Pci sound card ?
First post, by cydvog
hi just found this card on ebay.
name is " Marian Marc 2 Pro "
i like to use this as regular sound card is it possible ? do i need any components? thanks.
Reply 1 of 6, by cyclone3d
Do you have a source for drivers or documentation? It is using a xilinx fpga chip, no a normal sound card chipset. Is there a breakout cable that comes with it? If not, you will want the documentation to be able to make a breakout cable.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 6, by CharlieFoxtrot
Depends on what you mean by regular sound card. AFAIK this is a card designed for audio workstations used for music production, broadcast, post production editing and whatnot. It is a professional card and not designed for Windows gaming, so it would perform badly or not at all in this task.
Reply 3 of 6, by akimmet
If this card is anything like other DAW interface cards I have worked with, it will not have any analog signaling on board.
The Sub-D connection is probably clock sync not MIDI or an analog breakout port. The optical ports are most likely a multi channel ADAT port. If you are lucky the optical ports may be AES/ABU which is somewhat compatable with S/PDIF.
Reply 4 of 6, by NeoG_
According to the documentation for the card, the optical jacks are S/PDIF and there should be drivers somewhere for 95/95/NT4 that support DirectSound. So it's possible to use as a sound card.
https://www.marian.de/files/marc2p/m2phbus.pdf
Since you don't have the analog breakout cable, you will have to use an optical decoder on the S/PDIF output to get an analog signal.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 5 of 6, by akimmet
Well I stand corrected, this card may actually be used as a windows sound card with an external DAC.
Windows drivers appear to be here:
https://www.marian.de/files/marc2/
Reply 6 of 6, by NeoG_
It looks like there is a standard and pro version of the drivers, the PCB looks like the pro version
