First post, by Doombringer4u2nv
These speakers are an important part of my DOS gaming PC as I had them since new. I dug them out recently for my first retro dos build.
Anyway, I lost the DIN cable that connects the the two satellite speakers. I bought a generic DIN cable (same pin pattern) and the wiring must be different. I do not get sound on the lower speakers on the "slave" satellite.
No way to take the speaker apart as it must be glued or something. I took all the screws out and it is NOT coming apart without breaking it. Its a long shot but does anyone know how the DIN cable is suppose to be wired?
I suppose i can just run jumper wires from one DIN to the other DIN until it starts working to figure it out but not sure if that can damage something sticking wires in the wrong DIN "holes".
Not electronically education but I also thought about poking around with a volt meter on the DIN supplying signal to the "slave" speaker but again not sure if I can blow something doing that. Any thoughts would be great.
JD
ABIT BH-6, Pentium III 500, 256 mb RAM, Nvidia MX420 Video Card,SB16 CT1770 SCSI, GUS David Larsson Clone, SCSI ZIP 100mb, SCSI TEAC CDROM, IDE Hitachi CDROM, IDE LS-120 Drive, 3.5 Floppy, Viewsonic PF790 Monitor (DOS6.22, Win98 SE)
Reply 1 of 15, by dominusprog
Find the ground pin and go from there. For example, if pin 2 is ground on both speakers, you'll have to connect the pin 1 to pin 1 and so on.
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 15, by JidaiGeki
I took apart some ACS450 speakers in Feb 24. They do have glue around the entire assembly, so I got it apart using a plastic spudger. It took a while as I had to go carefully.
The ACS500 is different to the 450 as it has Pro-Logic I think? Anyway, you can probably go pin-to-pin on those speaker connections as the wiring is unlikely to be complicated. I didn’t get photos of the DIN plug circuit but I do have a pic of the 450’s internal connector and wiring. To be 100% sure you will need to crack yours open though. Keep us posted, there isn’t much info out there on these speakers.
The attachment IMG_0107.jpeg is no longer available
The attachment IMG_0109.jpeg is no longer available
The attachment IMG_0097.jpeg is no longer available
The attachment IMG_0098.jpeg is no longer available
The attachment IMG_0099.jpeg is no longer available
Reply 3 of 15, by Doombringer4u2nv
Thank you for the pics. I know now I will not be dealing with any plastic clips. Looks like the "platforms" are what glued and holding it together.
JD
Reply 4 of 15, by Doombringer4u2nv
I I was able to get it apart. Unfortunately I broke the power pcb with the pry tool. I am posting a pic to show others that if you use a pry tool go up at least 2 inches from the base of the speakers to avoid doing what I did. It looks like the trace that I broke is a ground trace and I will just solder a jumper wire over the break.
The Dolby board is huge. I now know what two DIN pins go the the "lower" center speakers on the satellite . I will rewire my DIN wire and see what happens. Will post when I get it working or either blow it up . 🤣.
Reply 5 of 15, by tehdrewsus
Hello! First time posting... This thread in particular brought me here.
I just purchased a set of ACS500's with the ACS250 sub. they're... functional. But they're WAY more "used" condition than the seller let on, and although it doesn't blow me away, I can definitely smell tobacco/tar built up. I may make a restoration thread. Upon getting into them one of the wires is broken, which is odd to me. Is there a good way of getting the separator flaps out?
Reply 6 of 15, by Doombringer4u2nv
tehdrewsus wrote on 2025-01-15, 18:51:
The rear part of the "flaps" was glued with silicone. The front part looks like they used epoxy so no way of removing the entire flap but no need too anyway really.
Reply 7 of 15, by Doombringer4u2nv
Could you please put a ohm meter on both ends of the DIN cable and tell me what pins are what? Like is pin 1 on one side pin 1 on the other side and so forth. A standard MIDI DIN cable will no work with these speakers and I think they crossed a wire in the cable or something.
Reply 8 of 15, by tehdrewsus
Doombringer4u2nv wrote on 2025-01-18, 14:09:
After 25+ years, they came apart without too much of a fuss. I removed them so I could remove the speakers without cutting wires and having to re solder. on to more testing though. these don't work near as well as the seller let on... go figure.
Reply 9 of 15, by JidaiGeki
For what it's worth, I've tested the ACS450 speaker cable and it's wired straight through. While it's not impossible, I wonder if A-L would have created a special cable for the ACS500, given these were a mass produced speaker with common parts to the ACS400 and other sets. Certainly none of the pictured speaker interconnect cables in ACS500 sold listings have special markings. Hopefully tehdrewsus has a multimeter!
Reply 10 of 15, by Doombringer4u2nv
To finish the post. The DIN cable is pin to pin on the ACS 500. No crossover wires. The aftermarket replacement cable I was sent did have a cross as why it didn't work. I was sent the wrong cable and it cause the frustration.
Reply 11 of 15, by nali
dominusprog wrote on 2025-01-05, 05:32:
I know it's an old topic, but be careful with this.
Many amplifier are in a "bridge" configuration.
This mean the speaker is connected to 2 active pins of the amplifier component, out of phase 180 °C. Not between one active pin (via a capacitor) and the ground.
I've been playing with electronic for about 30 years, and I don't know any other way to identify pins other than opening the device and check inside.
IIRC, for some triphonic system like the ACS45-2, there's a 4 amplifiers component. 2 output are bridged for the bass, and 2 are used via a capacitor for the satellites. But it's something you can't guess, you have to open it and check.
Reply 12 of 15, by mercy
Anybody knows, why the left side sound in stereo mode is very muffled on these and starts to play the sound with a quiet drum tap in the beginning of the sample in windows 11 sound test?
Its like a fast radio crackle lasting for half a second always. It is audible on all the speakers in both L R towers. Always right at the beginning. Sounds like a recorded audio of a lame "drum sample" muffled, crackling once at begin. Did I mess up the cabling?
I'm trying to turn the CENTER to the left and all I get is a weak sound on the left always, but the right is super strong.
Win11 sound test:
Volume 48.
Left channel 48
Right channel 48
1. When I turn CENTER entirely to the RIGHT the crackling "left side" muffle sounds at the center.
2. Turning CENTER all the way to the LEFT, the test sound plays way outside to the RIGHT
3. When I turn the SURROUND knob entirely to the LEFT, then the stereo_LEFT test sound does NOT crackle anymore, but is super low volume. And the stereo Right sound test is normally loud.
4. Turning the CENTER knob all the way to the RIGHT the low-volume crackling sound returns.
5. Both speaker towers are working tho.. when I listen to music. Both towers appear to be quite loud and the voice remains more or less in the center. 🙁
SSI Gold Box-style game, we are working on
Reply 13 of 15, by mercy
Jesus, it still works! Just the volume potmeter is dirty. Adjusting the volume I pushed the volume knob weakly and and yanked it in some directions and now the full stereo sound is back. Like its sensitive because of 27 years of dirt on it, but it still works full stereo! WOW!!!
Reply 14 of 15, by mercy
Jeez its so strange hearing full stereo in movies after so many years of that potmeter getting dirty and becoming
15%left---85%RiGHT "skewed surround--mono".
Now its back to full stereo. I don't need the stupid surround, its just scares me. Stereo is perfectly OK! 😁 😁 😁
Reply 15 of 15, by NeoG_
mercy wrote on 2026-03-11, 21:39:
Jeez its so strange hearing full stereo in movies after so many years of that potmeter getting dirty and becoming 15%left---85% […]
I would recommend spraying some contact cleaner into the potentiometers and reflowing the pot/switch pcb connections if you have that capability, otherwise the issue might come back pretty soon
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
