First post, by Mourales
Hello everyone,
I'm having a problem with the Monkey Island 1 Talkie version. The game crashes every time a sound effect is played. I'm running it using the command:
monkey.exe s220/5/1
The music and speech work perfectly, but the game hangs whenever a sound effect is triggered. For example, opening the Scumm Bar door.
Monkey Island 2 works perfectly with the same setup.
The sound card is a Yamaha OPL3-SAx, configured as a Sound Blaster Pro, and it is integrated into a Toshiba laptop.
Does anyone have any idea what might be causing this issue? Thanks in advance.
Reply 1 of 1, by keropi
if you are using CTMOUSE for mouse driver try and use the MS driver and see if that makes any difference
