[Resolved] - Resident Evil Pc
Reply 20 of 34, by John Chaser
A thousand apologies for bumping this thread. May I know where you got this "neweur.exe" file cause, I've been looking for it high and low. Supposedly this file is to update RE1 to function on any Direct3D card. I once downloaded this file from Virgin's site which now has unfortunately disappeared. They only RE1 patch I see is the Voodoo patch. So if you don't mind, can you please host it so I can get it as well?
AvalonH wrote:
After tyring to get this working under VMWARE 5.5 running a win98 guest I found you don't need a 3d card to play resident evil!! […]
The readme says that you can launch resident evil
with the "/nocard1" or "/nocard2" parameter if you don't have a 3d card.
It didn't work with my Resident evil cd, but I downloaded
the patch and am happily playing resident evil by launching it with
"neweur.exe /nocard2"
You do need a fast cpu to run it w/ software render though but it helps the game from running to fast
Reply 21 of 34, by Great Hierophant
I tried winThrottle, latest version, and with the maximum slowdown settings, Resident Evil worked at the playable, not fast-forward speed. The game did not freeze when Barry and Jill decapitate the first zombie.
My system is an Athlon FX-55, 2.6GHz, 2GB RAM and a Geforece 7800 GTX card.
Reply 22 of 34, by AvalonH
The lost patch:
This patch was uploaded by a user called 'English-Sheep-Shagger' from Hampshire taken off the Virgin Interactive Entertainment Europe website years ago. Now the company has shut down
It's not the now useless voodoo 2 patch (repatch.exe) for resident evil 1 that has been available on other websites like patches scrolls.
It allows the game to also run without having to change their desktop resolution to 16 bit.
Reply 23 of 34, by AvalonH
Has anyone actually played the PowerVR version or 3DFX(Voodo) version of this game. Are the grahpics much improved.
I have read on the net that the PowerVR version has much better graphics.
The only version I have played is the direct 3D software choice.
Reply 24 of 34, by batracio
What do you mean by "PowerVR" and "3dfx" versions"? SGL and Glide? Because I don't think those ever existed.
Reply 25 of 34, by leileilol
There IS a special PowerVR version, "uncut" at least sold in Great Britain.
And the hype you read of "better graphics" is mostly the bilinear filtering enviness of the '90s.
Reply 26 of 34, by batracio
But is it powered by SGL, or just a PowerVR optimized D3D profile?
Reply 27 of 34, by AvalonH
I just read an old review of the game from December 1997, it says on a sidenote:
"By far the best PC version of the console hit Resident Evil is the PowerVR
optimized version, delivering higher resolution and better frame rates than
the directx and 3Dfx accelerated versions. Unfortunately we were surprised that the final shipping box listed support for Matrox, 3Dfx, and Rendition-based boards--with PowerVR support strangely absent."
"According to NEC's John Smith, NEC Electronics of Japan paid for the
original PowerVR conversion, and refused to give Virgin the rights to
distribute it without receiving financial compensation in return. Virgin
refused, and the game shipped without PowerVR support. The only way PowerVR owners will get the game is via a hardware bundle. Current PowerVR owners are completely out of luck."
So the question is what does this PowerVR version use, an optimized direct3d or SGL.
Also earlier on this thread there is a also a patch posted for the 3DFX vodoo So does the game also use Glide if set up instead of direct3d?
Reply 28 of 34, by AvalonH
I just tested the game with various old cards I have.
The PowerVR version does use PowerSGL not D3D.
The normal uncut version supports Rendition Redline and D3D
I can't get GLIDE support on any version. It;s seems if you have a voodoo card it just uses D3D even with the Voodoo patch.
The PowerVR version does look much better than the D3D version (both the software and hardware D3D versions.
Ranking the versions on graphics quality
1. PowerVR (has nice smoke effects also)
2. Rendition
3. D3Dhardware version
4. D3D software version (very poor)
Reply 29 of 34, by batracio
Could you please attach the PowerVR SGL binaries? I have both USA and UK retail releases, but neither version includes those files.
Reply 30 of 34, by leileilol
Seconding the binaries. I only have the vanilla version that does D3D and D3D Ramp Emulation (software)
AFAIK the PowerVR edition is a UK exclusive, and it's "uncut" for the colored intro.
Reply 32 of 34, by Myloch
sorry to revive this old thread but this can be useful, I'd like to notice that the best solution for the well known resident evil speed problems is to install a free utility called bandicam, and limit the framerate to 30fps. here you go, game fixed. No need to limit your cpu or other fancy workarounds (like custom dlls)
edit: resident evil is available in censored and uncensored versions. first american version, the german, the asian and the japanese one are the ones to go if you want full violence and gore.
Reply 33 of 34, by capsulej
Apologies for necroing such an old topic but im currently having this issue, and for some reason i cant send PMs. I cant seem to find a version of bandicam old enough for win9x. Is there an alternative program i could use? None of the cpu limiting apps work for me as my retro pc doesn't support ACPI.
Reply 34 of 34, by soggi
Wikipedia says the initial release of bandicam is from 2009 (-> https://en.wikipedia.org/wiki/Bandicam), so i guess there never was a Win9x version. Maybe it also works with Fraps?
If I remember correctly you need to have posted five times to make sending PMs available!
kind regards
soggi
Vintage BIOSes, firmware, drivers, tools, manuals and (3dfx) game patches -> soggi's BIOS & Firmware Page
soggi.org on Twitter - inactive at the moment
