MartyPC @ 8MHz?
First post, by middlenibble
Hi all,
I'm trying to configure a MartyPC box which performs like an 8088 at 8 MHz but can't make it work. It's either 4.77 MHz or something above that via the turbo button. I appreciate any insight.
Reply 1 of 6, by GloriousCow
Turbo should be 7.3MHz. In what way are you seeing it way above that?
MartyPC: A cycle-accurate IBM PC/XT emulator | https://github.com/dbalsom/martypc
Reply 2 of 6, by middlenibble
I'm using the ibm5160_xtide config.
Without turbo, Topbench scores 4 and classifies the box as an Intel 8088 @ 4.77 MHz.
With turbo, the box scores 13 as an NEC V3 @ 8MHz.
Reply 3 of 6, by GloriousCow
middlenibble wrote on Yesterday, 14:18:
That's not incredibly far off the mark, although I'm not sure why it's picking up an NEC for that. Do we have results to compare to from a real 8MHz system?
Reply 4 of 6, by keenmaster486
FWIW turbo is upwards of 14 MHz for me.
World's foremost 486 enjoyer.
Reply 6 of 6, by middlenibble
I apologise for the confusion - I had tampered with MartyPC's the source code. Here's the results from the v0.4.1 tag on turbo. I'm still using the ibm5160_xtide config.
