EAX appreciation thread
Reply 1020 of 1096, by Joseph_Joestar
The Serpent Rider wrote on 2026-02-19, 10:10:
Creative marketing bullshit should be taken with a grain of salt.
I agree that there is a lot of marketing speak here. After all, it's a demo disc meant to get gamers excited about Creative's flagship product at the time.
However, we previously had people saying that 128 hardware voices was marketing bullshit as well. But thanks to Falcosoft's recently released OpenAL Test tool, it was verified that some games can and will use 100+ hardware voices on X-Fi cards. So I wouldn't dismiss Creative's claims outright, without definitive proof to the contrary.
My retro builds
Reply 1021 of 1096, by Falcosoft
Joseph_Joestar wrote on 2026-02-19, 10:19:
For some more interesting performance metrics I have added the ability to display how long the OpenAL Test tool's busy loop runs. That is how long it takes creating the OpenAL context, initializing and loading the buffers with audio data and then finally freeing the buffers.
This can show from a specific aspect how well the given OpenAL implementation is optimized for performance.
Here are the results:
The attachment AudigyHW.jpg is no longer available
The attachment AudigySW.jpg is no longer available
The attachment OpenALSoft.jpg is no longer available
The attachment RealtekHW.jpg is no longer available
It can be seen that Creative's HW based OpenAL implementation is the fastest (4-5 ms).
Regarding that OpenAL Soft reports and handles 4x the amount of buffers it's pretty fast as well (39-40 ms).
The generic software implementation also uses 4x buffers compared to Audigy HW but it is much slower than 4x (238-240 ms).
And finally the Realtek supposedly HW based implementation: rtk_oal.dll. It's painfully slow (3100-3150 ms!).
(The Realtek OpenAL driver can be found in Realtek's 3DSoundBack software package.)
@Edit: rtk_oal.dll is not likely to be hardware based since:
1. When it's used the test application is detected by the Windows mixer and you can change the volume by the mixer. So it's sure that it does not bypass the Windows audio stack.
2. The same hardware under WinXP (where hardware acceleration is really available) reports only 32 hardware buffers through Direcsound3d. So the 66 buffers reported by rtk_oal.dll seems no to be related to real hardware resources.
3. When another OpenAL app uses the driver for output the 1st instance still can report 66 available buffers.
Her is the new version of OpenAL Test anyway:
The attachment OpenALTest14.zip is no longer available
Website, Youtube
VST Midi Driver Midi Mapper
Reply 1022 of 1096, by ott
Falcosoft wrote on 2026-02-19, 14:22:
It can be seen the Creative's HW based OpenAL implementation is the fastest (4-5 ms). Regarding that OpenAL Soft reports and han […]
The generic software implementation also uses 4x the buffers compared to Audigy HW but it much slower than 4x (238-240 ms).
And finally the Realtek supposedly HW based implementation: rtl_oal.dll. It's painfully slow (3100-3150 ms!).
Big thanks, that's exactly what I wanted to find out!
ott wrote on 2026-01-23, 23:50:
Is it possible to somehow compare Creative's HW OpenAL vs OpenAL-Soft audio latency?
Reply 1023 of 1096, by Falcosoft
ott wrote on 2026-02-19, 14:29:
Since OpenAL Soft uses WASAPI in shared mode latency cannot be lower than ~30 ms. But according to Github conversations it uses larger buffers so latency is larger in practice.
OpenAL Soft itself will add about 50ms on average, given the default 20ms period size and 60ms buffer.
https://github.com/kcat/openal-soft/issues/682
As for Audigy HW I have no justifiable data but considering that Creative's HW OpenAL driver's audio path is similar to Creative's HW ASIO driver I would guess that the latency is much better also.
(Creative's HW ASIO driver's latency is less than 10 ms if configured properly)
Website, Youtube
Reply 1024 of 1096, by ott
Falcosoft wrote on 2026-02-19, 14:44:
Thanks for the addition.
It seems that low-latency audio in games aren't of much interest these days.
https://youtu.be/okIpbu1tp_A
Reply 1025 of 1096, by Joseph_Joestar
Joseph_Joestar wrote on 2026-02-19, 08:19:
When I have more time, I'll try to put this on the Vogons wiki, so that it's more easily accessible.
And done! Behold our new EAX wiki page: https://www.vogonswiki.com/index.php/EAX
Still needs some polish, but most of the important info should be there.
My retro builds
Reply 1026 of 1096, by Joseph_Joestar
For some more interesting performance metrics I have added the ability to display how long the OpenAL Test tool's busy loop runs. That is how long it takes to create of the OpenAL context, initializing and loading the buffers with audio data and then finally freeing the buffers.
Cheers! This should make for some interesting comparisons, especially against period correct on-board audio solutions (Realtek).
My retro builds
Reply 1027 of 1096, by UCyborg
There's a KillDrvX.exe utility bundled in latest Audigy Support Pack 8.1. If you run it, it says:
The driver currently installed is affected by a bug that crashes Windows when disabled or uninstalled.
To workaround this issue, the CTAUD2K service must be disabled.
Daniel K's blog notes:
Driver uninstall on Windows Vista or later (affects all cards, except Audigy 5/RX SB1550 and Audigy 4 Series II SB0612):
- The included driver for Windows Vista or later has a bug that causes a stop (blue screen) error when unloaded by disabling the Audigy or uninstalling the driver. To workaround this issue, run the KillDrvX.exe utility included and restart when asked to do so. Proceed normally and uninstall all the software or only the driver.
But, stopping the CTAUD2K driver through System Informer or Process Hacker crashes both Win11 and XP. And I have Audigy Rx. Are there different versions of this card?
I haven't tried uninstalling specifically though, was hoping to find a way to reset the driver without rebooting.
Correction: Win11 doesn't allow stopping CTAUD2K through System Informer. It crashes in ctoss2k.sys when disabling the card in Device Manager though. I forgot where it crashed in XP.
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 1028 of 1096, by AndreaColombo86
It looks like the community at OldUnreal released a new patch for Unreal Tournament 2004. The question is whether you can still use the EAX 5.0 patch with it. If anybody tries it, please report back here!
Reply 1029 of 1096, by Joseph_Joestar
While researching something else, I accidentally stumbled upon an older version of Creative's EAX website.
This one is from 2003, and it describes EAX 3.0 and EAX 4.0 features in a more technical manner, without the marketing gobbledygook. I've incorporated these descriptions into the new EAX page on the Vogons wiki, and used Creative's old site as reference.
My retro builds
Reply 1030 of 1096, by ott
AndreaColombo86 wrote on 2026-02-19, 23:37:
They use cross-platform libs like SDL (it has audio engine with basic features) and the patch is designed for modern compilers/builds (requires Windows 7+).
This probably makes EAX APIs incompatible. I haven't tested it yet, but I'll be happy to be wrong.
Joseph_Joestar wrote on 2026-02-20, 00:09:
It's better to refer to technical docs from the EAX 4.0 SDK, I recently found them on the kX driver's GitHub:
EAX 4.0 Introduction (2003).pdf
EAX 4.0 Programmer's Guide (2003).pdf
EAX 4.0 Sound Designer's Guide (2003).pdf
Reply 1031 of 1096, by Joseph_Joestar
ott wrote on 2026-02-20, 01:28:
It's better to refer to technical docs from the EAX 4.0 SDK, I recently found them on the kX driver's GitHub: EAX 4.0 Introducti […]
Thanks! I already referenced the EAX 2.0 SDK where applicable (e.g. for Obstruction and Occlusion) so I'm sure this one will be useful as well.
BTW, it seems that we're missing a document from the EAX 4.0 SDK. I found several references to an "EAX Unified API guide" but there's no such document on that repo at least. Would be nice if someone could dig it up, as many games from the mid 2000s used EAX Unified in order to run on integrated audio solutions (Realtek).
My retro builds
Reply 1032 of 1096, by ott
Joseph_Joestar wrote on 2026-02-20, 05:57:
I found old doc in EAX 2.0 SDK, but to be honest I don't understand much about it.
The attachment EaxUnified.PDF is no longer available
Reply 1033 of 1096, by Joseph_Joestar
ott wrote on 2026-02-20, 12:10:
Cheers! I imagine there's an updated version of that in the EAX 4.0 SDK somewhere, but we'd have to find the full archive.
And yeah, EAX Unified was around for a long time. I think Final Fantasy 8 (PC version) was one of the first games that shipped it on the disc back in January of 2000. Originally, it allowed EAX 1.0 capable cards to make partial use of EAX 2.0 features. But it became a lot more popular during the mid 2000s, because Creative made EAX 3.0/4.0/5.0 proprietary, so third-party sound solutions were limited to EAX 2.0. Newer versions of EAX Unified could slightly help with that, but the results weren't always great on non-Creative hardware.
My retro builds
Reply 1034 of 1096, by RetroGamer4Ever
It would be great if we could get access to the later versions of the EAX SDK, so we could make sure that as much of the software-understanding needed to keep using EAX is not hidden away and lost to time. Unfortunately, CL hid the later versions of the SDK behind corporate walls, so you could only get access to it through them.
Reply 1035 of 1096, by Joseph_Joestar
I found these illustrations in the EAX 4.0 SDK, specifically in the "EAX 4.0 Introduction" document that @ott linked earlier. Figured they might be useful to other people as well, since they offer a visual representation of how sound propagates in-game when EAX is used.
The attachment EAX_Obstruction.jpg is no longer available
The attachment EAX_Occlusion.jpg is no longer available
The attachment EAX_Exclusion.jpg is no longer available
The attachment EAX_MultiEnvironments.jpg is no longer available
Pretty sure I experienced all of these while playing Thief 3: Deadly Shadows.
My retro builds
Reply 1036 of 1096, by UCyborg
UCyborg wrote on 2026-02-18, 20:24:
I was modifying CoDUO-YAP, but currently not having Visual Studio installed at home, I borrowed it at work to modify plugin code and only naively looking at Quake III code at first, I crashed CoD with modified plugin, because Sys_QueEvent() function there has different signature from Quake III.
Oops, that was wrong, the signature is the same, but Visual C++ compiler may employ custom calling convention when whole program optimization is enabled. The first parameter to Sys_QueEvent() is passed in the EAX register, the rest are passed on the stack.
I managed to get mouse buttons 4 and 5 working. If anyone cares, the binaries are at https://github.com/UCyborg/CoDUO-YAP/actions, the top entry, then under Artifacts. Though apparently an account is needed to download from this section. I'd put them under releases, but hopefully Clippy95 will pull changes to their version and release it.
Reply 1037 of 1096, by AndreaColombo86
Quick question—what are the best drivers to use for an X-Fi Forte 7.1 on Windows 7?
I was thinking DanielK’s, cause I remember reading in this very thread that Auzentech’s drivers were a PITA. But there’s also the problem of the latest drivers having OpenAL issues, so I want to avoid that and grab a version that doesn’t.
I’m torn between the Forte and a Titanium HD for my Win7 build and the Forte appears to have better components and a better headphone amp (I would exclusively be using headphones)
Reply 1038 of 1096, by Joseph_Joestar
AndreaColombo86 wrote on 2026-02-25, 18:41:
I don't have either of those cards, so I can't say one way or the other. But on the topic of DanielK's drivers and OpenAL, in his release notes, he states that the issue has been addressed in the latest version of his X-Fi support pack (8.0 Refresh 3).
While I haven't done a proper A/B comparison against the known good 2.17.0008 driver to confirm that, I didn't encounter any glaring issues while testing a bunch of OpenAL games under Win10 recently while using DanielK's drivers. That said, my tests were fairly brief, as I was just measuring the currently used number of hardware voices in specific games, but everything seemed normal during that time.
My retro builds
Reply 1039 of 1096, by Joseph_Joestar
Just posting this screenshot here since I need a reference image for X-Fi CMSS-3D Virtual. It's taken straight from the X-Fi Demo Disc, and gives a short overview of that mode.
The attachment CMSS-3D_Virtual.jpg is no longer available
I tried this briefly, and it seems to ever so slightly enhance the elevation perception for sounds coming from above and below the player. Though how well that works might depend on the physical placement of your speakers.
My retro builds
