predator_085 wrote on 2026-02-03, 11:18:
All in All I am happy with my asus tusl2-c mainboard with a tualtin celeron 1,3 mhz cpu running with geforce 4 4200. I am quite happy with the results. But i am consodering the max the system with getting a tulatin pentium 3 and maybe a better card.
Which brings me to the question if upgrading from gf 4 to gf fx would do anything for my mainboard/chip in the win98se gaming realm or is the extra power usefl for win98se. I coul get gf fx 5500 at a decent price.
it's really depends on what you're looking for, for win 98 build both gf4 and FX cards (later ones) are excellent for that build, only downside is the FX cards is the performance, the shader and texture quality is reduced by comparison to the GF4 TI 4xxx, the FX 5200 128-bit version is not terrible, it's on-par with geforce 2 gts performance, the 5500 is just an overclocked 5200, 5600 ultra is closer to basic geforce 4 ti 4200 levels, honestly it's nice to have mid-range card stock clock-speed then go with more powerful card that tends to die quicker due to more power and extra heat, with 20+ year old cards, the age can be a big problem for these type cards: vram chips can get corrupted (bit-rot), ageing/failing capacitors and fan/heatsink need to be properly cleaned or replaced. i already replaced 3 cards heatsink/fans and some recapping.
I also have a p3 Tualatin rig, with P3 1.26ghz, 512mb of sdram, that I’m very happy with it, and geforce 4 ti 4200 128-bit is perfect for that rig, very good support for older titles and DOS using Direct X 8.2 due to some programs (like daemon tools) don't run very well under DX 7 and runs very smoothly using force-ware 31.40 drivers, the 45.23 drivers is a little finicky under win 98.
the only real use for the FX cards in my opinion is for use of DX9 (despite how poorly it was handeld) for n-glide and dgvoodoo support you can play games with glide support and to save you a lot of headache and money on getting expensive 3dfx voodoo cards.
also ATI Radeon 9xxx cards are also excellent and much cheaper by comparison to the geforce ti cards, I have 9200, 9500, 9600xt (the 9600xt is my backup card in case my gf4 card is failing), aside from lacking legacy features like table fog and 8-bit palletized textures, there very good for win98, also have dx9 support, some games actually look and play better on radeon then geforce, the image quality on those radeon cards is much sharper and cleaner then the geforce.
