NeoG_ wrote on 2025-12-17, 21:27:
My understanding is that as long as you call SBESET before the card is initialised with SBEINIT, it should follow the updated settings
If it’s called after SBEINIT the settings won’t apply until the card is reset by rebooting the machine
Just tried it and the same thing happens.
The attachment IMG_5175.JPG is no longer available
Whether it comes first or it's run with/without SBEINIT, it'll say the PC needs to restart for changes to take affect and it'll still initialise the SB anyway if it isn't commented out.
The EK1M and MPXPlayer still initialise without issue even if both sound cards are configured though. Though, how exactly can you tell if things are working correctly? That you can juggle between them?
When I tested the DOS version of Simon the Sorcerer it still wasn't playing any MT-32 music via the SB16. The setup wizard doesn't seem to allow me to change any audio device properties either. The only option it gives me is the DMA for the Sound Blaster. With Doom, despite the Yamaha being initialised on boot, and in the game's custom BAT file, the music is... 'tinny'. Really poor. Not the usual GM you get from the sound canvas. So the SB was still taking priority.
I also added 'mix' at the end of '-as' but it gave me an unauthorised error. This is what my EK1M.ini looks like:
; ekm config, ver. 106
-boot
; mix matrix
; input afront dfront rear acenter dcenter spdif2
-io ac97 0 0 0 0 0 0
-io spdif0 68 68 68 68 68 68
-io spdif1 68 68 68 68 68 68
-io spdif2 68 68 68 68 68 68
-io i2s0 68 68 68 68 68 68
-io i2s1 68 68 68 68 68 68
-io i2s2 68 68 68 68 68 68
-io wave 0 0 0 0 0 0
-io synth 0 0 0 0 0 0
; output levels
; afront dfront rear acenter dcenter spdif2
-o 100 100 100 100 100 100
; ac97
-as line
-ai line 50
aux 0
cd 50
tad 0
mic 0
beep 0
Also, I might have misunderstood regarding the 2-pin digital audio. I don't think I have or use digital audio, but analog...? Via the S/PDIF from the sound card to the CD-ROM.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
HDD: C, D - IDE 1, CD-ROM - IDE 2, E - IDE 3
