Solid blue VGA output
First post, by mwiik
I just acquired a Tseng Labs ET4000/W32 PCI card to use in a Socket 5 build. While waiting for delivery of the Socket 5 board I wanted to test the card, so I popped it into a P3 build from 1999. The monitor (~15 year old BenQ LCD with VGA input) shows only a solid blue color when connected to the ET4000. Same result with a Dell monitor of similar age. The P3 machine has an AGP slot, but setting the BIOS to prioritize PCI video cards (and removing the AGP card) didn't help. The P3 machine works fine with an AGP card.
The seller states that the card is working. Is this a compatibility issue? I don't have a CRT monitor or any older PCI equipped machine to test with yet. The card is from 1994, so it's "only" 5 years older than the P3 machine I tested on.
What else can I try while I await delivery of the Socket 5 board? It would be nice to have a confirmed working video card when it arrives.
Reply 1 of 4, by jmarsh
Were the monitors set to VGA input?
Reply 3 of 4, by mwiik
I got it working... kind of. Not sure if disabling VGA BIOS caching or moving the card to a third PCI slot did the trick, but now it POSTs. I installed drivers for it in Windows 98 with both the ET4000 and the AGP card installed, and when I removed the AGP card I got to the Windows 98 splash screen, and then it hanged with a black screen. Rebooting into safe mode went a bit further with a grey desktop background on the upper half of the screen before hanging.
At least the card it working, but maybe it doesn't play well with Windows 98? I'll test it further when I get the Socket 5 board.
This thread can be closed unless someone has any insights to share.
Reply 4 of 4, by st31276a
I would be worried.
Safe mode uses the standard VGA framebuffer driver in 640x480x16, no reason at all it should hang there while working 'fine'
Hope it works better in the socket 5...
