First post, by BEEN_Nath_58
Choosing a Linux distro has been difficult for me, specifically shifting from Linux Mint for a change. I moved to Debian 13, only to see that many apps I use don't have the packages installed and I get to a loop to install them.
Obviously I imagine everyone would like to save their time choosing one that's tailored for their purpose.
I am looking for one that's sufficient for a personal user. Cherry on top, stable and a lot of available packages. Also how would I choose a fork of the major OS?
Reply 1 of 13, by The Serpent Rider
CachyOS, Mint LDME, Nobara, Bazzite. Based on Arch, Debian, Fedora, Fedora. If you want stable, just scratch Arch from that list.
Reply 2 of 13, by BEEN_Nath_58
The Serpent Rider wrote on Yesterday, 21:16:
Why has Bazzite seen a higher "promotion" lately compared to, say, elementaryOS or Gentoo or even CentOS Stream
Reply 3 of 13, by Joseph_Joestar
BEEN_Nath_58 wrote on Yesterday, 21:30:
It's a gaming focused distro.
For people who want to play games without too much hassle, Bazzite is the one to go for.
Reply 4 of 13, by Matth79
Until a realistic general release of SteamOS, Bazzite is probably the best way to get Steam (and some other launchers, Lutris etc) up and running with minimal fuss.
Reply 5 of 13, by jheronimus
Honestly, Flatpak mostly solves this problem. So I just use Debian + flatpak
I was in a similar boat, and I'd say the biggest selection of software would be ArchLinux's AUR. The downside is that while ArchLinux itself has been pretty solid in my experience, AUR packages do break routinely after updates.
MR BIOS catalog
Unicore catalog
Reply 6 of 13, by lti
I haven't used Bazzite, but a lot of the modern PC community is focused on gaming (to the point of being obnoxious). I haven't heard anyone talk about Gentoo in a long time, and I thought CentOS was more of a commercial server-focused distro.
I think there are two definitions of stability. There's the Debian "use old versions of packages with security patches only" definition, and there's the "doesn't crash" definition. At this point, I'm not too sure that desktop Linux is "doesn't crash" stable anymore, but it was in the past.
The Arch AUR and Ubuntu PPAs are probably the largest collections of weird third-party stuff (including drivers - for example, Hauppauge releases their drivers as PPAs, and then they get unofficially ported to the AUR). If you don't need third-party drivers like that, Flatpak and AppImages are good for software and not distro-specific.
Reply 7 of 13, by lawyerpepper
PopOS gets high marks from users, especially the new Cosmic desktop. Personally, I’m fine with Debian, but I’ve been using Linux on and off since the 90s.
Reply 8 of 13, by BEEN_Nath_58
Yeah PopOS, that's another that rings the gaming name.
Another one I hear a lot is Zorin OS for the fact it looks a lot like Win, but I don't know it's other aspects
Reply 9 of 13, by wierd_w
I use xubuntu on my big pc, but use bazzite on my gpdwin4.
Bazzite's immutable FS is a pita, imo. I only use it on my win4 because steamos isnt an option. I have to run a script to reconfigure zram swap, because the maintainer does not reference a user writable conf for that. (Grumble)
Reply 10 of 13, by Robin4
Iam using Cachyos my self on my living room computer.
Tried Bazzite, but was to closed to me with using the terminal. Maybe great for gaming only. Not for gaming + desktop use.
Reply 11 of 13, by BitWrangler
For pre-2010 machines, look at "Puppy".
Reply 12 of 13, by DracoNihil
I've been using Void Linux for the past 6 years now without a problem. It's a rolling release distro with it's own package manager and uses "runit" for the init process.
They have a policy of only packaging stable, non breaking (as in try to avoid ABI incompatibility and SONAME bumps) releases though if a major library has a breaking change then all packages depending on it are updated and in case of breakage, patches written to resolve the break if possible.
The base system install is very barebones like Arch, so if you're used to that kind of initial setup hurdle there's nothing really wrong with the distro. The package system is described here and is comparable to BSD "ports system".
I actually run my system with several locally custom built packages without problems. Manual intervention obviously needed in the event of SONAME changes but nothing impossible to fix.
― Κυνικός Δράκων
Reply 13 of 13, by BEEN_Nath_58
I guess I should step on the Arch train this time
