Tandy 3 Voice Sound - SN76489 ISA Soundcard Project
Reply 480 of 499, by Boohyaka
I'm still rocking your old card and love it 😀 I must admit I didn't go through every single pages of this thread, can you maybe explain what your objectives are with this new card and what will be the major improvements over the existing one?
Reply 481 of 499, by matze79
I hope to finish the new design today (assigning JLCPCB parts for the order, rechecking all connections, and finalizing the routing). The past two weeks have been quite busy, so I didn’t have much time to work on hobby projects.
I might pick up a Keystone bracket today to do a fit test with a paper prototype.
The new card is basically the same design, just polished a bit and optimized for manufacturing at JLCPCB. Some component part numbers were changed to better match parts available there.
I also added a dedicated oscillator instead of relying on the ISA bus clock, since a user reported that the sound could be slightly off on some systems.
The voltage divider on the PC speaker mix-in will be adjusted to allow higher loudness.
I'm also switching to a Keystone metal bracket. The old design was originally converted from Eagle CAD, which caused quite a few consistency issues when replacing parts, so starting from a clean layout seemed more reasonable.
I also noticed that JLCPCB now offers metal cutting and bending services. In the future it might even be possible to order the bracket directly from them.
Reply 482 of 499, by holaplaneta
These are amazing news. Keep up the great work!
Reply 483 of 499, by jal
holaplaneta wrote on 2026-03-15, 10:29:
Seconded, glad to see the design is finished.
JAL
Reply 484 of 499, by Boohyaka
Amazing, thanks for the update and great work 😀
Reply 485 of 499, by matze79
5 pcbs are on order for testing purposes, i will report back soon 😀
Reply 486 of 499, by jal
Cool! Can't wait 😁
Reply 487 of 499, by underthebridge
I randomly decided to check back on this project, now I’m excited after hearing the update! 😃
Reply 488 of 499, by matze79
A small parcel arrived today!
Unfortunately, I won’t have time to test it until next week(end).
Depending on weather 😀
I’ll also set up a Google Sheet soon where you can add your forum name and other details if you’re interested.
Reply 489 of 499, by jal
Great!
Reply 490 of 499, by theelf
is posible to buy one?where? thanks
Reply 491 of 499, by jal
theelf wrote on 2026-04-14, 21:00:
See Matze's last post: "I’ll also set up a Google Sheet soon where you can add your forum name and other details if you’re interested." So no, you can't buy one yet, but if everything goes according to plan, you will be in the near future 😀.
JAL
Reply 492 of 499, by matze79
Quick Update:
PCB design seems to work. I had to add a patch wire because I made a small mistake, and I replaced the oscillator because I accidentally chose a 3.3 V version from Parts Library, which does not tolerate 5 V.
Unfortunately the 5V part wasn't in stock today.
Reply 493 of 499, by jal
Thanks for the update!
Reply 494 of 499, by matze79
I just can’t manage to finish it in time. I’m running out of time, and I’ve also been run into some health issues, so I haven’t really been able to focus on it properly.
I’m sorry, but I also have several other things I wanted and need to take care of, so I may have to abandon this project for now.
It doesn’t make sense to keep you waiting for an effort that I may not even complete in the next few months.
So I decided to upload all the files so you can build it yourself,
Link in Post #1
Thank you
Matze79
Reply 495 of 499, by jal
matze79 wrote on 2026-05-26, 07:11:
Damn, I'm sorry to hear that! Of course your health is more important, I hope you get it sorted out.
For those that want to try this (not me, I wouldn't know how to hold a soldering iron), is the latest revision of the PCB the final one, or did you intend to update it further?
JAL
Reply 496 of 499, by matze79
It's the same revision as Page #1, Post #1.
You don't actually need to learn soldering — it's possible to order it pre-assembled if you know how to assign the parts and create the assembly list. You’ll still need a USBasp (or another programmer) for the tiny13 though.
Maybe I’ll pick it up later at some point... I already have way too many projects started.
I even shut down my website because I just don’t have the time anymore — writing content, updating the VPS, and maintaining everything takes more effort than I can spare.
I basically only have time on weekends, and most of that ends up being recovery time before another 40-hour work week.
Reply 497 of 499, by holaplaneta
Regardless of this, I hope you will get better soon Matze. Thank you for being so generous.
Reply 498 of 499, by jal
I completely agree!
If anyone wants to try to make one themselves, and wants to make more than one, I'm still in the market to buy one.
Reply 499 of 499, by holaplaneta
jal wrote on 2026-05-27, 20:42:
Count me in too please.
