First post, by keropi
Hiya!
I was searching eBay and I found this card:
and it only had this description: "USED LOGITECH 270120 8-BIT ISA MOUSE PORT"
do you think that this card will add a NORMAL mouseport on an old pc? Is this for the so called "logitech" mode on ctmouse for example? I got it for 5GBP so no big deal if it is totally useless 😁
edit: bah, I just saw a better pic of the "mouse-port" ... it seems it is a custom one... damn
Reply 1 of 17, by Amigaz
Nice find!
Just hope "Logitec mouse" isn't the same prehistoric standard manie like "panasonic, Sony, Mitsumi cd-rom" 😵
Reply 2 of 17, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Look at how many pins the connector has xD
1+1=10
Reply 4 of 17, by Amigaz
keropi wrote:
yeah, it sux
Now just hunt down the "special custom logitech mouse" for $99 on Ebay 😁
Reply 5 of 17, by Moogle!
I've got a similar card, which has that connector, and also just the traces for what looks like a serial port.
Reply 6 of 17, by jthieme
I've got a ATI VGA Wonder card that also had a proprietary mouse port on it, I wonder if it's similar? Unfortunately I couldn't find the mouse when I looked the last time:
Reply 7 of 17, by Moogle!
No no no! That on the VGA card is something different, though I'm not sure what. Possibly TV Out or something.
The round connector on the mouse card is called a 'bus mouse'.
EDIT: LULZ I REED GUD!
Didn't notice the "mouse Included" on the VGA box.
The Bus mouse comment still stands. :p
scroll down a bit for the info on BUS mice
Bus mouse on Ebay. Make sure you don't get one that says APPLE. Those are different.
Unless your Serial ports are both being used, I suggest a serial mouse, which are much easier to obtain.
Reply 8 of 17, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Where does that VGA card hide its 256k...
1+1=10
Reply 9 of 17, by keropi
right, we got the mice... too bad they are crap, they are the same as crap-old serial ones, so this does not make this card anything special... damn I thought it was a normal ps2 mouse port... 🤣
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 10 of 17, by prophase_j
wow a bus mouse. i had read about them once. i always thought it was a myth. just curious.. what is that trippy sli connector looking thing on the ati?
"Retro Rocket"
Athlon XP-M 2200+ // Epox 8KTA3
Radeon 9800xt // Voodoo2 SLI
Diamond MX300 // SB AWE64 Gold
Reply 11 of 17, by Anonymous Coward
Yeah, it's a bus mouse. I don't think it's a proprietary connector. The logitech, microsoft and ati mouses should all be compatible with a standard bus mouse port.
I really like the bus mouse because of its superiour resolution. I have a really nice one of my 486 systems supplied with an ATi Ultra. ATi was nice enough to keep including the bus mouse connector up until the Mach32 line. What's pretty amusing is that I also have a microsoft adapter of some kind that allows you to plug a bus mouse into a standard serial or ps/2 port.
That particular VGAWonder is one of the later model cards (VGA 1024), and actually has 512kb not 256kb. It's sitting in those four 44256 ICs at the end of the card.
Reply 12 of 17, by Moogle!
If you're referring to that 26 pin edge connector on the top of the card, than I beleive it is just a feature connector for a TV card (yes, they had those back then).
I'm interested in the fact it appeards to have two monitor plugs.
Reply 13 of 17, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
One EGA-style the other VGA (nope, no multi-monitor 😉 )
1+1=10
Reply 14 of 17, by prophase_j
ah the feature connector.. makes sense. i'm used to seeing the multi pin header. to honest though.. i have never seen a device that used the feature connector from a vid card
"Retro Rocket"
Reply 15 of 17, by jthieme
The ATI VGA Wonder card was originally 256K but I field upgraded to 512K. I also just pulled out the manual and it does say the mouse port is MS Bus mouse compatible so it's not proprietary as I thought. One of the monitor connectors is a 9pin digital connector for TTL type monitors, the other is the standard 15pin VGA analog connector. The connector on the top is called a VGA pass through connector, it doesn't really go into any detail in the manual but I believe that was for connecting to a dedicated 3D workstation card to provide the 2D capability, i.e something like this:
http://en.wikipedia.org/wiki/IrisVision
Reply 16 of 17, by Moogle!
Yeah, older VGA cards had the edge connector. My Compaq EISA 1MB card has an edge connector on it. I think the pin type started with the VLB typed cards,, but i beleive the pinout is the same.
Some old DVD decoders use the feature connector, too. I've got one, but I think it is broken.
Reply 17 of 17, by dh4rm4
Some 3D accelerators did as well. I think early PowerVR cards and even one release of the M3D (possibly OEM). The feature connector was just redirecting the overlay input stream wasn't it?
