First post, by TheAbandonwareGuy
OK, I'm about to bash my brains out trying to figure this out
I have a Pentium MMX 200 built on top of a Matsonic rebrand of the PCChips M547 running Windows 98 FE with 64MB of RAM.
I cannot get the USB bus to work correctly with USB mass storage devices. It will copy 30-50MB either way then throw a "cant access device" or "file not found/cannot be read" error depending on the direction of the transfer.
Is this a known issue with the Apollo VPX/97 chipset? I know VIA chipsets are generally not well regarded. I tried installing the Via 4-in-1 driver but that just bricked the OS (made Rundll32 start throwing illegal operations and access violations @ the desktop, and Windows to stop booting after a couple of reboots). I'm running the Sandisk Cruzer W95 USB driver.
I've tried the obvious (switching USB ports, a different USB drive, etc)
Reply 1 of 1, by shevalier
I had exactly the same problem with MVP3BS7-954 - after 10 seconds of active work with a USB flash drive, file copying stops.
Everything was resolved after replacing the electrolytic capacitors near the USB, PS/2, and other I/O ports.
There were small capacitors, for example, 22-47 μF, whose capacity was strange even in those distant times.
A polymer capacitor rated at 470-560 μF and 6.3 V will fit perfectly in this mounting location.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
