Pocket 8086 Boot Error
First post, by RetroPCCupboard
Hi. I was using my Pocket 8086 with the edit program, I then exited the program and was greeted with an error saying it couldn't load command.com (or something like that). So I rebooted, and now it does the RAM test and stops like this:
The attachment 20260124_083344.jpg is no longer available
I am pretty sure that it used to count up to 640kb. Does this error mean that some of the memory has gone a bad?
Not sure if it makes a difference but this machine has an AMD 8088 running at 4.77Mhz rather than the V30 at 10Mhz that it came with.
Reply 1 of 26, by EduBat
I don't have this machine and I don't know what that error code means but the most likely explanation is, indeed, faulty RAM.
Reply 2 of 26, by RetroPCCupboard
EduBat wrote on 2026-01-25, 01:03:
Oh. I guess that's not going to be repairable then. Should I take it apart and see if I can find the ram chip? If it is a BGA chip then I think I am out of luck. I can only solder at an amateur level.
Reply 3 of 26, by rasva
According to schematic, there are two 628512 RAM chips marked as U9 and U10. For sure not BGA. I would start with reseating of CPU and any other chip placed in a socket....
Reply 4 of 26, by Peter Swinkels
For what it is worth, I have seen desktop pcs suddenly failing to detect the proper amount of ram and the like due to a worn out power supply.
My GitHub:
https://github.com/peterswinkels
Reply 5 of 26, by RetroPCCupboard
rasva wrote on 2026-01-26, 11:27:
Ok. Thanks. I shall try that first! I could try swapping the CPU, as I have spares. But CPUs don't usually just die.
Reply 6 of 26, by RetroPCCupboard
Peter Swinkels wrote on 2026-01-26, 11:58:
It's a 12v plug. I could measure it to see if voltage is wrong, but I get same behavior with RAM when running the laptop on batteries.
Reply 7 of 26, by RetroPCCupboard
Ok. So I took it apart. To my untrained eye it looks like a beautifully designed machine.
Anyhow, I replaced the 8088 with an NEC V30 and I get an error even sooner in the RAM check (obviously this is 16 bit bus rather than 8 bit):
The attachment 20260127_064128.jpg is no longer available
Here are some photos of the motherboard. I can't see any bad solder joints. Most looks very neat:
The attachment 20260127_064857.jpg is no longer available
The attachment 20260127_065241.jpg is no longer available
The attachment 20260127_064913.jpg is no longer available
The attachment 20260127_065054.jpg is no longer available
Reply 8 of 26, by RetroPCCupboard
Here's some more photos
The attachment 20260127_065059.jpg is no longer available
The attachment 20260127_065106.jpg is no longer available
The attachment 20260127_065132.jpg is no longer available
The only bit that looks a bit suspect to me, is this chip that's covered in what I assume is flux:
The attachment 20260127_065146.jpg is no longer available
The attachment 20260127_070821.jpg is no longer available
Reply 9 of 26, by RetroPCCupboard
I couldn't find my bios chip remover to take out the two square chips. The small chip that's socketted near the CPU is really tightly in. I couldn't get my pry tool between it and the socket to remove it
Reply 10 of 26, by roytam1
maybe there is something under VGA board (daughter board in blue)?
Reply 11 of 26, by RetroPCCupboard
roytam1 wrote on 2026-01-27, 08:54:
This is what's under the VGA module. Looks ok I think?
The attachment 20260127_221206.jpg is no longer available
Reply 13 of 26, by CharlieFoxtrot
RetroPCCupboard wrote on 2026-01-27, 22:17:
That's the RAM as previous poster said. What I would do to diagnose the chips is to test if either of them gets unusually or at least warmer than the other, which indicates a short in the chip. Power it on and touch them with your finger and feel if one of the chips is getting hot. Thermal imager is even better if you have access to one.
Of course chips can fail without them getting hot, but to diagnose such fault you need a probe at minimum or preferably oscilloscope to see how the data and address lines behave. If you don't have such tools, it may be easier to just change both chips as the fault is most likely in the memory chips.
Reply 14 of 26, by RetroPCCupboard
CharlieFoxtrot wrote on 2026-01-28, 06:42:
Ok. Thanks. I will try to see if either is hotter than the other. I had, had the laptop on for quite a few hours when it died. I was learning assembly on it.
Is this what I need to order? I can't tell from the picture if it is surface mount:
https://ebay.us/m/ifLWcB
Reply 15 of 26, by RetroPCCupboard
I do have an oscilloscope but its one of those cheap pocket-size MiniDSO ones and I think max frequency it can see I think is 1mhz.
Reply 16 of 26, by CharlieFoxtrot
RetroPCCupboard wrote on 2026-01-28, 07:59:
Ok. Thanks. I will try to see if either is hotter than the other. I had, had the laptop on for quite a few hours when it died. […]
Looks about correct and you can definitely see SMD legs and I believe the chips on your pic is also HM628512ALFP-7, which means they are identical. That is for 10 chips, so if you don't need more than two, it may be worth looking at few other sales for individual or 5 x chips to save some money,. Of course spares and parts for future projects do you no harm, but just a thought.
Reply 17 of 26, by CharlieFoxtrot
RetroPCCupboard wrote on 2026-01-28, 08:02:
Not the best tool for sure, but might be enough to probe the pins and see if there is life or not and to compare the two chips, so I'd get the data sheet for the chip and do some probing if not for anything else than to learn and find out what I can actually do with that scope. There is not that much you can lose, except your time.
Reply 18 of 26, by RetroPCCupboard
CharlieFoxtrot wrote on 2026-01-28, 08:10:
That's the cheapest I can see with that exact part number. There are cheaper ones that begin HM628512 but the letters afterwards are different. I am not sure if the final letters matter. Anyhow, this 10 pack is barely more expensive than the prices of those other chips in lower quantities. It gives me some spares if I screw up the soldering, or if one dies again.
I will see if I see anything different between the chips with the oscilloscope.
Reply 19 of 26, by RetroPCCupboard
Is it possible that something in the design of the motherboard could have killed the RAM I wonder? Perhaps it's being run out of spec somehow. I did notice one wire on the VGA module that's been hand soldered after assembly. Which makes me think that perhaps there could be some errors in the design.
