I am using scc-1’s MPU401 to talk to my MT32. Since I often run into Buffer overflow / Exc. checksum err situation I want to use softmpu purely as SysEx delayer.
When using softmpu /mpu:330 /delaysysex my mt32 correctly shows SoftMPU. But each sierra game will hang during start. The MT32 transmit light is working for some seconds and than rhythmically just blinks without the game starting.
Am I doing something wrong / do you know about any solutions for this behavior?
You're not doing anythng wrong. Which system are you using with the SCC-1?
On my Packard Bell Pack-Mate 28 Plus, I used SoftMPU for a bit before I wrote a program that turns off the cache for certain games (that are either speed sensitive for both the computer and Roland MT-32) and it'll turn on the cache once the game exits.
Here are the cache control programs that I use on my machine.
Cacheoff - turns off L1-L2 cache
Cacheon - turns on L1-L2 cache
The attachment cachecontrol.zip is no longer available
I also wrote a lot of Batch files and I have the following entered when I want to load a game:
SIERRA.BAT (example)
1@echo off 2echo Sierra On-Line games 3echo. 4@echo off 5echo [----------------------------------------] 6echo [ A - A10 C - TCBQ I - ICEMAN ] 7echo [ K - KQGAMES P - PQGAMES Q - SQGAMES ] 8echo [ S - SILPHEED X - EXIT ] 9echo [----------------------------------------] 10echo. 11@echo off 12echo Sierra On-Line: A10: Tank Killer, The Colonel's Bequest 13echo Codename: Iceman, King's Quest 1-6, 14echo Police Quest 1-3, Space Quest 1-3, Silpheed 15echo. 16@echo off 17choice /c:ACIKPQSX /T:X,15 "Which Sierra On-Line game would you like to play: " 18IF ERRORLEVEL 8 GOTO END 19IF ERRORLEVEL 7 GOTO SILPHEED 20IF ERRORLEVEL 6 GOTO SQGAMES 21IF ERRORLEVEL 5 GOTO PQGAMES 22IF ERRORLEVEL 4 GOTO KQGAMES 23IF ERRORLEVEL 3 GOTO ICEMAN 24IF ERRORLEVEL 2 GOTO TCBQ 25IF ERRORLEVEL 1 GOTO A10 26 27:A10 28call a10.bat 29goto end 30 31:TCBQ 32call tcbq.bat 33goto end 34 35:ICEMAN 36call icm.bat 37goto end 38 39:KQGAMES 40call kqgames.bat 41goto end 42 43:PQGAMES 44cacheoff 45call pqgames.bat 46goto end 47 48:SQGAMES 49cacheoff 50call sqgames.bat 51goto end 52 53:SILPHEED 54cacheoff 55call silpheed.bat 56goto end 57 58:END
I’m trying to use SoftMPU on my Windows 98 machine but I get an error telling me that the port trap failed. I am using QEMM 9.0. QEMM 7.5 caused SoftMPU to crash when launched, and EMM386 wasn’t detected by it. I am using port 330 for the MPU address, and my sound card is using IRQ 5 and Port 220.
My specs are as follows:
Pentium II 400Mhz
128MB RAM
Compaq 332857-001 Motherboard
Geforce 2 MX400 graphics card
Ensoniq ES1373 AudioPCI sound card
CarvisJockerwrote on Yesterday, 15:00:I’m trying to use SoftMPU on my Windows 98 machine but I get an error telling me that the port trap failed. I am using QEMM 9.0. […] Show full quote
Pentium II 400Mhz
128MB RAM
Can you "see" the MPU-401 MIDI port in DOS?
It's been a while but, I believe you require a DOS driver to enable the sound card under DOS.
As I recall, it was called Sbinit.* and EMM386.EXE must be loaded.
So is this usable with AWE64, as Aweutil doesn't emulate intelligent mode of MT-32 that some games require?
The purpose of SoftMPU is to emulate an intelligent mode MPU-401 MIDI interface using supported sound cards that has a UART mode MIDI interface (it does also support older sound cards that just had the standard MIDI out port but with reduced functionality).
So, by outputting the MIDI data via your MIDI/joystick port to an external device (like the MT-32) SoftMPU would then emulate the intelligent mode MPU-401 MIDI interface for those ganes that does require it.
Aweutil has a totally different function.
So you need a physical external device instead of being able to use the internal EMU8000 in AWE cards?
The internal EMU8000 is not a General MIDI device..
I know but with Aweutil it can be used as one. So I was wondering if it would be possible to emulate intelligent mode with SoftMPU and then output that to Aweutil, but apparently not.
No, as far as I know it can not, it does not even truly exist at a real MIDI port..
