What hasn’t been done?
Reply 200 of 238, by Jo22
BitWrangler wrote on 2026-01-18, 15:53:
I just thought of something that would be interesting... […]
Voodoo2 on an FPGA on a mini PCI card for late 90s early 00s laptops. Though either internally cobbling to VESA pins or whatever you'd need to do to get it on the LCD might be a pain. Otherwise I guess it's awkward ribbon cable to VGA out for monitor only.
If it did it over PCI completely like a PowerVR or MPEG card that would be easier. Power VR cards aren't super complex, wonder what the chip situation is like, hmmm.
edit: NEC chips might be "around" ... can't read Japanese tho ... https://datasheet.datasheetarchive.com/origin … SASW0064371.pdf
Sounds reasonable!
There once was at least one V2 for iMac Mezzanine slot, too, so a compact size per se seems doable.
http://www.users.totalise.co.uk/~robert.thoms … n/indexold.html
The PowerVR for Mini PCIe would be interesting, too.
I remember that their had been h.264 decoders for netbooks once.
Were based on a Broadcom chip, I think. Habey HB-VD920 etc.
Reply 201 of 238, by MikeSG
It's a good idea, but many laptops from the late 90's & early 00's have good 3D cards already.
Reply 202 of 238, by BitWrangler
I would dispute the good 3D and that there are still many, there's dozens and dozens with chipset graphics, rage mobilities and S3 stuff, for every one that had Geforce or Radeon, until a few years into the noughts. 2003 or so the proportion with better graphics rose somewhat. Having been a laptop shopper in that timeframe when they were new, it was hard to find one with decent graphics then, sure, the magazines reviewed them, finding them for sale was another matter. I never ordered direct from Alienware or anything like that though, so I wasn't looking at $3000+ machines. Then there was the "forgot how to make hinges" "bad caps" "lead free solder" agents of slaughter which took these things out at a massively high rate. So apart from getting real lucky or spending a fortune on eBay after searching for months, you're not likely to get your hands on one now.
Dos capable sound went away just as the higher proportion of late retro compatible graphics kicked in, or the Turion/Sempron models that survived solder problems would be nice with X200/X300 onboard, which are basically Radeon 9600s. By then, screens were wide too.
Anyway, repro Voodoos are selling for desktops that could have any other card plugged into them, so I don't think the existence of other options is a factor. PowerVR doesn't have quite so much of a following though, but seems way easier to do. It's more of a tinker/novelty option rather than the be all and end all of late 90s 3D.
Reply 203 of 238, by MikeSG
PowerVR certainly looks compact enough
Reply 205 of 238, by RetroPCCupboard
BitWrangler wrote on 2026-01-19, 15:23:
My first gaming laptop was from early 2006. It was based on a Clevo M570A chassis. I believe it had an nVidia Geforce Go 7800 GTX and Pentium M CPU. It played all the latest games at high settings.
The attachment m570a.jpg is no longer available
I dont recall their being any worthwhile gaming laptops much before that. But maybe I am wrong.
I have a Dell D600 from around 2003 with Radeon Mobility 9000. It struggles with games from 2001 onwards really.
Reply 206 of 238, by bracecomputerlab
While the datasheet is in Japanese, the pin out and supported memory configuration pages are really in English (obviously), so at least that clears obstacle to designing the PCB.
That being said, is there still NOS inventory of the NEC made PowerVR somewhere in the world?
I assume the demand for this chip dried up by 1999, and remember Matrox fire selling their m3D card with this chip over at CompUSA back then ($30 after a mail-in rebate type of a deal).
On an unrelated topic, I have purchased several NOS copies of S3 Savage4 Pro recently.
I will eventually like to manufacture PCI and AGP version graphics cards eventually.
It is definitely a better chip than ATI Rage XL.
Reply 207 of 238, by BitWrangler
bracecomputerlab wrote on 2026-01-22, 08:17:
With a superficial search I found a couple of places with 4 figure inventory numbers, but I have not reached out to confirm. It would be easier if some turned up on eBay or somewhere, to get a few to mess with. Yeah I saw the pin labelling but assumed there might be some important notes in the text. Though I am not super sure that's a "real" datasheet, since there is not enough packaging and timing info on it.
Right, 1999 or so they were super cheap on a card, I got an Apocalypse 3Dx for $12 from Compgeeks back then, kinda wish I had grabbed a dozen now.
Anyway, still gotta confirm the chip would fit in MiniPCI card dimensions... and it would be a fat boy with PVR on one side, DRAM and crystal on the back and whatever most essential discretes crammed in.
Next guess, 32 bit PCCard for type III slot only maybe.
On an unrelated topic, I have purchased several NOS copies of S3 Savage4 Pro recently. I will eventually like to manufacture PCI […]
Those would be cool, I'm a couple dozen projects away from needing a second Savage though.
Reply 208 of 238, by bracecomputerlab
It does not appear that the very short Japanese language datasheet (14 or so pages) contains anything other than its chip pin out and general memory configuration.
Since this version of NEC PowerVR does not contain a VGA graphics core, one does not need a VGA BIOS ROM.
This makes the ROM copyright issue a non-issue for a "gonzo" retro graphics card.
I guess the chip used in VideoLogic Neon 250 is not really available (they probably weren't produced in numbers), and this one requires far more of design support to make a graphics card.
S3 Savage4 happened to have excellent hardware and register programming documentation on the Internet, and the only missing is a customer reference schematic.
This is why I decided to purchase several of them recently.
BitWrangler wrote on 2026-01-22, 15:00:
With a superficial search I found a couple of places with 4 figure inventory numbers, but I have not reached out to confirm. It […]
Reply 209 of 238, by BitWrangler
Gotta dump this idea out of my head so I can get on with the bajillion projects I already have...
The pico-286 project puts early ATish emulated hardware in a relatively miniscule package. That's fact one. Fact two is that Sega Game gear had a plug in TV cartridge with tuner, to watch TV on the Game Gear. However, there was a later variance in production that disabled this functionality, so only earlier Game Gears can do TV input off a composite pin on the cart slot.
So proposal to make DOS-Gear or 286-Gear or something cartridge that uses composite in for CGA or downsampled VGA graphics. Thus enabling a simple DOS machine, probably need your bootable media to have a menu system, externally configured, that lets you play some DOS games on the Game Gear.
However, this is a bit of a solved problem vis a vis the handheld console DOS actualisation, because you can do it merely as a software solution in one of two ways. The first is to hack a leapfrog handheld, and use linux emulators, it's only a 600mhz or so ARM so don't expect too much speed. The second is that rash of emulator handhelds that was around 5 years ago, those should also be able to run linux emulators... though I never found one to get into it much myself.
Thus it is a bit of a toy for those who might already have a Game Gear.
Reply 210 of 238, by BinaryDemon
I always thought it would be cool if some early 3D card had hidden SLI support and just no one thought to test it.
Reply 211 of 238, by Tiido
BitWrangler wrote on 2026-04-12, 21:11:
The TV tuner actually takes control of the LCD and drives it with native data format of the LCD, leaving all scaling etc. to the task of the chips in the tuner... But you can definitely hook up a CGA or EGA card to the tuner and enjoy extremely blurry video, and not just in the sense of motion blur. Text will be unreadable since the LCD has only 160 x 144 pixel resolution. There's not much one can do to get readable text except perhaps with some sort of custom solution that does the same LCD drive as the tuner does and utilizes some sort of adaptive font downscale that can recognize a 8x8 character and redraw it as 4x5 or something similar, while not getting in the way of regular graphics too much...
It would be a very interesting challenge for sure 🤣
Reply 212 of 238, by MikeSG
Discovered the other day that the Matrox Millennium first generation (IS-STORM / IS-MGA-2064W) is ISA compatible but no ISA cards appeared to have been made.
The IS-STORM / IS-MGA-2064W is a refresh of the IS-ATHENA. It does 2D GUI, 3D (hardware gouraud shading, software texturing), Video for Windows acceleration. APIs: OpenGL, Direct3D, Renderware, others.
It is essentially identical in function to the previous IS-ATHENA cards, but is 208 pin instead of 240, and uses WRAM. WRAM is identical to VRAM except uses larger bit blocking windows. The IS-MGA-2064W R3 operates at 60MHz instead of the first gens' 50Mhz. Supports 2/4/8MB WRAM.
I did some work on the chances of making a successful ISA card and I think it's worth it if you have already made an IS-ATHENA...
-The datasheet on the IS-STORM / IS-MGA-2064W has no pinout, and requires work.
-IS-ATHENA datasheet does contain information on hardware straps (required to select PCI/ISA mode), pinout, PCI/ISA pin differences. Identical pins on both likely do the same thing.
-IS-ATHENA ISA card has the ISA-specific buffers/latches on known pins.
-BIOS on the IS-STORM is now on the WRAM memory bus, and would likely work the same in either PCI/ISA mode.
-Windows drivers for the IS-STORM probably use the wrong IRQs, but not impossible to change.
Reply 213 of 238, by Jo22
Hi, some more ideas that comes to my mind.
a) a parallel port mouse adapter and a matching MS Mouse compatible driver, because COM ports are rare (just two, COM1 for mouse, COM2 for modem).
That way, users could have both COM ports available for more important things.
Say, an null-modem connection and a modem at same time.
b) A Win64 compatibility layer for Windows 98/SE. Maybe built out of VXDs.
Some sort of Win64s, basically. An analogous to Windows 3.1x which had Win32s.
It would use an AMD64 CPU emulator, maybe with an dynamic recompiler, to avoid issues with x64 long mode (Windows 9x heavily uses V86).
As a side effect, it would be able to run latest Win64 utilities such as Irfanview or Winamp on an 486 or Pentium era Windows 98 PC.
As a role model WINEVDM/OTVDM could perhaps be used. It implements Win16 and has an 386 CPU core.
It's of course made for NT and not 9x, but concepts can be re-used, maybe.
Reply 214 of 238, by BitWrangler
Not sure what modern winamp on 64bit emulation on a 486 would get you apart from a fart noise every few minutes and several days to finish when you fed it a 3 minute mp3.
Reply 215 of 238, by Jo22
Hi, these were just examples.. Winamp had (has) Plug-Ins for all sort of formats. Including MOD, SID, SPC etc.
Many users/fans of Windows 9x do likely have a modern PC with a few GHz, anyway.
Getting that to work might be more of an exciting challenge or experiment, thus.
It would also bring Windows 9x from the past to the present.
Just like how the Win32s add-on moved Windows 3.1x into 32-Bit era of Windows applications (-though Win31+Win32s was an early testbed to Win32 development, too-).
Many applications are Win64-only by now, after all. Even text editors.
Being able to run them on Windows 9x does build a bridge between generations (-both, technologies and users-).
It's not that different to Voodoo wrappers, maybe, which provide software compatibility.
Just other way round. :)
Edit: My wording is likely not very good, so I'll try to put it this way:
Windows 98SE already is very feature-complete in terms of good old Win32.
And .NET framework is available, as well. So are GDI+ and Unicode wtappers.
There's even KernelEx project to extend compatibility even further.
However, many Windows EXE files are Win64 PE files by now.
By using an Win32<>Win64 wrapper with an AMD64 CPU emulator,
Win64 API calls can be redirected to the corresponding Win32 calls.
It doesn't have to be slow with applicatons that mainly call Windows API.
File converters, picture viewers and so on are not that CPU heavy.
Edit: I forgot to mention, to my knowledge, the Win64 API and Win32 API are same for about 99٪.
The main difference between them is the lenght of pointers, basically.
I mean sure, the Win64 PE EXE files may include advanced instructions such as SSE because they're part of AMD64 architecture.
So compilers may do include them by default, even if they're not really necessary.
But luckily, Windows 98SE already supports some of the SIMDs.
So an AMD64 CPU emulator might process them using the real SIMDs of the x86 CPU.
Sure, that would prevent 486 and Pentium PCs from running Win64 EXE files that use them.
But the problem could be solved on OS level, maybe, by installing an SSE emulator.
Such things did exist in the early days of Mac OS X 10.4 (intel), for example.
They made OS X run on PCs without these SIMDs.
Another parallel situation here: The RISC versions of Windows NT 4 had third-party CPU emulators.
They allowed normal i386 Win32 applications to run on Alpha and Power PC systems. FX!32 is most popular, maybe.
Sure, Windows 98 is not as sophisticated as Windows NT - but it is very hack-able via VXDs. :)
And it has a partial NT compatibility via ntkern.vxd, for WDM support etc.
PS: This is just an idea, of course. I don't have the know-how to implement this.
So no worries, Windows 98SE will remain safe. ;)
Reply 216 of 238, by Jo22
What also comes to mind..
a) an co-processor board for handling SSL2/HTTPS encryption.
It might be an ISA card with a Raspbery Pico, ESP32 or something. Like PicoGUS or PicoMem.
If the i/o is well documented, it might be useful for Arachne, Dillo or MicroWeb to use.
The source code to these DOS browsers seems available.
I mean, there are MP3 player cards for various platforms already. So it's not that far fetched.
They do the heavy lifting that the vintage computer (Amiga, C64 etc) can't do.
Another option would be to simply build an hardware-based HTTPS/HTTP proxy that can be installed between the network card of a vintage PC and the home router.
Wouldn't be as cool, though, I'm afraid.
b) an ISA co-processor card with an Motorola 68000 and/or Z80 (or clones). Or maybe 6502, too.
It would allow porting other OSes to IBM PC platform, basically.
Such as SymbOS (Z80) or AmigaOS or TOS (68k). Or C64 Kernel/BASIC (6502).
I got that idea, because the manual of AT-Speed PC emulator on Atari ST mentioned that it might be cool if DOS software (games, BGI drivers) would add support for the Atari ST's native graphics hardware ("Important information about AT-SPEED").
The logic behind this was that AT-Speed was 80286 based and could see the entire address space of the Atari ST.
Both 80286 and 68000/68010 were 16/24-Bit CPUs (16-Bit wide data bus, 24-Bit wide address bus.
So with enough AT-Speed users being out there, it would become another major DOS platform.
Edit: Sorry for another post after the previous. but I thought it belongs in its own post.
Reply 217 of 238, by rmay635703
Tiido wrote on 2026-04-13, 06:36:
The gg just like GBC actually has a sub pixel resolution of 480x144
If your willing to throw away color control you could render rainbow text but you can’t get back the 56 vertical rows that are missing
GBA has subpixel demos showing them used as independent entities, idea would be the same.
Reply 218 of 238, by Tiido
That is something I didn't consider trying to take advantage of at all, this will definitely help with text a lot.
Reply 219 of 238, by rmay635703
Tiido wrote on 2026-07-24, 13:22:
Yeah, np,
most folks don’t realize sub pixels can occasionally be useful .
Let’s face it we played on worse screens in the 90’s.
These days it’s wonderful to have more options than we would have had back in the day and it’s wonderful every time someone finds a new use or technique with old equipment.
The hard work the community puts in is always appreciated even when it’s not immediately obvious.
