First post, by lilylarceny
Okay, this has been the one major problem with my windows xp build. I have an X-Fi Titanium Fatal1ty and I am pretty sure that my GPU is conflicting with it, it's a reference evga 980ti. I have the GPU "HD Audio device" disabled in the device manager. I have Daniel K's most recent custom driver for the X-Fi. The Creative Labs software is set to "Game Mode" and EAX is on.
With in-game settings enabling EAX:
Sometimes I can play my entire gaming session without a problem. Sometimes my games play normally at first, and then after a little while some part or all of the audio will crack, pop and stutter, or get out of sync with the game. Other times the audio will be bad from the start, and I have to reboot the computer. This problem is usually resolved at least temporarily by rebooting.
If I set the game audio settings to "software" everything just works, but no EAX features.
Everything else seems to work great and exactly the way I want it to.
I have found quite a few people complaining of the same problem with the X-Fi and I have tried a lot of things they suggested. I think it might be time to consider a different sound card. The main reason I built this computer is EAX 3, 4, 5 hardware support tho, so I'm not sure where to go from here. If anyone has any recommendations, I'm all ears.
Current Specs:
Z97 chipset/Gigabyte G1 sniper motherboard
Intel I7 4790k CPU
16gb DDR3 ram
GTX 980ti
Win XP sp3 Integral Edition + PAE patch
Reply 1 of 15, by Joseph_Joestar
From my experience, X-Fi Titanium cards work better when using older drivers under WinXP. See my guide for more details. Be sure to also install EAX Unified and OpenAL as instructed there.
Additionally, there are some reports that EAX can break under WinXP if the system can access more than 4GB RAM. I have 16GB on my machine and I haven't experienced that, but I don't use the PAE patch, so WinXP only sees 4GB .
My retro stuff
Reply 2 of 15, by lilylarceny
Joseph_Joestar wrote on 2026-03-07, 20:05:
I will have a look at this and try, but I have attempted a lot of other recommendations.
The vram and system ram both count toward the 4GB limit. Without the PAE patch, video intensive games crash constantly and behave as one would expect with running out of vram. After installing the PAE patch I don't have any more problems with vram limits or game crashing.
Reply 3 of 15, by Joseph_Joestar
lilylarceny wrote on 2026-03-07, 20:40:
Out of curiosity, which games specifically caused those crashed for you? I had a 980Ti in one of my XP rigs and never saw anything like that.
That said, the most demanding games that I ran under WinXP were Crysis and BioShock, which both worked fine. I also played Mirror's Edge and Risen there, which are a bit newer, but they don't really need a super powerful GPU. Haven't really dabbled with anything released after 2009, other than a very brief test of Risen 2.
My retro stuff
Reply 4 of 15, by TheIpex
Is your CPU running at stock clocks?
My Haswell system won't play nice with X-Fi cards if the CPU is clocked above 4.6ghz (Despite being stable by every other metric).
Intel 486DX2 66MHz
Intel Pentium MMX 233MHz
Intel Pentium III-S 1400MHz
Reply 5 of 15, by agent_x007
ASUS Xonar stuff can emulate EAX 5.0, but not sure if WinXP driver for it is fine with that (since I use those usually in Vista+ OS).
Reply 6 of 15, by ott
Can you suggest which games and settings to use to reproduce the bug?
Since you have PCI slots on G1.Sniper Z97 motherboard, I'd like to recommend the original X-Fi Fatal1ty (SB0460) but I'm not sure if it will have same issues with PAE patch.
Reply 7 of 15, by shevalier
lilylarceny wrote on 2026-03-07, 19:53:
If I'm not mistaken, these boards came with an activation key for the ‘X-FI for motherboards’ software.
It's a kind of software wrapper for the built-in sound codec with X-Fi functions.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 8 of 15, by lilylarceny
Joseph_Joestar wrote on 2026-03-07, 21:01:
ott wrote on 2026-03-08, 04:02:
This happened consistently with Fallout New Vegas (2010 but system requirements were WinXP). I used max/ultra settings. I tried resolutions between 800x600 and 1920x1440. It did not have any sound problems, but the game didn't use EAX at all.
Upon using the PAE patch to 64gb the game just runs fine. Most of my games run great now, just the inconsistent sound issue. I do frequently have to download official patches and updates to get games working, but that's how it always was in the 98/xp era.
I could certainly try that, however I would prefer a PCIe card. My GPU is currently mounted vertically and it blocks off most the expansion slots except for the first PCIe 1x slot that the X-Fi is in.
TheIpex wrote on 2026-03-07, 22:29:
It's only running at 4.0ghz, which is more than capable, so I don't see a need to push it. I would like this system to last a long time.
shevalier wrote on 2026-03-08, 09:40:
The on-board sound is Creative Sound Core3D, which does not have windows xp drivers. I have it disabled in the bios. I'm not sure what you're referring to beyond that.
Reply 9 of 15, by Joseph_Joestar
lilylarceny wrote on 2026-03-08, 14:38:
I only have New Vegas on Steam, so I can't test it under WinXP. However, I do have Fallout 3 on GOG, and I did install it under WinXP a few months ago to check something. Granted, I didn't play for very long, maybe 15 minutes tops, but all my settings were fully maxed out at 1920x1200 and the game ran fine.
BTW, Fallout 3 doesn't use EAX, only DirectSound3D. I just checked New Vegas and it's the same there.
My retro stuff
Reply 10 of 15, by lilylarceny
Joseph_Joestar wrote on 2026-03-08, 14:52:
Yes, I am aware. I believe I mentioned that above. I do not have a problem with Fallout NV now at all. Only with EAX games.
Reply 11 of 15, by LSS10999
I will have a look at this and try, but I have attempted a lot of other recommendations. […]
IIRC there was a thread regarding EAX with more than 4GB RAM but that was about WinXP x64. So it might be that for some games EAX may not work correctly if the system has available RAM above 4GB boundary, regardless of the environment being x86-PAE or x64.
From my experience with PAE-patched WinXP (most likely 2003 x86 also), however, avoid using the card's MIDI (soundfont) synth in such environments. The system may BSOD during MIDI playback. Sound playback (without any MIDI operation) works without issues, however.
Regarding PAE, however, Audigy series with kX driver seems to be free from most if not all BSOD risks. It's said that kX offers only limited EAX support, however.
agent_x007 wrote on 2026-03-08, 01:25:
You can't really install ASUS Xonar drivers on PAE-enabled WinXP as well as Win2003 x86. The driver will BSOD outright on startup during install process, if you have available RAM above 4GB boundary.
Reply 12 of 15, by Dimos
You shouldn't need to have the PAE patch installed to run any game on Win Xp really. I have a setup almost identical to yours and run every game imaginable on XP x86 without PAE problem free at max settings, including exotic anti aliasing settings implemented through Nvidia Profile Inspector. Fallout 3 is one of them, also Metro 2033 which is incredibly demanding as far as Windows Xp games can be.
Cpu: Intel i7 4790k
Gpu: Gigabyte Xtreme Gaming 980 ti
Ram: G-Skill Trident X F3-2400C10Q-16GTD
Mobo: Gigabyte Z97x Gaming 5
Hdd: T-Force Vulcan Z 512 gb Ssd
Psu: Corsair CX650
Soundcard: Creative SB Audigy RX
Os: Windows XP Sp3 x86
Reply 13 of 15, by LSS10999
Dimos wrote on 2026-03-19, 18:21:
Technically this is not specific to WinXP PAE patch. If the game/driver is misbehaving in PAE-patched WinXP, the same problem will happen on Win2003 x86 as well. The latter has PAE enabled by default and never had the bugs introduced by MS that made them artificially disable PAE on WinXP since SP2 in the first place.
The thread I mentioned, however, was about WinXP x64 which is the same base as Win2003 x64. Some issues in certain games manifest simply when you have memory above 4GB boundary, regardless of architecture.
Reply 14 of 15, by Dimos
I understand what you said. I simply state that op shouldn't need to have Pae enabled in order to not have games crashing as he stated. Something else must be the culprit. Also vram does not have anything to do with the 4gb available address space of x86 systems and the reason of the games crashes is definitely not that they run out of available vram because of the 4gb address space limit.
Cpu: Intel i7 4790k
Psu: Corsair CX650
Reply 15 of 15, by LSS10999
Dimos wrote on 2026-03-20, 02:54:
Come to think of it. After reading the OP's detailed system specs I think PAE might actually be the problem.
On a X99 system of mine I also used X-Fi Titanium Fatal1ty on XP Integral Edition with PAE patch enabled via Patch Integrator. That system has 64GB RAM available for XP and I'm getting BSODs particularly with games that use MIDI for music. I haven't tried games that OP played, but in other places where MIDI isn't involved the card is working fine, without any stutter nor BSOD.
Creative's drivers aren't PAE-friendly compared to kX, though still better than C-Media (which BSODs outright). I've since replaced the X-Fi Titanium on that system with a PCIe Audigy (0090) clone using the kX driver. Works okay for now (both sound and MIDI), despite lack of proper EAX. The card has one minor issue on WinXP, though, that the card seems to enter a "sleep" state when idle, and will hang about a second to "wake up" before playing sound. The card will work without any stutter if it remains awake, and will go back to "sleep" again if no sound is being played for a few seconds (MIDI doesn't count). The issue can be worked around, by looping an empty (silent) WAV file in the background. This way the card will remain awake and will not go to "sleep".
Perhaps something to do with my board's ACPI regarding WinXP, as I've another such clone installed on another H87-based system, and I don't recall encountering this behavior there (WinXPIE, PAE patch enabled, kX Driver). I'm not getting this issue on the same X99 system with Win7, either.
I think the best thing to do for the OP is to limit RAM to below 4GB boundary via /MAXMEM=4096. This excludes all memory above 4GB boundary which should hopefully fix most of the related misbehaviors. Due to memory hole, the actual usable RAM will be around 3-3.25GB as a result. On my X99 system, however, the memory hole is very huge -- I only have about 1.4GB of usable RAM below 4GB.
NOTE: Just limit RAM below 4GB, but do not try disabling PAE altogether. DEP (Data Execution Prevention) requires PAE to work, and you won't even be able to disable PAE if you have DEP turned on in System Properties (opt-in or opt-out), since DEP implies PAE.
