First post, by ChrisK
So I have this board https://theretroweb.com/motherboards/s/gigaby … ga-586atx-rev-3.
It mentions some Auto Voltage function for the CPU.
Does anyone know how this is supposed to work?
The reason for asking is that this never seems to work.
For example, putting in a plain Pentium 133 it doesn't matter how any of the four voltage DIP switches are set, it always get's 3.5V or 3.17V (measured with multimeter).
With 3.5V it boots and in the POST screen as well as in the BIOS the 3.5V are shown. At 3.17V it doesn't boot. I'd have to have a look again but IIRC DIP switch #7 makes the only difference.
I didn't risk to install any other CPU yet.
Wondering about this behavior I had a look at the voltage regulator and it's surroundings and the following came up:
The voltage regulator is a HIP6008 which can be seen on the last picture in theretroweb just above the blue DIP switch box.
It has four VID inputs which are controlled by four DIP switches. The DIP switches pull those VID pins either to GND or leave them floating.
Then there are three additional transistors mounted between the HIP6008 and the DIP switches. They are connected to the VID0..2 inputs of HIP6008. VID3 has no additional transistor connected. There are no other connections to these pins.
My thinking was that these transistors can be controlled by any other means on the board and set the CPUs voltage according to its type when the DIP switches are set to the AUTO setting (which is OFF-OFF-OFF-ON).
BUT: all three gates/bases (don't know if they are FETs or bipolars but doesn't matter) are visibly connected together and driven by some 12V signal.
That means they are always active and pulling VID0..2 to GND.
How does that make sense?
Unfortunately the area is very densely populated with caps so I couldn't find out yet where the driving signal comes from.
But being 12V I doubt it's coming from the CPU directly. But even if so it isn't really plausible to me.
I'm thinking about just removing those three transistors and setting the CPU voltage completely manually.
Will this work? What's your opinion?
RetroPC: K6-III+/400ATZ @6x83@1.7V / CT-5SIM / 2x 64M SDR / 40G HDD / RIVA TNT / V2 SLI / CT4520
ModernPC: Phenom II 910e @ 3GHz / ALiveDual-eSATA2 / 4x 2GB DDR-II / 512G SSD / 750G HDD / RX470
