First post, by ludicrous_peridot
I've been at it before - using (more or less) modern controllers with DOS games (and no Win9X), but this time I had an idea for a new twist.
So, Bret Johnson's driver TSR already offers good customization options for game controllers for relatively modern MoBo-s. It only works with EMM386 however. For old games to have sound with those relatively modern MoBo-s JEMM + HDPMI combination is likely required (in conjunction with e.g. VSBHDA). But, as written just above, joystick drivers are unable to take advantage of port virtualization that JEMM and HDPMI offer, since the latter is not compatible with EMM386.
So I decided to combine the two: have my fork of VSBHDA run as usual, but specifically for port 201 forward the calls to joystick service routine from pre-loaded TSR. This way both joystick driver and sound driver can coexist, and hopefully not much development effort is required. I guess, I was inspired with how Doom was interfacing stats server.
So far as a proof of concept I decided to start with keys2joy TSR and with the approach, I am able to have (Bret Johnson's) THRUST.COM joystick tester pick up "joystick movement" from port 201 with JEMM + HDPMI + sound driver loaded, which is promissing (the TSR maps keyboard presses to joystick "inputs", effectively creating a virtual joystick).
There's little point in testing game compatibility of this toy version, as games will likely intercept keyboard input anyway resulting in unpredictable behavior (Keen and Wolf3D don't really work), but next step - trying this with Mr Johnson's USB stack is a very interesting one, so wish me luck 😀
GA-G41M-Combo G41/ICH7 - Core 2 Quad Q9550 - DDR3 1033 - Radeon RX570 - CMI-8738 - CM-300 - Saitek ST-30
Beetle/M/i815+ICH2 - Celeron 566Mhz - Opti 924 - X3MB
https://archive.org/details/peridot-26
Reply 1 of 5, by oso2k
ludicrous_peridot wrote on 2026-03-17, 22:39:
So Bret and Japheth are both active on the BttR forum. Bret is also active on the FreeDOS mailing lists. Maybe ask at one of those forums. Bret's work is pretty stable at this point. Japheth is more frequently taking patches on GitHub these days. There's a chance one or both could be interested in helping.
Reply 2 of 5, by ludicrous_peridot
A sound advice, although I somehow doubt that Bret Johnson would want to change the port virtualization code of his TSRs "after all these years", or that Baron-von-Riedesel will be keen to pull USB stack into his sound driver. So I am trying to solve this in a non-intrusive way, by effectively marrying the two, but keeping them largely stand-alone. I also think a fork is generally a better place for this type of thing, than a well established product, each of the two offerings are.
Anyway, I tested actual USBUHCIL/USBJSTIK combination with this approach using my old trusty Rumble Pad and got some very promissing results:
- Bret Johnson's own THRUST worked in port access mode
- Keen 4 picked up the joystick and allowed me to calibrate; in the menus there was a lot of drift, but ingame everything felt playable, no drift
- Wacky Wheels setup picked up the joysticks, allowed me to calibrate and successfully test
- Wacky Wheels had joystick controls operational post the setup, as well as digitized sound
Now Wacky Wheels did crash after a few minutes, with me actually pressing joystick button at the time, so some debugging is due, but overall SB emulation with VSBHDA fork in real and protected mode, can coexist with USB stack TSR, and VSBHDA can "offer port virtualization services" to the latter.
Once I try more games more systemically, and make sure they dont crash more often than they should, will be happy to post binaries for testing.
Reply 3 of 5, by ludicrous_peridot
Okaaay... so things are much better than I anticipated. I played a few games, including Wacky Wheels again, and could not reproduce crashes anymore.
In fact I am quite excited that with the combination of VSBCMI and USBJSTIK, I am getting a whole array of amusing options for the controllers I have lying around...
The attachment 5330017602631308303.jpg is no longer available
The attachment 5330017602631308302.jpg is no longer available
The attachment 5330017602631308301.jpg is no longer available
Despite the experiment note being over yet, I have published the source code and "alpha-grade" binary in the VSBCMI repo.
Also posting the limitations and usage notes here:
To run:
  • obtain and unpack USBDOS.ZIP (FreeDOS also ships the drivers; they may or may not work)
  • run USBUHCIL
  • run USBJSTIK
  • run VSBCMI as usual (see HOWTO in source distribution for details) only with adding /J argument
  • to tweak joystick mapping or a particular game, run USBJSTIK < GAME.CFG which will refresh joystick TSR settings without need to unload or reboot anything.
When /J is not given, joystick support is ignored; TSR should work as usual.
Caveats and limitation (take note of alpha in version name):
  • only WATCOM build functions at the moment, DJGPP build is likely to be broken and has not been tested
  • 16-bit variant of VSBCMI crashes with /J option activated
  • because VSBCMI looks for exact version of USBJSTIK loaded in memory, it may or may not work with the driver installed on an arbitrary PC; version available on the official site linked above was tested
  • "virtual joystick port" to expose is hardcoded to 201h
Will be doing more rounds of testing, including on more than one machine and with actual HDA audio chip, and updating this post with the results.
One problem I am seeing is axis jitter, which also seems to result in "drift" that makes the solution hard to use in some games.
I am very surprised to see jitter and drift in a "fully digital" solution, and yet it's there.
It is also observed with USBJSTIK on its own (i.e. without JEMM+VSBCMI) and the degree seems to change depending on CPU speed settings.
I have not studied USBJSTIK source code just yet and, guess will be reaching out to Bret Johnson for advice on this eventually.
UPD: after having studied USBJSTIK for some time (and banging the head on the wall for some time), I have finally made some progress, albeit in a somewhat "hacky" way. I ended up dropping original USBJSTIK port 201 routines altogether, and am providing replacement for those right in VSBCMI, which use 32-bit math and scrap PIT, resorting to TSC instead. This has allowed to fix the jitter making Gods playable and Super Street Fighter 2 works now too, with 6-button Capcom gamepad fully emulated. For me this is a moment of big joy, as I was pursuing this type of setup for quite long, even though I appreciate many will not find that useful, as only UHCI type controllers are supported by Bret Johnson's drivers. Somehow I found one (!) port connected to such controller on my motherboard, but, e.g. for an i5 laptop the I have there were none. I am yet to get a USB hub to test out multiple joysticks support (it's a shame one can't have two Capcom gamepads in DOS, so it'll probably be a boxing match).
On the new VSBCMI an "alpha to beta" update will be pushed during the weekend or early next week, but 16-bit protected mode support is not yet there, as crashes still need to be investigated.
UPD2: 16-bit PM issues have been resolved and joystick support confirmed for Tyrian 2000. Also tested Wing Commander III and observed no axes drift - something that has been getting in my way of enjoying the game in DOS for so long. Buying a new joystick now becomes simply unresistably tempting...
Reply 4 of 5, by ludicrous_peridot
Slowly and steadily moving this towards a release, with the following games tried:
- Gods
- Speedball II (incl. 2 player mode)
- Wipeout
- Aladdin
- Wacky wheels (incl. 2 player mode)
- Tyrian (requires patch for VSBHDA16 compatibility)
- Subwar 2050 (incl. with throttle)
- Wing Commander III (also with Thrustmaster patch for POV hat support)
- Super Street Fighter II The New Challengers (incl. with Capcom 6-button gamepad emulation and 2 player mode with this patch)
- Whizz (patched for USBDOS compatibility)
- Rebel Assault
- Terminal Velocity
Allegro 3 setup also works. Planning to try SSF2T and Terminal Velocity if those work ok then it's done.
On Whizz - the game is hijacking PIT interrupt handler shutting off USBDOS, and is a bit speed sensitive when it comes to using joystick on modern machines.
I have patched it to successfully resolve the issue. Unfortunately, as the game consists of more than a dozen executable files, each having a copy of basic routines, I haven't got around to test it from the beginning to the end, to see if all occurrences were fixed, nor have I prepared a proper patch.
If there is interest, I can, of course, share the patch in the future.
E: list updated
Reply 5 of 5, by ludicrous_peridot
I have got SSFIIT and it's a train wreck experience.
Firstly the game runs with 32RTM Borland DOS extender and is not compatible with HDPMI, so no sound nor joystick support with it via VSBCMI.
Secondly, I had to struggle with running it on a machine that has ISA sound card to try and play with a USB gamepad that presents itself as keyboard and mouse to BIOS, since it does not like SHSUCD emulation and that machine does not have a CD-ROM drive. After working around this I got a game that has sound but no music.
Right, the credits mention CD-Audio, but the copy I got doesn't have any audio tracks, so I didn't figure this out until I actaully successfully ran it off the CD image. On a machine with CD-ROM the game happily plays music from an arbitrary CD I insert, but of course no sound because of the PCI sound card.
So bad luck, I guess. Adding the game to the list of unsupported games. Strike Command has got a new sparring partner.
I don't have much testing ideas anymore, so going to push a new tag towards the next weekend.
UPD: it couldn't simply end this way, right? Have found a way to run Super Street Fighter II Turbo with HDPMI and sound works absolutely fine. Joystick code still doesn't, so my job here is not done yet....
