Test and troubleshoot PC@LIVE motherboards
Reply 1060 of 1072, by PC@LIVE
With the AZZA P4M2-MVB and P4 2400/400 motherboard, I did some benches, and the results do not seem bad at all, if compared to a DFI with Celeron D 2.66 GHz, but later we will see to make a direct comparison with the same CPU, so as to understand if it changes a lot with the simple transition from Celeron to P4, I think there is a certain difference, because in the past I had changed a P4 2000 with a Celeron 2600, and it seemed slower to me, despite the greater frequency.
I start with Phil's benches, for a couple it was not possible to see the results, one definitely due to the CPU speed, and the other instead could be the monitor (?), apart from this, here's what I got:
2) 615.3 3) 612.3 4) 127.6
5) 382.3 6) 57.3
A) 553.26 b) 139.09 c) 259.4 e) 122.8
K) 565.5 m) 505 n) 1603.17
In addition to these, I ran other DOS programs, including QTPRO obtaining:
CPU Bench Mark 518777 Dhrystones
262721K Whetstones
Compative about 48,000 MHz XBenchSpeed
And also those of NSSI 060
CPU Perf. Index: 836444 Dhrystones/s (839562, 16 bit code)
FPU Perf. Index: 212302 KWhetstones/s (212729, Real mode).
Phil's scores of the DFI NB78-BL, are these:
2) 441.5 3) 523.7 4) 90.3 5)284.8
6) 46.3 a) 461.05 b) 103.16 c) 216.7
E) 60.3 m) 463 n) 1108.15
All inferior to the AZZA, sometimes the gap is clear, as in n), but I consider the integrated video card, a disadvantage compared to the ATI 9250 AGP of the DFI, so some could be even ️ better.
It remains to replace the TC23 SACON 3300uF 6.3V, for complete recovery, then you should decide the amount of memory, and whether to use an AGP VGA instead of the integrated one.
After replacing the swollen electrolytic capacitor, I would have to upgrade the memory, and the disk to use, to load Windows XP (probably), from there then I can run other bench programs, such as CPU-Z Sandra BMX etc...
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
Reply 1061 of 1072, by PC@LIVE
Well now that I'm done with the AZZA, I'm going to an ASUS motherboard with something in common, namely the support of DDR RAM and P4/400 CPUs, the rest differs, but anyway they are the same kind of PC.
What is ASUS?
A P4B266 REV.2.01, with Socket 478 and DDR RAM slot, probably the first with this type of memory, previously used with Intel chipsets, RDRAMs and later SDRAMs, the latter were not the best with the P4, and I think it was a fallback solution while waiting to be able to use the DDR.
Here we have three DDR sockets, in total so we can get to 3 GB of RAM, more realistically 2 GB would still be enough.
Given the ATX format (a classic), we have plenty of PCI slots, well six plus an AGP and a CNR, if we wanted to fill them all, I remind you that in the ATX cases the maximum number of cards is seven, so it is evident that a PCI and the CNR are shared.
The CPU supplied with the motherboard is a P4 SL5ZU 2.2GHz/512/400/1.5V, the chipset is Intel 845, to the motherboard I added a 64 MB DDR AGP 8X GF4 MX440 video card, in the future I can always change it, if I need something better.
In this motherboard, there is integrated audio, with C-Media CMI8738/PCI chip, I think it can go, except for special or professional needs, in which case it is possible to disable it and use a special PCI sound card.
There is no integrated LAN, and this given the number of available PCI slots, should not be a problem, in fact it could be an advantage, because they are usually 10/100M, while a special PCI LAN card, could be 1000M, then if we want, we can add a USB Wi-Fi, in one of the ports available in the shield.
Returning to the motherboard, despite several attempts I failed to make the IDE CF adapter work with CF memory card, sometimes it happens that it does not work in some motherboards, so I think I will try to connect a HD and a CD player, to load Windows.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 1062 of 1072, by PC@LIVE
Not happy with the results obtained recently, I definitively put away the ASROCK ConRoeXFire, because before the adjustment of the PIN, it is definitively (?) KO put, I tried everything I could, and no post code is displayed (— —)!
Now I have the doubt whether the PIN repair was successful or not, in short I don't know what happened, but the card went from displaying some codes, to not displaying any, plus while before it beeped without RAM, now no beep!
This thing, in the past has happened with other motherboards, initially working and after a few starts, completely KO, despite the tensions being normal.
So having a free seat, I'm going to an LGA 775 motherboard, with the typical appearance of an ASUS, but which is actually an HP Benicia, or ASUS IPIBL-LB REV. 1.01, with Intel G33 Bearlake chipset, uATX format, Intel Pentium Dual Core E2160 1.8GHz SLA8Z CPU, AMI v5.35 BIOS of 12/16/08, and integrated audio, video and LAN.
The one I own, is a bit bare version, in the PCB you notice many empty places, and ditto in the shield, overall it has a couple of positive things, and one minus, the minus is the lack of a 40PIN IDE port, to connect the drives, there are only SATA ports (N.4), the positive things are the support for Intel CPUs with FSB 1333, and the presence of four DDR2 RAM banks (667 or 800).
If it is necessary to install a better video card than the integrated one (Intel GMA 3100), there is a PCI-E 16X slot, or alternatively for other cards there are two PCI-E 1X and one PCI.
The original PC is an HP dx2400, which I obviously don't own, having only the motherboard, however I tried it and it works, at least it seems so, then later I would have to connect a disk and a CD player, to install Windows, and some bench and diagnostic programs.
At startup it shows an error message, but suggests pressing F2 to continue, maybe it has remained stored, because there is a low CR2032 battery, so any changes to the BIOS are not stored.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 1063 of 1072, by Minutemanqvs
I'm hijacking your thread as it looks like it's the mainboard repair thread 😁
A couple of months ago I got a dead MSI KT7 Pro2 board (https://theretroweb.com/motherboards/s/msi-ms-6330-ver-1.0c) that had badly leaking caps.
After replacing the caps with new ones (Panasonic)I'm finally at the moment where I feel confident to power it up. I started by verifying that:
- There is no short between the power rails (ATX connector)
- Check if the VRM Mosfets are not shorted (good)
So I plugged a Duron 700 in the board, added my POST card and shorted the "Power" switch and...nothing. Absolutely no sign of life.
With my multimeter I can see 3.3V on the power switch, so at least it's coming to the right place. On the other side, on the ATX connector I can measure PS_ON at 4.7V which is also fine.
When I short the power switch, PS_ON stays at 4.7V instead of going to 0 as it should. So some component that acts between the power switch and the ATX PS_ON does not cooperate.
So next step, force a power on by shorting PS_ON to GND: the board starts and the POST card displays codes. The board itself has diagnostic LEDs and it shows 0010: Initializing Keyboard Controller (in the user manual)
So, any idea on what could cause the issue? I fear it's the southbridge as I see no other chip which could handle the power management.
Searching anything Nexgen, PM me if you have one. Also ATI Rage 128 PCI cards.
Reply 1064 of 1072, by PC@LIVE
Minutemanqvs wrote on 2026-02-19, 20:25:
I'm hijacking your thread as it looks like it's the mainboard repair thread :D […]
Ciao 👋
No problem friend, if I can help you I'll gladly do it, I don't think I have a motherboard like yours, but I have a very similar one that is a Turbo, unfortunately I haven't fixed it yet, even though it's been several years.
Maybe 🤔 it's as you suggest, an SB problem, but if it was, I think it can be diagnosed, I don't know if after a few minutes that it's on, it stays cold or gets hot (?), if it stays cold it could be the missing power supply, which you should understand where it comes from, maybe a pdf of the SB with the pinout, could suggest which track to follow.
One thing I would check, when you turned it on (forcing it), are the voltages on the Mosfet PINs, if it's not too complicated, write everything down and publish the Mosfet and PIN voltages here.
By following these steps, we can exclude what works from the troubleshooting, and seeing that it shows codes, it seems that the BIOS works, and the CPU should also be good, eventually if you have the possibility to use a working motherboard, you can check the components.
I don't know if you've already tried, what I suggested, possibly don't take into account, what you've already done.
So good work, and update me on the tests you run.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 1065 of 1072, by PC@LIVE
Looking better, I would have a couple of things to suggest, first put a CR2032 battery and try to start (normally), some boards like the i81X do not work if the battery is empty, so this one could also behave in the same way, if you are interested there is a video of Tony359, in which it repairs the circuit of this battery in a short time discharged.
For the second problem, of the indications of the 4 LEDs, yes I think it is correct, since the keyboard is not connected, you should try to connect one, and see if it continues, in case then complete the start, it is clear that the SB works.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 1066 of 1072, by PC@LIVE
I would continue with the tests on the ASUS HP IPIBL-LB, but not having a 40PIN IDE port on board, I can't run the usual Bench and start DOS, even if the PC is very powerful compared to the single-core ones, with DOS I believe that the CPU is used at half the potential, or maybe even less, I don't think that the various instructions like SSE or similar, are used when the SW is running.
As a replacement for a SATA disk, you could use a memory card via IDE-SATA adapter, I had a couple, but after a certain period of time in which they worked, they stopped working, at the moment I'm not going to get more, rather I prefer to look for a SATA-CF adapter later, or an ISA-CF card or as a further alternative, I could use a bootable USB pendrive of tiny size (today), enough to hold what I need to run the usual bench.
Going back to the motherboards, I have a motherboard very similar to the IPIBL-LB, also ASUS HP, but this is an IPIBL-LA REV. 1.03 (HP Berkley - GL8E), basically I think it's the first version of this type of motherboard, and most of the components are the same, there are small differences, and especially here the equipment is clearly superior, almost complete I would say.
As a CPU I would have, a Pentium D 820 2.8GHz/2M/800 SL8CP, it's the only PC with Pentium D that I have, but this is a Pentium D of the 8XX series, I think the 9XX series is more common, in any case I don't know if it's the CPU originally used on that PC, however it could be interesting, give it some bench, just to understand if there is enough difference with other similar CPUs.
Before trying it, I have to replace a swollen electrolytic capacitor, it's an 820 uF 6.3V, I have some new replacements, I hope it's the only one to ask for a replacement, because I wouldn't want others, despite being visually fine, actually not to be.
This work of replacing the swollen electrolytic capacitor, I will see to do it over the weekend, then I would be planning a recap of the ASUS P2B-F, I think there is some electrolytic capacitor that prevents starting, certainly everything will be clearer when the work is finished, although the chances that it will work, will be clear when I check the capacitors removed, one or more out of tolerance, they could increase the chances that it will work again.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 1067 of 1072, by Minutemanqvs
PC@LIVE wrote on Yesterday, 10:52:
I tried with a battery this morning and things actually worsened (not because of the battery). The POST card now displays nothing. All the voltages seem to be ok on the POST card but no code is executed. On the board, the cPU fan spins. 🙁
What I can feel is that the SC1155CSW DC-DC controller near the VRM Mosfets is burning hot already a few seconds after the force power-on. User "nali" on this forum had the same issue and this caused his board to fail. These chips are easy and cheap to find, so it's still an option to replace it...but I wonder if it has something to do with my initial problem or if it's a second one.
So, measuring the Mosfet which are by pair. I set my multimeter to diode mode. The CPU has been removed at this point.
Q9 and Q12 (the upper ones on the picture):
- Drain (tab soldered to the mainboard) to Source (right leg): 0.4V drop on each Mosfet. As it's not 0V I conclude that there is no short here.
- Gate (left leg) to Source (right leg): 0.64V, so no short either.
Q10 and Q13 (the lower ones on the picture):
- Drain (tab soldered to the mainboard) to Source (right leg): 0.05V drop on each Mosfet (they are in parallel). This looks more suspicious so I went to continuitiy mode: 30 Ohm.
- Gate (left leg) to Source (right leg): 0.62V, so no short.
I don't have enough experience to conclude if there is a problem with Q10, Q13 or the SC1155CSW...
Reply 1068 of 1072, by Minutemanqvs
Adding some info, i measured some pins on the SC1155CSW (https://www.alldatasheet.com/datasheet-pdf/pd … /SC1155CSW.html).
Ground to Pin 12 (DRVGND): 0.13 Ohm, so ground is not floating
Ground to Pin 13 (LOWDR): 683 kOhm
Ground to Pin 14 (DRV): 6.6 MOhm
Ground to Pin 15 (VIN12): 15 kOhm
Ground to Pin 17 (HIGHDR): 880 kOhm
So nothing seems shorted here.
Reply 1069 of 1072, by PC@LIVE
Minutemanqvs wrote on Today, 09:49:
I tried with a battery this morning and things actually worsened (not because of the battery). The POST card now displays nothin […]
Minutemanqvs wrote on Today, 10:16:
Adding some info, i measured some pins on the SC1155CSW (https://www.alldatasheet.com/datasheet-pdf/pd … /SC1155CSW.html). […]
Ciao 👋
So, in fact it could be another problem that of the lack of post card codes, or if it is a consequence of forcing the start(?).
Unfortunately in these conditions, I did not see the normal voltages in those Mosfet, instead before it was possible that they were there, since the CPU showed some start signs, there was also the possibility of noting all the codes prior to the lock, it was enough to press the button on the post card, now it is possible that the chip that heats up, has failed (?) Or there is something around or in the circuit, but even before, maybe you would have made progress if you had turned on the motherboard with the RAM installed.
In conclusion I would say that you have to start over, try CPU and RAM if you can in another motherboard, if they work later you put them in the motherboard, I don't know if you checked the PowerGood pin (ATX power supply), this could say if there is a problem, but now I think there is for sure, while before maybe not.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 1070 of 1072, by Minutemanqvs
Thanks for your feedback. Indeed it's complicated to know what the root cause really is, or if some other things have broken since the initial situation.
Meanwhile I tested CPU + RAM on another board and they fortunately still work.
I will sit on this board for a couple of days to think about what I can do or just call it a loss and use it for spare parts. It's not like I absolutely want it, I have plenty of other S462 boards.
Reply 1071 of 1072, by PC@LIVE
Minutemanqvs wrote on Today, 11:15:
But you know it depends, it could still be repaired, even if now the chances are much lower.
But of course now solving the problem, it requires a greater effort, and so I don't know if you have time to dedicate to it or not.
However, if you decide to continue with the repair attempt, if I can help you no problem, if you want I can recover one of my motherboards, and look for one with the most similar circuit possible, if it works I could tell you the Mosfet voltages.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 1072 of 1072, by PC@LIVE
Following your instructions 🧭, I checked through datasheet the voltage regulator chip 😬, it seems to be very common in PC P3 and Athlon, well it seems that the initial problem, of failure to start, could be connected in some way to this IC, so the subsequent problem, could be due to the definitive breakage of this IC, or something connected to it.
I tell you that the problem could be another, but in my opinion, it's probably him who broke 😑, looking at the pdf file, I extracted an image, where you can see the individual PINs to what they are connected to, I don't know if you are equipped for removal and verification, that is, you have specific tools, but most are quite easy to verify, using a simple multimeter with diode test or in OHm 🕉.
Also from that image you can understand which PINs to check, clearly if you make suspicious readings, you could be close to identifying the problem.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
