First post, by david6477
Hello All,
I'm having trouble with sound in my Quest for Glory Anthology games. So far, this problem happens in all of the games.
They start out fine. After about 5-10 minutes of play(it is different everytime, and it doesn't matter what I am doing in the game, or where), the sound deteriorates to high pitches of the sounds and music. Sometimes, it's just loud static. It's quite painful with headphones on. Quitting the game doesn't solve the problem either. Dosbox has to be shut down and restarted before the sound will work correctly again. Does anyone have any ideas as to what I can try?
I have tried other types for sbtype, but they have the same result. I did try to set sbtype=none and mpu401=none after installing some gravis sound files, but then the games couldn't initialize sound.
Here's my current DosBox v0.72 video and audio setup:
sbtype=sb16,mpu401=intelligent - everything else is default
[midi]
config=128:0
[sdl]
fullresolution=1680x1050
windowresolution=original
output=opengl
[render]
aspect=true
scaler=normal2x
Computer information:
Motherboard: Compal IFL90 (notebook computer)
Intel Centrino Duo 2.2GHz
4GB DDR2 RAM
nVidia Corporation GeForce 8600M GT w/ 512MB
audio Intel Corporation 82801H (onboard)
OS: Linux Fedora 8
I tried searching this forum and google, but didn't find much beyond statements about how good Dosbox is with sound.
Any help is much appreciated!
David
Reply 2 of 11, by MiniMax
Rank Moderator
Moderator
I don't run Linux, so I could be totally wrong, but maybe the problem is related to the SDL install on your PC? I don't know if DOSBox on Linux comes with its own copy of SDL, or if it relies on a system-wide install. If so, where did your copy of SDL come from? Self-compiled? Packaged? Repository? Tried updating SDL?
And where did you get DOSBox from? Self-compiled or??
_________________
Reply 3 of 11, by leileilol
Try changing all those 22050s to 48000s in your dosbox config
Reply 4 of 11, by david6477
Thanks, leileilol. That change has solved the sound problem! Just for a complete post, I'll list what I changed in my config file:
[mixer]
rate=48000
[sblaster]
oplrate=48000
[gus]
gusrate=48000
[speaker]
pcrate=48000
Thank you all for the speedy help!
Even though the issue seems to be resolved, I'll answer the other questions asked, just so that anyone else who might stumble upon this later can have as much information as they can.
The games were installed within dosbox by running the dos installer on the game discs. The sound issue happens to all the English Quest for Glory games (I haven't tried any of the different language games of QfG3 or 4). I have applied patches to QfG3 and 4 from this site:
http://www.geocities.com/TimesSquare/Arcade/7 … s/Downloads.htm
I ran into an error on QfG4, so I installed the patch. I don't get the error anymore, which definitely makes me happy! After the original post, I tried another game, and it had the same sound issue (the original post was done late at night, and such an obvious troubleshooting step didn't occur to me!).
I installed dosbox from the fedora repository. SDL was installed with the OS, and is kept updated by repository versions. It looks like I have the latest version (1.2.13).
Reply 5 of 11, by wd
Rank DOSBox Author
DOSBox Author
Hm maybe you have some time/fun to do some testing? I don't know much
about the linux part of the SDL audio routines, but maybe it would be possible
to detect if the default output value (mixer 22050) is "bad" (non-hardware
accelerated or something). I'll try to look a bit through the sdl sources.
Reply 6 of 11, by collector
This does not occur in the Windows build of DOSBox with the Glory games. At least I have never encountered it, nor have ever heard anyone on Windows complain about it.
@ david6477, Don't forget to apply the NewRisingSun patches.
The Sierra Help Pages -- New Sierra Game Installers -- Sierra Game Patches -- New Non-Sierra Game Installers
Reply 7 of 11, by david6477
Hey collector,
Thanks for the link. It has some patches for some other sierra games that I was going to load up after the QfG series, so I'm glad that those have a pretty good shot at working well again!
wd,
I wouldn't mind doing some testing. Do you have something specific in mind? I don't know much about SDL, either, but I'm willing to give it my best shot! I can at least see if a mixture of 22050's and 48000's works, doesn't work for now. I just changed them all to 48000 on this first attempt.
Reply 8 of 11, by wd
Rank DOSBox Author
DOSBox Author
Yes that would be nice, especially try leaving all values at their original 22050
except for the mixer rate.
Can you compile dosbox from sources?
Reply 9 of 11, by david6477
wd,
Sorry for taking so long. Yesterday was really busy at work.
I commented out all of the lines in my .dosboxrc file that had 48000, including the mixer (just to make sure I still can get the messed up sound). I got the static after 10 min. of play.
I then uncommented the mixer line to set the rate to 48000:
[mixer]
rate=48000
I didn't get the static after a half an hour of play.
I did download the source code from sourceforge, and I can easily compile it (I love automake!). I ran it with mixer rate=22050, and got the sound issue, then changed the mixer rate to 48000, and didn't run into the sound issue even after an hour of play. I did this testing of the source compiled binary just to be sure I would see the same behavior as the fedora repository version.
Does this tell you anything?
Reply 10 of 11, by wd
Rank DOSBox Author
DOSBox Author
The mixer frequency is the one that is output to the sound device.
So the emulation part is not relevant, but don't know what to conclude.
Maybe you can check if there's something odd with the returned frequency
and sample size when the sound is initialized. In mixer.cpp, at the bottom
there's a call to SDL_OpenAudio() where the else part is when it succeeds.
There you can check the actual settings, something like
	} else {
LOG_MSG("specfreq %d, obtained %d, specsamples %d, obtained %d",
spec.freq,obtained.freq,spec.samples,obtained.samples);
mixer.freq=obtained.freq;
mixer.blocksize=obtained.samples;
mixer.tick_add=(mixer.freq << MIXER_SHIFT)/1000;
TIMER_AddTickHandler(MIXER_Mix);
SDL_PauseAudio(0);
(watch the console window for the output during dosbox startup.
Reply 11 of 11, by david6477
I added the LOG_MSG line that's in your last post to mixer.cpp, and here is the output when I don't set the mixer rate:
[david@raiyuu checkFreq_build]$ src/dosbox
DOSBox version 0.72
Copyright 2002-2007 DOSBox Team, published under GNU GPL.
CONFIG:Loading primary settings from config file /home/david/.dosboxrc
specfreq 22050, obtained 22050, specsamples 2048, obtained 2048
ALSA:Client initialised [128:0]
MIDI:Opened device:alsa
Here's the output when I set mixer rate=48000:
DOSBox version 0.72
specfreq 48000, obtained 48000, specsamples 2048, obtained 2048
It looks like it is getting what it requests for.
