First post, by GeorgeMan
Hello forum!
I've consolidated my retro builds to just 3. The first one is a laptop for Windows XP so it doesn't matter for this thread. The remaining 2 are the following:
1. K6-3+ running at 400-450MHz max, with i430TX motherboard and an S3 Savage4 Pro with 8MB vram. I'll use this for early DOS to DirectDraw 9χ mid 90's games (upto 1996-1997). I'll take advantage of the CPU's plus features to slow it down. It'll also run WFW 3.11.
2. PIII-S 1133MHz with Matrox G450 and Voodoo II 12MB. This will solely be used under Windows 9x environment (98SE or Me) to cover late 90's stuff, directX 5-6 games, glide of course, and DOS-in-Windows box for the few games that are not running smoothly in the first build. No real DOS though.
So my question is, which of the title's cards should I use in each build? Will the Yamaha OPL3-Sax card have better early gaming compatibility or the ES1868F shines better in early stuff?
Or is it better even to use the most compatible for the older build, discard the remaining one and just go for an SB Live! for the Tualatin build?
I'll be using a Gravis Gamepad in gameport and 3com PCI ethernet to transfer files too, if that matters.
I know I can test them on my own, but I for sure can't test all obscure old games and for sure forum's knowledge is better than my own! 😁
Acer Helios Neo 16 | i7-13700HX | 64G DDR5 | RTX 4070M | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Win11 + Virtualization => Emudeck @consoles | pcem @DOS~Win95 | Virtualbox @Win98SE & softGPU | VMware @2K&XP | ΕΧΟDΟS
Reply 1 of 8, by badmojo
Both great options - the Audiodrive is better for earlier stuff IMO because it has heavier filtering than the YMF card, so it sounds better with the lower quality samples from older games, like the original Sound Blasters did. Also Duke Nukem 2 won't sound right on the YMF without a patch, if you care about that.
The filter on the YMF card can be modded to sound like a real SB Pro, and then it's the better card because it has a real OPL3. But yeah, either card is great.
Reply 2 of 8, by Linoleum
Owning both of these cards, the Yamaha is easily my favorite — especially once you manage to tame that mixer that only seems to cooperate through black magic.
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge, SB32, PicoGus
486DX4 100, CLGD5424, SB32
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA, Forte16
PS2 30/286, SBP
Reply 3 of 8, by badmojo
The OPLSAx initialisation / mixer software in DOS is a bit challenging - I ended up hex editing it to stop it from updating my autoexec.bat every dang boot. Unisound works with them of course but it doesn't set up the mixer properly either - Wolf3D doesn't have stereo for example.
Reply 4 of 8, by carlostex
Both are excellent.
I do prefer the YMF chipset, and in my case i actually do not enjoy the filtering so much. One thing that got me so passionate with this chipset is how clean it sounds. It has other surprises like its ability to play much higher sampling rates without issues, even though this is out of spec for real SB Pro 2 with 8-bit Stereo at 22KHz, it is a nice surprise when you bump the sampling up to 44KHz and there's no playback slowdown whatsoever. I remember Tiido mentioning it could go as high as 96Khz or something.
Both have good UART MPU-401, both have good joystick support, YMF might be harder to find in full ISA height to support a "normal" sized daughterboard, where its quite easier to find that for ESS cards.
ESS fully supports all ADPCM modes, but YMF only supports 4:1. ESS has a register compatible and excellent enhanced OPL3 that on some occasions does not sound equal to the real thing, but ESFM is genuinely good.
So it comes down to preference, i liked the way the YMF chipsets sound so much that i never looked back. The holy grail for YMF, until Tiido's card is out, is probably the MediaTrix AudioTrix 3D-XG. For ESS, my favorite card is the Guillemot Sound MAxi 64 with a ESS1868. The holy grail for it now is MK1869 xTreme by Keropi and Marmes.
Reply 5 of 8, by GeorgeMan
So it seems that compatibility-wise they are about the same, since no one mentioned anything about it.
I am planning to use UNISOUND, I'm sure there must be a way to adjust the mixer while initializing it with some switches. Isn't that the case?
I am not interested in Wavetable addons, so yes both cards are not full height but it doesn't really matter for me.
I just want a hassle-free plug'n'play experience for the most part and enjoy the games. I know this is not the case for DOS and a lot of different eras of software, but I want to make it as simple as it can be. 😀
I know (and hate) the CQM that replaced OPL by Creative, but honestly the ESFM is a good implementation, I don't mind using that instead of "being true and faithful".
About filtering, I guess I didn't notice it so much, maybe I need to try both cards one right after the other to listen to the differences.
Reply 6 of 8, by badmojo
GeorgeMan wrote on 2026-03-02, 11:01:
3 people replied, 2 mentioned a compatibility issue.
Reply 7 of 8, by GeorgeMan
Apologies about that, since English is not my primary language maybe I misunderstood something.
badmojo wrote on 2026-03-03, 03:21:
Reply 8 of 8, by appiah4
If you'll go for the YMF card definitely use Tiido's software for initializing and managing the mixer, the original Yamaha drivers are a total clusterfuck. I use one of these cards in my 486 system because I used to own an SB Pro back in the day, and in terms of features and sound that is the closest.
That said, the ESx688 cards are definitely my favorites among the ISA sound cards.
