Reply 58440 of 58452, by PD2JK
The attachment 20260306_141445163.JPG is no longer available
After years I found my unicorn, a Raptor X.
The attachment 20260306_142843958.JPG is no longer available
Oh noes. Would a regular WD1500ADFD donor board work? Otherwise I'm thinking of replacing only the chassis part, that would keep things more original.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 58441 of 58452, by Fazeshift
Nunoalex wrote on 2026-03-06, 00:22:
very nice !
my first cd-rom was a mitsumi double speed that came with its dedicated controller card
I still have it but haven't tested it in more than 30 years... I need to get that guy out
Mitsumi is the only early proprietary optical drive I have never owned tried.
I once again have a Sony drive and sound card with Sony interface. It is single speed, and the tray is not motorized - the eject button activates a solenoid, and with a "clunk" the tray springs partway open. Then you slide it the rest of the way open and push closed manually. I think a friend gave it to me in the mid-90's after upgrading. It ended up in a 486 I built out of used parts with the intention to sell. My grandmother bought it, because she wanted to learn computers and "surf the internet." She did learn, quickly. Within a couple years purchased herself a new HP with an AMD K6-2. And many other newer PC's. She passed about a year ago. The PC I built, and the HP, were given to me. I checked/removed clock batteries, but I haven't booted either yet. I still remember that Sony eject "clunk" sound - maybe it is time to power it up and hear it again.
I also had a pair of Hitachi drives, in external enclosures were branded "Todd" with 8-bit proprietary ISA interface card. They used CD caddys. They were originally part of an early CD-ROM encyclopedia system at my schools library. I saved them from the trash pile when I worked part-time for their IT admin. The drivers were very limited and slow.
giantenemycat wrote on 2026-03-06, 14:15:
This one is ok?
I think so - that looks like a standard 40-pin, but I cannot see the connector - just make sure no holes are blocked (keyed), since all 40 pins are populated on the drive connector.
Reply 58442 of 58452, by Big Pink
rasz_pl wrote on 2026-03-06, 08:03:
TheAbandonwareGuy wrote on 2026-03-06, 00:48:
EDIT: Who is the webmaster here these days? I get a 500 Internal Server Error every other time I post (the message always posts tho)
logged in: OpenAI [Bot], OpenAI Search [Bot], Claude [Bot], DataForSeo [Bot], Baidu [Spider], Bing [Bot], Google [Bot], ChatGPT [Bot], Common Crawl [Bot], PetalBot [Bot], facebook external [Bot], Qihoo 360 [Bot], Google Docs [Bot], TikTok [Spider]
welcome to dead internet theory
I experience the exact same here and on another forum which frequently complains about too many connections.
I thought IBM was born with the world
Reply 58444 of 58452, by TheAbandonwareGuy
thats where most VIA based motherboards belong in the first place :-) […]
Nunoalex wrote on 2026-03-05, 21:59:
I just found this motherboard in the trash
thats where most VIA based motherboards belong in the first place 😀
DFI CA64-TC (Canyon CN-6XBAS-T)
except this one actually
Can anyone explain to me why people are asking insane amount of money for it on ebay ? 200-300 euro
Yes it is a Tualatin motherboard
This makes it special, its the first VIA chipset that didnt suck and was ~on par with 440BX while officially supporting 133MHz, agp x4 and afaik also 512MB PC133 dimms. Plus you get fcpga socket so no mods/converters necessary.
concerning scratch on the south bridge bga
ripperoni, recycler ripped $0.05 worth of aluminum with a screwdriver destroying the chipset
Depending on where those chipset traces go, the board may still work without some functionality. Best case scenario it's something mostly useless like the parralel port or a single PCI slot will be dead or something.
Reply 58445 of 58452, by PcBytes
PD2JK wrote on 2026-03-06, 14:21:
After years I found my unicorn, a Raptor X. […]
Fixable if you have patience. Did that to a 250GB Samsung SP2504C drive that I ended up using in a OGXbox I sold. Desoldered the whole header pin by pin and used a donor PCB from a 160GB Spinpoint that died.
In your case you can probably harvest one from even a WD800JD or WD800JS since I think they use the same type of connectors.
Reply 58446 of 58452, by PD2JK
Good one mentioning these models, thanks, let's see what's in the donor-store here. Luckily, the disk is spinning and the actuator moves like a normal initialize operation.
Reply 58447 of 58452, by Robert B
Put a small piece of thin cardboard inside the SATA cable or under the pins so that they make contact well and use it as is.
OR
Break the missing plastic portion from a dead SATA HDD and use that to secure the pins inside the SATA Cable.
Reply 58448 of 58452, by PD2JK
That last option crossed my mind as well.😀
Thanks guys.
Reply 58449 of 58452, by TASOS
BetaC wrote on 2026-03-04, 01:54:
While it isn't the Athlon 1GHz, it is indeed a 1GHz Athlon. I can't complain too much about having an interesting CPU. It's one of the Thunderbird ones, so it probably even has some good OC overhead.
The attachment IMG_0892.jpg is no longer available
Very nice find !!
Reply 58450 of 58452, by PcBytes
A few more scores waiting for me 😀
- DFI Lanparty DK 790GX-M2RS - 150RON
- front panel SB Live! - 150RON
- ATI Radeon 9800XT - 250RON
- AMD Athlon XP 2600+ AXDA2600DKV4D - 45RON
- ASUS A8N - SLI Premium + Athlon 64 3000+ - 300RON
- AMD Opteron 170 - 420 RON
and a FX55 😀
Reply 58451 of 58452, by NeilKnows
A couple of CPU's off ebay...
Pentium III 1000/133
Duron 750
Reply 58452 of 58452, by RetroAddict
These are collective purchases over the last few days, but thought some might find them interesting!
The attachment 166 Project.jpeg is no longer available
First one is a 166 AMD K6, sat in a Gigabyte GA-586TX motherboard with 128mb memory. The hard drive is a brand I've never heard of before (Micropolis Mustang). The graphics card is a TSENG ET-6000 which I'll swap out for a S3 Virge DX potentially. Not sure what to do with this machine but it seems period correct for a dos / 98 machine?
The attachment AOPEN HX08.jpeg is no longer available
Second machine I purchased purely for the case in all honesty, has a 1000 MHz AMD Athlon in an asrock board with 1gb of DDR memory. Hard drive is functional in this one but it's not a brand I use (Seagate). I'm not sure what to do with this machine, it feels like a good sleeper case but I also had the slightly smaller version of this back in the early 2000s!
