Bleem!
First post, by 3dfx_fan
How well does Bleem! work for emulating PS1 games on Windows 9x/ME PC?
Reply 1 of 12, by leileilol
Not well. Bleeding textures off edges from the "better" bilinear filtering as all playstation textures are rendered from pages, and have had hardlocks. Stopped using Bleem! in 2000 and just left PSX emulation alone until pSX some 2006 later.
Macs apparently had it better with VGS in the day
Reply 2 of 12, by Zup
Bleem! is a piece of history, but it's an early emulator and have compatibility issues.
ePSXe is a better emulator but it uses plugins, so it is not as easy to configure. Go get ePSXe 1.5.0 if you want to play PSX games on Windows 9x.
(P.S.: I think ePSXe doesn't use plugins anymore, but older versions do)
I'm selling some stuff!
Reply 3 of 12, by DudeFace
its not great, i tried final fantasy 7 it worked for about 10 mins then i got graphical errors that covered most of the screen making the game unplayable, i also tried out an FPS game called disruptor, it was playable but did have some graphical errors until i changed some options, played a few levels and was pretty cool, its worth trying out just to see how games run on old hardware but i wouldn't actually use it for playing through a game.
epsexe is a better option, though in the 20years its been around ive never managed to get it to work right or look good no matter what plugins i use, there was also a couple of forks i think was called something like pcsx rearmed or reloaded, for me it just looked like the GUI had been updated but the emulation was just as poor as it was 20 years before. thank god for duckstation.
also as leileilol mentioned theres VGS (connectix virtual game station) originally for Mac, theres also a windows version, havent got round to trying it yet so not sure if its any good.
Reply 4 of 12, by NSX
I have completed GT1 and GT2 on Bleem, using Voodoo3 2000. It worked correctly, the picture was much better than on PS1.
Reply 5 of 12, by wbahnassi
I played quite a few games on VGS when it was available for PC. It was much better than bleem, but still not perfect.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 6 of 12, by twiz11
wbahnassi wrote on 2025-12-01, 20:10:
bleem and VGS, i mean the companies sacrificed themselves so we can get legal reverse engineering clean room emulation. Its barely the only thing holding on allowing dolphin and other emulators to exist
Reply 7 of 12, by butjer1010
Or You can buy PS1 these days for 15€....
Reply 8 of 12, by Shader_BiH
Bleem! was an important emulation chapter, still is, but it was never a good emulator. ePSXe is much better solution with high compatibility. With Pete's DX7 or OGL2 plugins you will have very good experience. He also includes documentation with those, so you can check how to set it up for your specific PC config. You also need a pack of PS bios files... they can be dumped from PS or.... found on the net 😁
Reply 9 of 12, by Geri
bleem was quckly overthrown by ADri psx.
Then adripsx was replaced by epsxe.
But you will have a hard time digging out the old opengl/glide/d3d/sound/input plugins from their graves to run the old versions of these emulators.
But dont worry, i still have them.
I still have my adripsx archive, which i used with my 350 mhz AMD K6/2 in 2002.
This version - if i remember well - required a 4 mbyte graphics card + 32 MB ram.
I collected all the plugins, and stored multiple versions of them, until i found the ones which were fine, and not stuttering on my computer.
Some of these plugins are made by russian and jugoslavian programmers, are long gone in history (just like Jugoslavia itself).
The emulator package is still operational. Please treat it with respect.
Start AdriILE.exe and enter enhanced mode to be able to choose the plugins.
It doesnt needs installation. Also it doesnt needs a bios file.
I abandoned using this when i got my 400 mhz Celeron in 2004 - which was already able to run epsxe well.
TitaniumGL the OpenGL to D3D wrapper:
http://users.atw.hu/titaniumgl/index.html
Reply 10 of 12, by Jo22
Shader_BiH wrote on 2025-12-11, 17:39:
Bleem.. Bleem! is ancient. It's old enough to be listed on CDV homepage, even!
Where I live, CDV Software was a big publisher of Shareware CD-ROMs in the 90s (next to ARI).
To many, it's probably better known as the publisher of Wet series.
Reply 11 of 12, by alex17pat
Man, seeing AdriPSX mentioned really brings back memories! I remember trying to get this running on a Celeron back in the day too. It’s wild how some of those obscure plugins from the early 2000s handled things - sometimes they worked better for specific games than the 'big' emulators did.
Reply 12 of 12, by Nitram78
Connectix was also the publisher of VirtualPC for Mac.
Any attempt to launch the Windows version of VGS within a VirtualPC instance would trigger an error message saying something like “I can't believe you actually tried that!”
