First post, by cucgod
hi guys,
im a long time reader and really love this forum. after lots of searching around i could not find an answer to my problem.
i have a gigabyte GA-5AA ss7 board in rev2.2 and it was running an amd k6-2 400 in 4*100 just fine.
i was swapping cpus the other day when the metal clip keeping the cooler in place snapped. f***
but so far i cannot see any damage done to the board. it looks good to my eyes, no visible sign of mechanical damage or hit traces ....
now to my problem:
since this accident, it looks like i cannot set the fsb to anything lower than 105mhz on this board. so even if the jumper (JP14) is set to the before working 2-3 position, it now just does not register as such.
at least thats my conclusion...
i dont have a tool to measure frequencies but i cannot boot any longer with any pci vga card i tried (maybe because of the fsb frequency the pci clock is too high?) but agp works fine.
also the k6-2 400 which was detected and working fine before, now became a k6-2 417 😀 (104.25 mhz fsb if that makes any sense...)
any advise or hints would be great as i really dont want to give up this board (they are really expensive nowadays) and in the current state it does not seem to work properly...
tia
