First post, by cloverskull
Topic. Basically, I'm looking at Obsidian cards in SLI or Voodoo 1 cards in SLI and am trying to determine what choice to make here. 😀 Help appreciated.
Reply 1 of 9, by meljor
Voodoo1 in sli is not possible, sli is voodoo2 only (or indeed some quantum cards).
Reply 2 of 9, by cloverskull
Anthony (guy that makes "new" voodoo cards) has two voodoo 1s running in SLI, and that's who I'm sourcing my cards from. Turns out the voodoo 1 was perfectly capable of SLI, it just wasn't enabled on the original cards.
Reply 3 of 9, by NitroX infinity
meljor wrote on 2026-06-09, 11:00:
The Voodoo Graphics absolutely supported SLI. It was just not implemented for consumer-grade cards.
Reply 4 of 9, by DarcTangent
Anthony makes very cool stuff. I would only ask why you would want the Voodoo1 SLI over the Voodoo2 SLI. Best!
Reply 5 of 9, by cloverskull
I know I know 🤣. It's for a Pentium MMX build so the Voodoo 2s would be held back pretty hard.
Reply 6 of 9, by DarcTangent
Voodoo1 SLI with two texture units each would be fun to play with on a 486 or Pentium system. There will be lots of different configurations to play with to get different games working. Some will run better than a single Voodoo2 and some will run not quite as well, I bet. Let us know your results!
Reply 7 of 9, by DrAnthony
cloverskull wrote on 2026-06-13, 05:23:
Well the triangle setup engine of the Voodoo II would benefit lower end CPUs a bit. Overall the cards would be bottlenecked, but I think your overall performance would still be higher. SLI Voodoo 1 is a novel enough party trick though and I don't think you'd be giving up THAT much performance wise.
Reply 8 of 9, by NeoG_
Why do something that's always been done when you can do something that's rarely been done, no-one is building these retro systems for convenience
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 9 of 9, by leileilol
"voodoo held back" is just a silly phil myth to gaslight others to putting in rages and virges instead based on stupid benchmark bars to "fit the spec" disregarding driver reliability/features and such. They're not "held back" if they can multitexture and blendfunc worth a damn, they were considered the bare minimum for doing just that in a world of better cards (i.e. anything after November 1998)
Debian's fucked
