheet, and it mentions "The I/O locations 22h and 23h are used for MediaGX processor configuration register access." - that might be what you had in mind? But i doesn't seem to help here 🙁
Is there an easy way to check in practice whether a given IO range is in use?
Reply 1705 of 1885, by myne
Just curious, has anyone made the code for the pico to connect directly to the lpc bus?
I built:
Reply 1706 of 1885, by LSS10999
myne wrote on 2025-11-24, 00:33:
I'm not sure... I did search around GitHub about using RP2040 to directly interact with the LPC bus before, so far only two notable results.
https://github.com/Team-Resurgent/modxo
https://github.com/MrGreensWorkshop/RasPiPico … sPostCodeReader
They only used very basic LPC functionality, covering just LAD0-3, LCLK and LFRAME, from what I can see.
For other LPC functionalities, particularly SERIRQ and LDRQ#, perhaps one has to refer to nukeykt's LPC Sound Blaster and figure out how to do this on RP2040/RP2350. Not sure if control pins like LRESET# and LPCPD# are absolutely needed.
PicoGUS may be able to take advantage of LPC's serialized IRQ and DMA. This means no more IRQ/DMA jumpers, and can claim more than one IRQ/DMA to allow multiple functionalities to be active at the same time. High DMA can also be used for enabling full SB16 functionality, if possible.
DMA is usually not an issue as long as it's properly initialized, but IRQ can be too contested on modern chipsets. LPC can use IRQs 2-9 provided no PIRQ line is occupying them. On Intel chipsets, this can be checked through registers 60h and 68h of the ISA bridge (00:1f.0).
Reply 1707 of 1885, by myne
Cool.
Seems like there are more advantages than disadvantages.
* potentially more performance because monitoring fewer pins.
* potentially more functionality
* potentially more people interested - since it may only require a tiny bit of soldering and a handful of bus wires instead of a whole uh... daughterboard.
Sounds like something someone will see as worthwhile at some point.
I built:
Reply 1708 of 1885, by theelf
Hi, i try to have cdrom on windows 95, i follow instructions here
https://github.com/polpo/picogus/wiki/CD%E2%8 … 90ROM-Emulation
But i always get the hardware in error, even in port 250 no conflicts. The picogus is in mode USB, cdrom port at 250, and in DOS work perfect
The attachment mke.png is no longer available
Any ideas guys? thanks
Reply 1709 of 1885, by NeoG_
theelf wrote on 2025-12-11, 01:19:
Are you loading CDMKE.SYS and MSCDEX in config.sys and autoexec.bat before windows loads? If yes port 250 will be in use by CDMKE.SYS and the windows driver will be unable to use it. You can use one or the other method but not both at the same time.
From my testing, using CDMKE.SYS and MSCDEX before windows loads was faster for accessing optical media via the PicoGUS than using the windows driver.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 1710 of 1885, by theelf
NeoG_ wrote on 2025-12-11, 01:24:
Hi, no DOS drivers load, only try windows
In DOS work fine, i use usb mode and CDrom read fine, like 4x or similar, if windows driver is not very good, i will use dos compatibility mode then
Reply 1711 of 1885, by theelf
Sorry double post, finally solve the problem, update to new firmware 3.2.1 and everything work fine
With firmware 3.2.0 in DOS was working good, but not win95. Updated and solve problem!
Reply 1712 of 1885, by Calolo
Is there a going to be a PicoGUS 3.0 updated with RP2350 + SD card ? Thanks
DOS/98SE : PIII-S 1400/C3 1200, GA-6BXC 2.0, 256MB PC133 C2, GeForce 2 Ultra, Voodoo2 12MB, Audigy1 Platinum Ex, ESS1688, SSD 128GB
XP/7 : i5 3750k, 8GB DDR3 1600, GTX 280 1GB, Radeon X1950 XTX, SSD 512GB
Reply 1713 of 1885, by Kekkula
Hi.
Can anyone confirm if the tandy mode is workin on xt machines in port c0 on latest firmware and 1.x card?
I can't get it working on my pc10-III machine, I'm using patched files from tandy project.
Edit: for future me strugling with this again in a few months time.
You have to run commands separately.
First.
Pgusinit /mode tandy
Then again
Pgusinit /tandyport c0
Reply 1714 of 1885, by eliot_new
Hello, I want to thank once again User Polpo and also the producer of PicoGUS. I have now 2 of them: 1 in my AMD K6-3/400 and 1 in my P3-450 system, both along with an AWE64 value.
Here I have read that in the future the PicoGUS might emulate a true Panasonic 2x speed CDROM drive.
I m curious and would like to ask you all here:
Does anybody still have an old Panasonic, Sony, Mitsumi 2x CDROM drive with a proprietary interface, i.e. non_IDE non_ATAPI?
Back in the days when I was very young once I bought a Panasonic and wanted to connect it to the sound card.
Unfortunately it didn't function and I had to sell it and to buy a Mitsumi ATAPI 4x.
Since then I have an unfullfilled "dream" or better said desire: one day get a Panasonic or Creative 2x speed.
AFAIR you could pair it with a special ISA 3DO card and play directly 3DO games?
DOS:K6-3/400,192MB,P5A,Rendition v2200 AGP,Trio64 PCI,3dfx V1,AWE64,ESS1938,PicoGUS,32GB
w98SE:P3/450,768MB,QDI440BX,V3AGP,AWE64,PicoGUS,80GB
wXP:P3/1G,512MB,CUSL2-C,MSIFX5600,Audigy1,80GB
Reply 1715 of 1885, by SScorpio
eliot_new wrote on 2026-01-30, 17:36:
Hello, I want to thank once again User Polpo and also the producer of PicoGUS. I have now 2 of them: 1 in my AMD K6-3/400 and 1 […]
The emulation is already in the latest firmware. In SoundBlaster mode it is 2x, in USB mode it's between 3-4x.
You use the Panasonic DOS and Windows drivers to access it.
Reply 1716 of 1885, by Valet2
Thinking about getting a PicoGUS. Could anyone confirm it works with System Shock 1? It has its own Ultrasound patch.
--- Old Habits Never Die ---
Reply 1717 of 1885, by NeoG_
Valet2 wrote on 2026-03-03, 10:22:
I tried to get it running but unfortunately I'm using the CD-ROM emulation on the PicoGUS in DOS and the CD edition requires the CD be present to run the game. Currently GUS mode and CD-ROM are mutually exclusive so I wasn't able to run the game with the GUS driver installed.
Maybe someone that has a PicoGUS and a physical disc can try it.
Reply 1718 of 1885, by Valet2
NeoG_ wrote on 2026-03-03, 12:48:
No need to — just copy the CDROM and INST folders to the game folder, and edit both CYB.CFG and CDSHOCK.BAT to change the CD path accordingly:
cd_data_dir_path E:\cdrom\data
to:
cd_data_dir_path .\cdrom\data
and from:
E:\cdrom\cdshock.exe
to:
cdrom\cdshock.exe
Reply 1719 of 1885, by NeoG_
I copied everything to hard drive so I could run the game without a CD and use the PicoGUS in GUS mode. I used the method of replacing SB16.DIG and MPU401.MDI from an ultrasound driver package and replacing them in the sound folder.
GUS FX + GUS Music = Audio stuttering, random lockups and game crashes
SB16 FX + GUS Music = Occasional stutter and also locked up changing resolution but more stable than GUS FX+Music
GUS FX + MPU401 Music = Stable
SB16 FX + MPU401 Music = Stable
I checked if the behaviour was CPU speed dependent but it wasn't, same at different system speeds
Also need to check if the behaviour is the same in dosbox to rule out audio driver issues
I will probably stick with GUS FX + MPU401 Music regardless as I think it sounds better than SB16 FX
