Cpu for K7T Pro2 ?
First post, by nali
There's a Duron 600 on my K7T Pro2 Ver:1 (W6330VMS V3.6 100702 11:00:51)
I would like to upgrade it with a more powerful CPU.
But I can't find clear information about what is supported.
For example the doc for the Bios 3.6 says support for XP 2600+, only for K7T Turbo2.
But it's never clear what the "not Turbo" card can do.
I read the card support a Athlon 1.4 GHz, but also it doesn't support a Athlon 1.4 GHz 😀 Conflicting, as usual ...
The bios of my card says it goes up to 133, and multiplier up to 13.5. Which gives a theoretical max of 1.8 GHz. Quite 1733 MHz as on XP2100+
I would not mind using a XP 2500+ for example, even if it works just like a 1700+. All I need is bios support for the cpu.
The bios update 3.0 says "Update AMD recommend CPU string for Palomino CPU (1.5Ghz & above)."
So it should support the last Palomino CPU ? XP 2100+ ?
Of course I use the latest bios.
What do you actually use on this board ?
What I understand is Palomino cpu, with a code for example AX2100DMT3C would work, but Thoroughbred cpu like AXDA2500KV4D would not.
Am I right ?
