Battle of the platforms: socket 939!
Reply 220 of 242, by nd22
As AlexZ correctly anticipated the final part of the first chapter is:
CHAPTER 1 PART 3: performance evaluation of DESKTOP single core Athlon 64 revisions for socket 939!
Athlon 64 has the highest number of revisions out of all AMD classic era (1998 - 2008) CPU's. K6 got 4; K7 got 7: Argon, Pluto and Orion, T-bird, Palomino, Thoroughbred, Thorton, Barton. I tested them all in the first battle of the platforms.
K8 got no less than 9:
1. Clawhammer - the very first Athlon 64 released for the consumers back in 2003; also used for the first 2 FX CPU's: FX-53 and FX-55;
2. Newcastle - AMD downsized the chip to make it cheaper to manufacture;
3. Winchester - trial run for the 90nm manufacturing process;
4. Venice - large scale manufacturing on 90nm;
5. Manchester - dual core with 1 of the cores disabled;
6. San diego - the base for the last 2 FX CPU's: FX-55 and FX-57; highest clocked single core Athlon 64 and the easiest to overclock;
7. Toledo - again a dual core with the defective one disabled;
8. Orleans - single core Athlon 64 for socket AM2 which are not the target of this comparative;
9. Lima - also for socket AM2; energy efficient models.
Reply 221 of 242, by nd22
AlexZ wrote on 2026-06-03, 06:38:
I didn't have any background apps.
On screenshots of PC Mark I mostly see Irfanview, Total commander, Everest, those should not influence the score much. There are many system processes normally running. It depends on what they do.
On most of the screenshots you can see afterburner running: example Doom 3; Aquamark 3 and so on. I use fraps to double check the results - fraps is set to record the framerate and after each test I compare afterburner with the fraps log.
Reply 222 of 242, by nd22
In order to test as many revisions of Athlon 64 as possible we have to find a good candidate, that is a CPU that is manufactured from the very first revision - Clawhammer - up to the last - Toledo!
That CPU is Athlon 64 3500 that is available in 6 out of the 7 revisions for socket 939. Only Toledo does not have an Athlon 64 3500.
So we have 6 different 3500 to test, starting with Clawhammer and finishing up with San diego!
Reply 223 of 242, by AlexZ
Perhaps test CPUs with the same frequency rather than the same rating. Interestingly, there is no ClawHammer 2.2Ghz 1MB L2 cache for s939. So AMD gave us 2 IMCs and took 512kB cache from us so the performance benefit was gone. 4000+ would have been very rare as 3700+ in s754. 1MB L2 cache only returned with San Diego. The main advantage was high clocked FX CPUs if you had the money for them.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 955,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
Reply 224 of 242, by nd22
While many have been bought second hand or I received them for free, I managed to score a NOS Winchester 3500:
Reply 225 of 242, by nd22
AlexZ wrote on 2026-06-04, 06:33:
All 3500 have the same 2.2 GHz and 512 Kb of L2 cache so they are identical specs wise. 3500 is the most common and present across 6 of the 7 revisions for socket 939. Perhaps you have a better idea?
Reply 226 of 242, by nd22
The 5 musketeers ready to fight ( I am sorry about the photos, I used my phone):
Left to right:
Clawhammer - Newcastle - Winchester - Venice - Manchester - San Diego(not pictured)
Reply 227 of 242, by nd22
And slightly better group photos arranged by manufacturing process:
Reply 228 of 242, by AlexZ
If all have the same 2.2Ghz and L2 cache then it's fine. I was worried AMD pulled a trick on us and labelled a lower clocked CPU as 3500+. We know how unreliable the rating is. 2.2Ghz was indeed most common and most likely candidate in retro s939 systems.
Reply 229 of 242, by nd22
Yes, I know! 3500 does not warrant its rating actually! I selected it because it is the most common model among all Athlon 64 revisions! We just found out after 2 rounds of tests that dual channel = 200 PR points when compared the same CPU to its socket 754 counterpart and 512 Kb of Level 2 cache = 200 PR points! After part 3 I will try to put up a new PR scale for Athlon 64's based on the tests that you have seen!
Reply 230 of 242, by nd22
The platform selected is another - you guessed it! - Abit board. In order to cycle through the motherboards in storage I selected KN8 SLI as the board of choice for the next tests! When we will get to Athlon 64 X2 you will get "hit"by a fatality 😀.
Also in order to investigate the suitability of single core Athlon 64 for socket 939 and socket 754 for late XP-era gaming I decided to use 4gb of RAM in order to test some games like FEAR, Quake 4, Serious Sam 2 that are known to require large amounts of memory - by the way this will also investigate the frequency, timings and command rate for various Athlon 64 revisions!
Reply 231 of 242, by nd22
The board up close and personal; please note the very good placement of the main 24 pin ATX connector; the same Winbond monitoring chip as the KN8; the Vitesse pci-express based gigabit LAN controller:
Reply 232 of 242, by nd22
The board supports SATA 300 so the SSD should get quite a speed boost! The small card onto which you see written Abit SHADOW CARD is mandatory to be used in a single card configuration otherwise the system will not post! Good luck finding one!
In order to not be limited by some ordinary memory sticks and to get the best timings and frequency possible i selected one of the best kits for socket 939:
Reply 233 of 242, by nd22
I selected arctic cooler freezer 7 pro for cooling duties, some SATA DVD RW and a geforce 7600gt to test install the system:
Reply 234 of 242, by nd22
This particular board does not have the micro GURU chip ( actually a reprogrammed winbond) so no fancy fan and voltages control in the BIOS. Also it is mandatory to connect the molex underneath the last PCI slot to the power supply!
Reply 235 of 242, by zuldan
nd22 wrote on 2026-06-04, 08:46:
That memory must be ultra rare?
Reply 236 of 242, by nd22
It is not actually that rare as you can buy it on ebay, right now in june 2026, unlike some of the Abit boards which you will see later on that are unobtanium ; it is rather expensive!
Reply 237 of 242, by nd22
Word of caution: Abit KN8 SLI features passive cooling unlike NV8 and KN8 that you have seen already. The chipset gets really hot! The board has 4 fan headers: 1 for the CPU, 1 for the rear fan, 1 for the front fan and 1 for the side fan. I strongly recommend to install a side fan to blow some air onto the nforce4 chipset! I have a 120mm one that is just perfect for cooling the nforce4!
Reply 238 of 242, by TinPlat
Wow, the level of detail in your testing is fantastic. Doing a clock-for-clock comparison between the socket 754 and socket 939 platforms, both on AGP and PCI-Express, is very comprehensive. This will be an invaluable resource for anyone looking to build or upgrade a retro system from this era.
Reply 239 of 242, by nd22
Thank you!
First hurdle already encountered: I installed first Clawhammer 3500; with 2 memory modules it runs just fine at DDR-400 with command rate 1T. However, the moment i put in all 4 modules the RAM frequency drops to DDR-333 despite selecting SPD in the BIOS! This is a serious drawback because Athlon 64 requires the memory to run in sync with the CPU in order to get the best performance! I knew this from period correct reviews and forum posts but I was thinking that using high end Corsair would bypass the problem and let me run 4 double sided modules at DDR-400.
An investigation is required and creative thinking to come up with a solution!
