First post, by twiz11
This is an unrelated rant over laptop makers that dont make it easy to replace stuff like RAM, CMOS Battery, Laptop Battery. I despise HP, Dell, Acer for making you unscrew everything to remove the bottom plate. I destroyed an hp laptop trying to get to the clock battery because otherwise the laptop wont boot from hard drive, wont even see the hard drive due to the way the default firmware is set up. I completely gutted it rather than play HP's game of trying to get it working and I took what I could get. If you have a dremmel, please cut out a section for easy access to this stuff. Toshiba laptops RIP had the components you could replace easily accessible. Now you got to create your own case and slop in the gear. Its the same way with smartphones, non servicable parts like batteries. I think apple was the first to pioneer such stuff. Everyone else followed suit because of convenience and you paid for the enhanced ambience.
