387 FPU identification
First post, by RandomBlankUsername
Starting a new thread, as I didn't want to hijack this thread:
A brief comparison of 386 FPUs
Long story short, I recently bought a CX83S87-33 from .cn from a source I previously had good experiences with, what arrived was some badly lasermarked chip (I mean look as the "F" and "sM" using different fonts than the rest).
After checking out the GND/VCC pins I decided to give it a try in a system I don't care too much about ... turns out it works.
So what did I get? Without checking the die I'm currently unsure whether it's a legit chip.
What I tested so far:
LandMark 6.0 -> 83D87
Sysinfo -> Non-Intel 387
NSSI -> C&T 38700, 33MHz
IEEE-Test -> Fine (taken from: https://theretroweb.com/uploads/drivers/cyrix … 06816664168.img)
IIT 4x4 Test -> Fail (taken from: ftp://ftp.oldskool.org/pub/drivers/IIT/IIT Math Coprocessor/IIT.ZIP)
Intel FPU Diagnostics -> Fail (fails transcendental test ... taken from: https://winworldpc.com/product/386sx-math-coprocess/10)
The main reason I'm going rather indepth is because the final target system would be a PS/2 Model 60 with an "IBM Cached Processor Upgrade Card" (IBM 486SLC2-66) that can enable FPU caching for Cyrix FPUs, where it would run at 33MHz. While I've used that FPU in that system and the FPU cache can be enabled and provides a nice 50% boost in Checkit3, I noticed the machine getting rather unstable (hangup on warmstart, Speedsys CPU test hanging). Quake Timedemo works.
The machine I did the initial tests on has a VLSI TOPCAT board running at 25MHz, where it runs stable.
Currently I'm unsure whether it's a legit Cyrix FPU (vs. C&T 38700), if it's rated at 33MHz (or less - but I'd assume Quake would be an issue then) or if the IBM CPU Upgrade is the source of the instability (runs stable without FPU).
Any leads would be highly appreciated.
Reply 1 of 13, by Anonymous Coward
It definitely looks weird. It’s probably a 20 or 25mhz c&t that’s been remarked as a 33mhz Cyrix. What’s funny is the c&t chips are far more valuable to collectors in the present day.
See if you can download the manufacturers’ diagnostic from c£t, ulsi and cyrix to see if it can pass the tests.
Reply 4 of 13, by MikeSG
There were some "REVEAL by Cyrix" 387sx FPUs on ebay not long ago. I tested one up to 45MHz. They are hardware implemented like the Cyrix and Ulsi's...
Reply 5 of 13, by RandomBlankUsername
After going down a rabbit hole last night, I guess my system might be affected by this? This would explain why a considerable number of 286->486 CPU upgrades were downgraded to 50MHz and/or 66MHz expansions being rather shortlived.
Reply 6 of 13, by RandomBlankUsername
Oh ... and in case anyone ever finds the datasheets for the 87DLC and 87SLC (QFP package) FPUs ... please let me know.
Reply 7 of 13, by Anonymous Coward
RandomBlankUsername wrote on 2026-02-14, 17:55:
Only the early versions of the 83D87 and 83S87 had this problem. The old 83D87s are easily identified because they had grey tops and smaller lettering. The older 83S87s were ceramic PLCC, switched to plastic in the later models. The vast majority of Cyrix FPUs you encounter will be the later models, as they were produced is far greater quantities.
Reply 8 of 13, by RandomBlankUsername
Anonymous Coward wrote on 2026-02-15, 01:33:
I'd definitely consider mine to be plastic instead of ceramic ... is there a way to derive the production date from the code in the bottom right on the CX83S87, so I don't pull yet another dud? I noticed there are variants with a small space between CX and 83S87 and those which don't have it.
Reply 9 of 13, by Anonymous Coward
The silkscreen on these chips is supposed to be bright white.
The printing in the bottom right corner should contain a datecode, but I've forgotten how to decipher it. CPU-World is a good place to check.
Reply 10 of 13, by lti
Anonymous Coward wrote on 2026-02-15, 13:07:
These relabeled chips usually have a somewhat recent fake date code laser-marked on them (along with the fake markings), so seeing a 2015 date code on a Cyrix chip will be another sign that it's fake. It doesn't really help much since the rest of the markings are so obviously wrong, but it could identify some of the better-quality fakes.
Reply 11 of 13, by RandomBlankUsername
First one I got was a badly relabeled Intel (possibly even a 80186/286 as the pinout didn't comply? - marking on backside, placement of ejector pins on top, pin material showing through [see the white spot on the F]), that went straight to the trash after getting my money back. Problem is on most major sites they'll show originals (which happened to me twice, the later even had videos) and send you fakes/relabels.
Reply 13 of 13, by RandomBlankUsername
Comptest seems great - already tried that and it detected my .cn Cyrix as a 83S87
PC Config is another tool that can differentiate between old and new Cyrix FPUs.
http://www.dcee.net/Files/Utils/conf802e.zip
