zyzzle wrote on 2025-12-22, 22:24:I absolutely agree. This recent tripling of prices will only hurt things. Total system RAM will remain stagnant or even decrease […]
Hoping wrote on 2025-12-22, 12:42:
I'm not surprised either, as the amount of RAM has been stagnant for years. Back in 2010, I installed 16GB of DDR3 for the Phenom II 1100T because it was cheap. Nowadays, 64 GB is considered a lot, but in my opinion, that's ridiculous. 64 GB should be considered the minimum today, 128 GB should be acceptable, 256 GB should be standard, and 512 GB should be for enthusiasts. The same goes for consumer SSDs, which have been pretty much stagnant at a maximum of 4 TB in general.
In these respects, hardware has been very stagnant. It is normal for such a strong software advance as AI to suffer from this stagnation. And to show a great imbalance.
I absolutely agree. This recent tripling of prices will only hurt things. Total system RAM will remain stagnant or even decrease due to this current faddish egregious cost. We should be seeing 128GB standard systems by now- as a minimum. Back in 2010, 16 gb of DDR3 was only about $50, 32gb was considered enthusiast and you could get that for a little over $100. I couldn't even speculate how much 512 GB of DDR5 RAM would cost now. Thousands?! Which motherboard will actually accept that much RAM? None?
It's this stagnation which doesn't bode well for the industry. CPUs have also stagnated, especially at Intel. Not much increase in literally 15 years. My i7 2600k still rocks very well today at 5 Ghz. Building systems is no longer cheap. With SSDs more than doubling, RAM tripling or quadrupling, and components also greatly increased, it's a cryptically expensive endeavor. The days of the $200 basic system are over. One could almost argue that AI (coporate greed) and gaming is hurting the hobbyist industry more than helping it. Is there even a hobbyist industry any longer? It's a sad state of affairs.
During the last 50 years, the trend has been toward commodization, and prices kept falling and falling for similar amounts of power in computer systems. Now, it's toward profit and rapaciousness at all costs. There is no Moore's Law any longer. Prices will just keep rising. Stagnation is very, very bad, but that'll be the trend.
I agree with most of this, but I think CPUs have improved nicely in the past 15 years since Sandy Bridge (thanks mostly to Ryzen) unless you are stuck using a 60Hz display. Considering most non-gaming tasks (as well as a lot of less intensive games) are still fine on systems that old, we just don't "need" the advancements in CPU power that we needed 25 years ago. BUT... if you are using a 120Hz or higher display and want to keep your frame rates up there, a 15 year old CPU is going to struggle compared to something newer.
I used a 2500K overclocked to 4.2Ghz for 8 years before getting my current X570 board and a Ryzen 5 3600 in 2019. The difference in a lot of situations was huge. Then going to a 5800X3D a few years later was also a large improvement in situations where the CPU was actually the bottleneck. The overclocked 2500K is still perfectly usable for day to day stuff and would probably game decently if I was just using a 60Hz screen, but there are situations that I'm sure would be quite excruciating... like trying to play a physics sandbox game like Teardown, or even something like Minecraft with some of the latest view distance mods. It takes quite a bit of processing power to keep those kinds of situations in the 120-200fps range. I don't really play AAA games, so I can't say how the latest ones handle old CPUs.
Also, memory performance has changed considerably since then too. With huge caches and significantly higher bandwidth, it can help quite a bit at times.
Overall though, things have stagnated quite a bit, yes. I think we can blame that on the fact that nearly everything the average non-gamer needs to accomplish on a computer could be done plenty fast enough on a Windows XP computer with an SSD, a couple gigs of RAM and a Core 2 Duo... if not for outdated security updates and web browser support. That has taken a lot of the urgency out of advancing the speed of general computing.
The GPU stagnation is the worst though. There is absolutely NO REASON that a 3060 Ti should trade blows with a 4060 Ti. The fact that the 4060 Ti 16GB also launched with a ~$430 MSRP is just... disgusting. At least 5000 series brought some slight improvements but the prices are still so bad it makes no sense to buy one unless you really need it for something or you currently have a (lower end) GPU that is from the RTX 2000 series or older.
