DOSBox Game Launcher (DOSBox Frontend)
Reply 2200 of 2224, by DosFreak
Its annoying that this thread is being used to announce DOSBox fork releases. Is the thought process that the dev of a DOSBox frontend isn't aware of new versions?
Make your games work offline
Reply 2201 of 2224, by Neville
DOSBox-X 2026.05.02 is out and this time they've added a new option that could be aded to DBGL:
When DOS games use the Adlib FM chip to do "digitized speech", DOSBox-X does emulate that correctly, and it also correctly emula […]
does emulate that correctly, and it also correctly emulates how low
the volume is on the sound card output. However to make it more
audible, a new option "adlib pcm boost" has been added. If set,
and the Adlib emulation detects that the guest application is
playing PCM audio through it, the audio levels of the FM output
will be amplified to make the digitized speech much more audible.
(joncampbell123)
More information and download here.
Reply 2202 of 2224, by Monotremata
DosFreak wrote on 2026-03-30, 16:18:
Apparently so, since it seems its still going on..
Reply 2203 of 2224, by Neville
If you want me to drop it, just say it so.
I feel compelled to mention it here when some compatible DOSBox fork adds new options that might (or not) be interesting for DBGL users, that's all.
I don't know if rcblanke is aware of these things or if he's just to busy with real life.
Reply 2204 of 2224, by DosFreak
If you would ask him it would be appreciated.
IMO, if it's such a chore to know what options are added to each fork then each fork should make it easier to know what was added instead of having to dig for it both for regular users and frontend developers.
Then the threads could be linked in the OP and people when they want to know why an option isn't in DBGL they can ask for why it isn't.
I'm not sure I see a point in constantly bringing up options that might need to be added to DBGL that a user may or may not ever use. You may use them all, I can't say.
My main issue is that this forum is for the original DOSBox. Fork discussion should be in their respective threads (for those that have their own thread).
This thread is for DBGL, not forks.
Reply 2205 of 2224, by dosdog
At least in my DBGL version (v0.100beta17), the most recent DOSBox-X release I can configure is 2025.02.01, so it seems there's not much point bothering with newer releases until DBGL fully supports them.
Reply 2206 of 2224, by Monotremata
dosdog wrote on 2026-05-04, 10:39:
You can manually edit your DOSBox-X conf files and add any new options you want (or turn them on using the DOSBox-X menus) and they work just fine. DBGL is just giving us an 'easy way' to turn all those on or off. DBGL just passes the parameters available to your conf file as it is. If it's not there in the GUI, you can still use it. Depending on what you use DOSBox for, most of those new options might not even matter as it is.
Reply 2207 of 2224, by dosdog
Monotremata wrote on 2026-05-05, 01:46:
I am aware of this, thanks though.
Reply 2208 of 2224, by rcblanke
Hi everybody,
First of all, apologies for the silence on my part, these last months.
Due to multiple reasons, the energy I used to get from working on DBGL has dimished somewhat. After nearly 20 years of DBGL, I need a break. And while I still very much enjoy the nostalgia of retrogaming, my interest has shifted a bit away from DOSBox, in the direction of console and arcade gaming (using MiSTerFPGA, for example).
Truth be told, I'm not sure what the future looks like for DBGL at this moment. Maybe I'll be happy coding on it in a few weeks time, maybe no more. For me personally, DBGL functions as I had originally intended it to, and so much more. I had an absolute blast developing and adding features with help from the awesome Vogons community, and learned so much in the progress. Seriously, you guys and gals are great!
FWIW In case DBGL progress stagnates, it goes without saying that any developer may feely take the existing DBGL sourcecode and create a fork. I'm very much willing to assist with any technical questions.
Regards,
Ronald
Reply 2209 of 2224, by Monotremata
I mean it's been almost 20 years man, you deserve a rest for all the work at the very least! I mean DBGL does what it was meant to do and then some, a job well done if you ask me.
I'll cross my fingers Apple doesn't do anything screwy that breaks Java and it should live for quite a long time as it is. Keeping up with all the builds of DOSBox-X, made me dig in and learn how to manually setup a configuration file, they can keep adding options and its easy enough to manage if you REALLY need the random 'updates' that get added. Honestly, DOS games have been perfectly playable this whole time anyways.
Reply 2210 of 2224, by Neville
What can I say? It pains me to see the end (for the foreseable future, at least) of the project, but I 100% understand rcblanke's decision. It's been many years, and pretty much everything we could expect from DBGL has already been implemented. The only thing left was to keep up with the new features DOSBox forks keep introducing, and it seems that's something we can do for ourselves.
All that is left is to thank rcblanke for his dedication all these years, and hope somebody picks up the project whenever new DOSBox (or forks) features require it.
There's small issue left, though. If dbgl0100beta17 is to be the final DBGL release, maybe it should be made it the last official release, so all users can benefit from its bugfixes and new features.
Reply 2211 of 2224, by IIGS_User
If he really decide to stop development (hopefully not), then he could make it Open Source & Move it to GitHub.
Klimawandel.
Reply 2212 of 2224, by rfc
@rcblanke thank you for all the free time you put into this tool, that's truly very appreciated.
I'm aware you always had the sources published with the downloads, but I gotta ask: have you ever considered putting up DBGL on github or similar code platforms for collaboration?
Edit: DAMN, 20 years! I just realized I published my first comment in this thread in 2007, didn't realize I've had been around since then already. 20 years...
Reply 2213 of 2224, by red_avatar
rcblanke wrote on 2026-05-13, 19:55:
Hi everybody, […]
Hi everybody,
Regards,
Ronald
Thank you for 20 years of supporting DBGL!
Thank you for implementing most of the suggestions I made over the years & always keeping an open mind about anything we wanted to see being added.
Retro game fanatic.
IBM PS1 386SX25 - 4MB
IBM Aptiva 486SX33 - 8MB - 2GB CF - SB16
IBM PC350 P233MMX - 64MB - 32GB SSD - AWE64 - Voodoo2
PIII600 - 320MB - 480GB SSD - SB Live! - GF4 Ti 4200
i5-2500k - 3GB - SB Audigy 2 - HD 4870
Reply 2214 of 2224, by RedTony
Hi everybody, […]
Hi everybody,
Regards,
Ronald
Respect, Ronald, DBGL is by far the best DosBox frontend out there. You have shown dedication and patience to all of us. Vielen Dank, mein Freund 😀
Please take a well-deserved rest and wish you the best of success in your new projects.
I still have the hope you come back, but if you don't do, I second the questions from some of our mates above. Would you mind if we upload it to Github?
Reply 2215 of 2224, by wesbat
Thank you Ronald. Us humble DOS gamers are forever grateful for all the work you have done in DBGL. I use DBGL often and will for a long time to come.
Reply 2216 of 2224, by wesbat
As an aside, and if you will indulge me this soap box on the floor here (steps on it) — I am in favor of putting the source on a hosted platform just facilitate future collaboration by the community.
However I am firmly against Github due to their AI scraping policies, not to mention the poor degradation in performance their source code browser has exhibited over the past couple of years.
I would recommend Codeberg, a "nonprofit, privacy-focused Git hosting service powered by Gitea and dedicated to ethical, open-source development". I've had a great experience with CB to date.
Reply 2217 of 2224, by rfc
Codeberg also works for me (I brought his first up AFAICS)!
I wonder if we should give rcblanke the honor of maybe setting up their canonical public repo where they want (and maybe even archive it) if we work off from it; but hard to say given the last statement and time available for them.
Reply 2218 of 2224, by Estel Randir
I am new to DGBL. I have an issue with mounting my games.
In Defend Reloaded I could mount my games folder (full path) that contains all my games as hard drive (I.E. \Games\Dos Games). Then I would add the full path to the game executable & the setup. Everything worked fine. But in DGBL, if I do the same thing, the game will not run. I have to mount each games folder (I.E. \Games\Dos Games\<each individual game folder>)instead of the folder with all my games. This becomes a bit tedious when trying to make profile templates. Is there a solution to this or is this just how DGBL works?
I.E:
I cannot mount \Games\Dos Games as the hard drive
I have to mount \Games\Dos Games\<each individual game folder>
Reply 2219 of 2224, by Estel Randir
This front end does not play well with dosbox staging at all. It crashes for no reason constantly. I create profiles, run the games, try to edit the profiles, I cannot even edit them half the time they lock up. Simple things like changing the title of the profile or even putting my mouse into a different "tab" makes the program go unresponsive. I have been making and remaking a dozen profiles only to have this program become unresponsive. I even tried an earlier version, still the same issues.
I tested with dosbox-x , none of these issues. I really want to use dosbox staging (it will stretch). It is better to my needs. I cannot get dosbox-x scalers to work to fit my screen (4k) because dosbox-x does not allow streatching. So either a lot of black bars or the game is larger than one monitor and gets cut off.
And why do the normal scalers (Normal 2x, Normal 3x, etc) do nothing?
