HIDman - USB to PS/2 converter (Open Source)
Reply 580 of 601, by rasteri
TgamesFR wrote on 2026-01-08, 14:51:
Does it means that mouse not detected on a reboot is fixed too ?
No, I'm looking at that now. Took me a while to find a PC that did it!
Also will be great to support gamepad buttons reconfiguration, sadly many games not allow changing keys.
If we could for each buttons choose the corresponding keys it will be great.
Not too many people use gamepads so it's always been low priority in my mind. But I'd really like to get that feature added too.
Reply 581 of 601, by TgamesFR
Normally i prefer using keyboard only too but some games have very weirds keybinds like Batman Forever (the 2D game not the arcade one) who using numpad buttons from keyboard only and cannot be changed.
So for thoses games only a gamepad will be a game changer.
Reply 582 of 601, by rasteri
Turns out hidman gets confused if you move the mouse while rebooting. Should be an easy-enough fix but as a workaround in the meantime just make sure to avoid nudging the mouse while rebooting 😀
Reply 583 of 601, by TgamesFR
rasteri wrote on 2026-01-09, 13:15:
Btw i've reverted back to v1.1.6, i had some issues still with the 1.1.7beta :
- Caps Lock still not goes from uppercase to lowercase, only uppercase (once pressed it's always in uppercase and not setting back to lowercase). Only pressing shift put it back to lowercase.
- Media Keys still not working (none of them, tested wheel, play, stop, previous and next) on my Logitech G910 under Windows 98.
- None of the keyboard LED react but i've saw it's a known new bug added and it's shown on github
- I have the keyboard who now no longuer responds if the mouse is also not responding (was not the case before with 1.1.6).
I've also compiled your lastest commit "Hopefully fixed mouse reset issue" but no changes for mouse reboot issue on my side.
Reply 584 of 601, by mbandalauk
Hi - is the CH559T one-time-programmable? I built a Hidman-micro and worked fine, then I blew it up when connecting it to an industrial PC. I replaced the CH559T on the tiny PCB and the software detected it fine but failed to program it. Now it does not matter what I do, the Hidman-micro is no longer detected by the software. I think it bricked, this is the version with the push button to force the CH559T into firmware update, but that does not work either. Any suggestions?
Reply 585 of 601, by rasteri
mbandalauk wrote on 2026-02-25, 16:29:
What binary did you program to it? hidman micro isn't supported by the default binaries
Reply 586 of 601, by Shreddoc
rasteri wrote on 2026-01-08, 15:07:
I'm really looking forward to being able to set HID gamepad controls to specific keys. Among the small geek communities I'm active at, discussion about using gamepads in DOS has been growing recently, but the legacy options are few.
Reply 587 of 601, by InsertDisk
I recently got a HIDman and am using it in a setup with an ATEN CS1784A (DVI + USB KVM). It wasn’t entirely straightforward to make it work (beacuse of the KVM I guess), so here’s what worked for me in case it helps someone using a similar KVM switch (HIDman firmware 1.1.6):
First, I connected everything without changing anything. It didn’t work. I then tried an older, simpler USB keyboard, still no luck.
The KVM has an emulation layer for keyboard and mouse when they are connected to the dedicated console ports (to support hotkeys for switching between machines). In addition, it has two “regular” USB ports. I tried connecting only the keyboard to one of the regular USB ports on the KVM (not the dedicated keyboard port). Suddenly, the keyboard worked. However, as soon as I plugged the mouse into the second regular USB port, neither the mouse nor keyboard worked again.
There is a BIOS option on the Pentium system under boot settings, Turbo or Deturbo for the boot process. It was set to Turbo. After switching it to Deturbo, both keyboard and mouse started working reliably through the KVM. POST and boot now take longer, but this seems to give HIDman enough time to initialize properly.
Now I tried the modern keyboard again, a Ducky One 3, but changed the setting in HIDman to advanced keyboard. This time it worked together with the mouse when connected directly into HIDman, but only keyboard worked when connected through the KVM.
I also tested firmware v1.1.7beta1, because of its improved hub support, but that made the setup not work anymore (also for the older keyboard together with the mouse that had worked before). Reverting back to 1.1.6 restored the previous working state for the old keyboard + mouse.
Any suggestions for getting the Ducky keyboard + mouse combination to work with HIDman through the KVM? Combination older usb keyboard + same mouse works..
Reply 588 of 601, by zuldan
InsertDisk wrote on 2026-02-27, 13:56:
I recently got a HIDman and am using it in a setup with an ATEN CS1784A (DVI + USB KVM). It wasn’t entirely straightforward to m […]
That’s interesting information. I’m using a very similar KVM and a ducky keyboard. I could not get my setup working at all. Will look at your points.
Maybe if you post a log the developer might be able to help.
See Re: HIDman - USB to PS/2 converter (Open Source)
Reply 589 of 601, by mbandalauk
rasteri wrote on 2026-02-25, 19:54:
I meant that I am using the HIDman-mini by Serisman, so I downloaded the binaries from his GitHub. I built one, and it worked well until I blew it up on an industrial half-size PCISA card. Those boards have a combined keyboard/mouse connector that is not standard, and it burned my HIDman-mini. I know I damaged it because I was using it with my WeeCee, and eventually only the mouse worked while the keyboard stopped working.
My problem is that I have replaced the CH559T chip twice, and both failed to be programmed. One was not detected at all, and the other was detected but failed during programming and apparently became bricked. The HIDman-mini has a push button to force it into fw update but that does not work either.
My original CH559T (the one that worked) was sourced from UTsource, but they do not carry them anymore. I bought some from AliExpress instead; perhaps they are counterfeit, as they seem to be completely unusable.
Reply 590 of 601, by InsertDisk
I think it should be able to work, as I was playing around with settings and set the mouse to advanced as well and after a reboot both mouse and keyboard (ducky) was working through the KVM. But only once. I have not been able to replicate the result.
Another thing I've noticed: when connecting both mouse and the ducky keyboard directly to the HIDman, the keyboard have to be in the upper USB-port on the HIDman. Otherwise it will not work.
I have attached a log from HIDman where both the ducky keyboard and the mouse is connected to the KVM, and I pulled out and reinserted the USB cable into the HIDman.
Reply 591 of 601, by mbandalauk
Would it be possible to provide compiled binaries for HIDman-mini and HIDman-micro in future releases?
Reply 592 of 601, by InsertDisk
zuldan wrote on 2026-02-27, 20:19:
Using the deturbo option slows down the entire machine, and that’s too big of a trade-off just to have both the mouse and keyboard working.
So for now, I'm using the keyboard through the KVM (in a non-console USB port) and HIDman, and I just have a separate mouse for the computer that requires PS/2. I’ll test future firmware versions to see if that improves compatibility.
@rasteri: I posted a log in a previous post, hopefully that can give some clues as to what’s going on. If there’s anything else I should test or log (or if the way I tested was incorrect), just let me know.
Reply 593 of 601, by myne
My wild guess is clock drift.
The oscillator on that board is far enough out of spec that it can't compensate.
I built:
Reply 594 of 601, by rasteri
InsertDisk wrote on 2026-03-01, 08:56:
Looks like hidman is parsing the keyboard report descriptor incorrectly. I'll have a look.
Reply 595 of 601, by rasteri
mbandalauk wrote on 2026-02-28, 21:29:
I'm reluctant to, because I don't own any mini or micro boards so I can't test the releases. Also those boards didn't have oscillators so they don't work with a lot of devices.
Reply 596 of 601, by DJNW
Shreddoc wrote on 2026-02-25, 20:19:
One of these days, I'll get off my bum and bash out a circuit with a Pi Pico that'll use a couple of digipots, some transistors and whatnot to take input from a USB gamepad and spit out the right signals for a DB15 analogue joystick.
Mabye even leave out the digipots and just implement a software-controlled version of the DB15 gamepad I've got - I've got pictures of both sides of its the board, so I could steal most of the circuit from there.
Reply 597 of 601, by weedeewee
DJNW wrote on 2026-03-14, 23:06:
2 to 4 DAC outputs and 2 to 4 open-collector/open drain outputs should do it, I think.
Do not ask Why !
Reply 598 of 601, by KVM Nerd
If you are just looking for HID gamepad to HID keyboard and/or mouse, you could hook a HID Remapper in front of the HIDman. No idea if both devices work together smoothly, I could test it if there is interest.
Why not hook it up to a KVM switch?
Reply 599 of 601, by TgamesFR
KVM Nerd wrote on 2026-03-15, 06:50:
Interested that you test it.
Can you test on Batman Forever (DOS Version) ? (Not the Arcade one, the 2D style like Mortal Kombat).
This game have hardcoded controls using numpad only, who is a pain to play using the keyboard (it's litterally unplayable to do movesets)
And sadly as the USB controller is not remappable i can't use it either.
There is others games who have weird hardcoded controls under DOS with same problems.
