First post, by PacificState
I have two (cheap) socket 370 -> slot 1 slotkets which both have retaining arms raised above the level of the socket, and are fouling pretty much any heatsink I put on top. Is there a heatsink narrow enough to fit? Thanks!
The attachment IMG_7812@0.5x.jpg is no longer available
Reply 1 of 2, by shevalier
The highest-clocked Pentium 3-S draws a maximum of 35 watts.
That’s why heat pipe coolers hadn’t been invented yet.
Back then, they often used coolers like these, but they haven’t been made for ages.
https://www.frostytech.com/articles/707/index.html
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 2 of 2, by PC Hoarder Patrol
Would think most 50x50mm models should fit (not the best for cooling but readily avalable). For anything better / larger (60mm +) you'd need a model with a raised or shaped baseplate (improved cooling but much harder to source nowadays)...
The attachment skt coolers.jpg is no longer available
