^The Zenith Z-Star EX seems to be a notebook,
the flash card adapters seem use 44 pin IDE which has power wires on the data cable itself.
To use them on a PC, a passive 40pin to 44pin adapter is often used.
Which has an extra cable with an FDC or Molex connector for +5v.
They look like this (just as an example):
https://www.amazon.de/44-polig-40-polig-Deskt … =A1OYBPU55BK2AN
Alternatively, some passive adapters without an extra cable might
use the +5v found on key pin of later PATA ports instead (like DOMs would do).
Edit: Sorry for the bad wording.
What I meant to say is that it's 44pin IDE, which is used by 2,5" notebook HDDs.
It's found in embedded sector, too. It has +5v on the data cable, the spacing of the pins is more narrow.
The normal 40 pin IDE cable we're used to doesn't normally have +5v on the data cable.
Except if the mainboard is that of a Thin Client or an internet set-up box, maybe. Then the key pin is likely available and carries +5v.
-> The key pin location is, were normally that hole on 40 pin IDE plug often is filled with plastic/were there's a missing pin in the 40 pin socket.
That's the original purpose of the key pin, after all: To prevent reverse insertion of 40 pin IDE cable.
The filled hole+missing pin on connector make sure the port on motherboard and the HDD cable are correctly aligned.
On a 286/386/486 vintage mainboard, however, all pins are installed on 40 pin IDE port.
So the pin is there (because none is missing) but it's not connected or it is grounded.
Sorry for the overly complicated wording. 😅
Edited.
