Voodoo2 diagnostics software (Witchery)
Reply 80 of 92, by Fagear
RetroLizard wrote on 2026-04-07, 13:18:
Is this able to be used on older linux distros from the early 2000's?
I don't know. Maybe?
Witchery is provided as standalone package with purpose-build environment and Witchery binary itself.
When it'll go in public beta probably its binary will work on random Linux systems.
That's not the point of the utility though. Making it work on whatever Linux system is very low priority task.
New BIG soundcard: FMonster.
Covox Sound Master replica
Innovation SSI-2001 replica & DuoSID.
My audio/video collection.
Reply 81 of 92, by subhuman@xgtx
I have a few Obsidian 200SBi cards working. One of them is up and running as we speak, the other simply crashes when Windows' hardware detection tries to detect its PCI-to-PCI bridge. I can run some tests/upload some logs if you want.
Bear in mind I usually post to the forums using my old systems.
Reply 82 of 92, by Fagear
subhuman@xgtx wrote on 2026-04-10, 04:41:
I'd like to see what Witchery would say about the one that crashes Windows.
Reply 83 of 92, by JonPP
Artemio wrote on 2026-02-25, 01:52:
Results were: […]
Results were:
The attachment Screenshot 2026-02-24 19-38-07.png is no longer available
Full Log
The attachment 260224_18-39-49_witchery.log is no longer available
and it looks like so, colors are now correct but textures of course are wrong. Thanks!
The attachment Screenshot 2026-02-24 19-41-41.png is no longer available
The attachment Screenshot 2026-02-24 19-42-41sm.png is no longer available
Hi because your FBI is ok - and because you turned off tmu1 same artifacts and turned off the back ram - its one of 3 things - bad TMU0 ram - bad TMU0 - or loose legs on the TMU or a failed broken resistors around the TMU 0- ive had similar texture artifacts and run witchery = FBI and ram ok = i replaced the ram on TMU0 and no improvement for me after turning every thing off - so that leaves a failed TMU0 in my case . if u can solder - a ram swap for TMU0 is doable - its also ram is more available than a TMU which has to come from a donor - either way you need a microscope and skills to get them on straight and soldered properly
Reply 84 of 92, by SylvainA
what is your method to desolder and solder SOJ-40 chips ?
With hot air gun and soldering iron ?
With hot air gun, which temperature ?
Reply 85 of 92, by zuldan
@Fagear is there anything that would stop Witchery loading from FreeDOS? I formatted a USB with FreeDOS (Rufus) but when I run WITCHERY.BAT it starts to load but nothing happens.
Reply 86 of 92, by Fagear
zuldan wrote on 2026-05-04, 06:46:
Reloading from DOS into Linux is handled by LOADLIN.EXE, I don't have anything to say about its compatibility with FreeDOS.
Witchery is provided in two variants:
- to load from DOS (MS-DOS and what else LOADLIN is supporting)
- to load from Linux (as Linux binary)
If neither of variants work on FreeDOS... well, tuff luck. Witchery is Linux-based binary in its core. If there's no way to run Linux-binary from FreeDOS then FreeDOS will not be supported.
Reply 87 of 92, by Nexxen
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 88 of 92, by SylvainA
Hi!
I noticed on BuB's YouTube channel that a new tool had been released that lets you test the memory of TMUs.
https://gitea.chacha.ddns.net/chacha/V2TMUMemTester
Have you tried it yet?
Reply 90 of 92, by sndtst
I just tried this utility on my P166MMX running MS-DOS 6.22. LOADLIN starts but as the Linux kernel starts booting I keep running into a Kernel Panic saying "Unable to mount root fs on unknown-block(0,0), is there a preferred Linux distro I should try to load the Linux binary directly?
A Sound Test for as many games as I can find at SNDTST.com
Reply 92 of 92, by Fagear
SylvainA wrote on Yesterday, 20:42:
I've seen that video but I'm doing my thing with TMU mapping at the moment.
And as far as I know that tool uses 3Dfx driver to access the board, that's no good for low level problems.
