Reply 1820 of 1834, by NeoG_
theelf wrote on 2026-04-14, 07:30:
Hi thanks fo reply!!, im in DOS, using for playback, quickview pro […]
polpo wrote on 2026-04-14, 00:02:
Are you in DOS? Windows?
- Picogus is in USB mode
- Video is a Cinepack 12fps, 320x200 video, tried ADPCM 22khz mono audio or PCM 8bit 11khz, interleave every frame. Video is 40min long, 560mb, then 230-250kb sec
- Tried too msvideo 1 256colors, 12fps, same audio options and interleave, 640mb more or less 270kb sec
- Tried iso and cue/bin
Bot videos i burn in CD and test in a 4x IDE drive and play fine, from HDD too
Using Picogus CD give me stops every 2 or 3 seconds because frameskip
NeoG_ wrote on 2026-04-13, 23:16:
Check your transfer speed from the virtual drive using something like speedsys, if it's running at full speed it should be able to get 3.5x with bin/cue images and 4.5x for ISO images. I had some settings in the BIOS like IO recovery period which was slowing down the virtual drive speed but still allowed the audio side to work fine.
Hi! i get consistent 600kb sec transfer rates in speedsys, and i can confirm by copy a file in DOS is correct
The attachment IMG_20260414_092524.jpg is no longer available
In fact my IDE 4x drive is slower, because i think i use CDRW unit and the unit is old, read at 360-420kb sec, but anyways video play smooth from real CD
I dont have a IO recovery period option in bios
thanks!
I wonder if the MKE cdrom has naturally higher CPU overhead and its running out of CPU power to copy from ISA bus and decode at the same time
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 1821 of 1834, by theelf
NeoG_ wrote on 2026-04-14, 08:04:
thanks!
I tested in a pentium 200 and videos are slow too using picogus
Funny thing is that msvideo1 avi play smoth from HDD in a 286 25mhz
Maybe is ISA bus that saturate?
The only videos i can play smoth using picogus CD is msvideo1 optimized for CDrom playback at 150k
Reply 1822 of 1834, by Kekkula
Hi and thanks again for the great work.
I was wondering if there are plans for upgrade path for 1.x card owners to upgrade their cards with pico 2?
Chips are pin compatible... I think.
:edit
I can also confirm that with 4.1 update usb mode no longer finds images from previously working usb card... on the other hand sb mode now works with images that 4.0 could not run 🤷‍♂️
Reply 1823 of 1834, by ubiq
I'm experiencing a different error with the 4.1.o update - GUS mode appears to be broken. When I "pgusinit /mode gus" it gives me:
ERROR: card is not alive after rebooting firmware
Trying pgusinit again confirms "ERROR: no PicoGUS detected!"
Rebooting brings it back alive in SB mode; switching to USB mode and back works; resetting back to /defaults doesn't help.
Reverting back to 4.0.0 brings GUS mode back to normal.
Reply 1824 of 1834, by Yoghoo
Can also confirm that Gus mode and cdlist are not working anymore with 4.1.0. Rolling back to 4.0.0 makes everything working again.
Reply 1825 of 1834, by polpo
I’ve pulled the v4.1.0 release. Sorry about the disruption. Serves me right for doing a release without my usual testing from the final release artifacts.
creator of PicoGUS and PicoIDE
Reply 1826 of 1834, by ubiq
All good m8! Thrilled that you're continuing to support and develop the project well past what anyone could have expected. 🙂
Reply 1827 of 1834, by theelf
polpo wrote on 2026-04-14, 17:46:
well i think everybody here all we are happy to help being beta testers!! thanks for your work
Reply 1828 of 1834, by rasz_pl
Releasing BETA firmwares clearly labeled "just for testing" might not be such a bad idea to lighten your workload Polpo. Or building some test automation suit to run thru all scenarios on real hardware without need of a human.
Reply 1829 of 1834, by Qbccd
Could someone please recommend a USB hub to use the mouse and CD-ROM emulation simultaneously? Would any powered USB 2.0 hub work? And there is no additional setup needed with the hub?
It would be amazing if a future version of PicoGUS had dual USB ports. The dual emulation of USB mouse and CD-ROM for $50 is really amazing value.
Reply 1830 of 1834, by vutt
Can community contribute to regression testing before release?
Also I was thinking about auto testing. It would be possible to write script and run scenarios automatically with reboots a la memmaker or QEMM memory optimisation sequence. I'm into LLM use case scenarios these days so I'm thinking about running trough automated scripts/boots with sound samples playback and clear text printouts on screen while recording screen on phone (or capture card). Then I would define prompt. Feed recording and reference sound samples into LLM. Only manual action might be required with freezes when manual power cycle is required. hm...
...and perhaps all this could be set up for Github Actions on commit... ...ok I should hold my horses here 😉
Reply 1831 of 1834, by rasz_pl
vutt wrote on Yesterday, 14:50:
All of these can be accomplished with normal diff. You dont need LLM to compare two files.
Github Actions
the problem is testing code running on real hardware
Reply 1832 of 1834, by nevergrownup
Has anyone successfully setup PicoGUS in SB16 mode under Windows 3.1? If so, what driver did you use?
Reply 1833 of 1834, by LSS10999
nevergrownup wrote on Today, 01:30:
I think you can probably get away with Windows 3.1's built-in SB1.5 drivers. It may not offer support for playing audio of higher quality but everything essential (sound, MIDI, FM) should work fine, and this driver also works in Standard Mode if you can't use 386 Enhanced Mode for whatever reasons.
AFAIK there's no easy way to install Creative SB16 drivers directly from Windows. It has to be done from their DOS-based installers which:
- Will refuse to run if it detects Win9x (including MS-DOS 7.10), and the detection is too complicated to bypass, that I only managed to get it work by booting to PC-DOS 7.10 or EDR-DOS with the help of lDebug's boot mode.
- It would create quite a mess in CONFIG.SYS and AUTOEXEC.BAT especially if you use multiple startup configurations. IIRC it would turn all characters in CONFIG.SYS/AUTOEXEC.BAT into uppercase letters.
Reply 1834 of 1834, by myne
Try the iso in my sig in a vm.
Then just copy it over and see if it works.
It'll do the config for you but you might have to tweak it a bit.
I built:
