Returned to repairing the Roland SC-55 I had on my bench a few weeks ago. This was the unit with the faulty resistors on the rear MIDI input.
The resistors are in a really awkward location right next to the giant plastic MIDI ports. I didn't want to use hot air or a regular soldering iron to try to remove them.
The attachment Roland SC-55 unit 1 resistors before removal.jpg is no longer available
I'd been waiting on getting tips for my new soldering tweezers. After several weeks on backorder, they finally arrived.
The attachment Hakko FX-9705 tweezers.jpg is no longer available
Using these soldering tweezers for SMD removal is a dream. The two resistors came off with virtually no effort and no risk of damage to adjacent components. Pads cleaned up well too.
The attachment Roland SC-55 unit 1 resistors removed.jpg is no longer available
Soldered the new resistors in place and did the MIDI input test. It finally passed. Did some subsequent listening via the rear input and everything seems to be working fine.
I still need to replace the tactile switches on the front panel, but I'll save that for another day.
The attachment Roland SC-55 unit 1 replacement resistors.jpg is no longer available
The attachment Roland SC-55 unit 1 MIDI test ok.jpg is no longer available
