Reply 20 of 24, by mr.cat
FIVE-one wrote on 2020-12-18, 16:03:
Sorry for the dumb question but kjliew test was made on a Linux running computer ?
Maybe I'm trying the wrong way as I'm tinkering with VM on a Win10 computer.
Yes the most recent tests (that use qemu-5.2.0) were made on Linux, but I think it *should* work on a Win10 host too (WHPX is a Windows thing, similar to KVM on Linux).
Unfortunately you can't apply the Linux recipe on Win10 as is, you will need some special sauce (msys2?) to compile.
Robertmo's compilation guides should provide a better basis to work on (I can't vouch for their correctness on the most recent version though).
Earlier in that thread there were even binaries for Windows available, but the guest stubs won't work for the current version - the thing is pretty finicky about the versions between guest and host, they must match.
Reply 21 of 24, by FIVE-one
Ok I better stick it to VirtualBox and VMWare so. As I don't have any Linux OS installed and last time I worked on a Linux system was more than 10 years ago. (even if I know it's like bicycle, you never forget how to use it)
Hail to the Emperor !
Reply 22 of 24, by mr.cat
FIVE-one wrote on 2020-12-20, 09:59:
Or just wait a bit, maybe robertmo or someone else does a Win10 run at some point.
Reply 23 of 24, by FIVE-one
A quick update to the case :
I finaly have USB support AND music rendering on VirtualBox, using ACH97 sound device in the virtual machine configuration for the latter.
I dropped the VMWare option, as VMWare is totaly unable to detect any USB device. Too bad cause it is way more stable and doesn't have to mess up to make MIDI plays.
Still have the inherent black screen bugs sometimes but clicking on switch update the display and make anything visible.
However I sometimes have unknown crash and returns to Windows on some missions, but seems to be a game bug. Using latest iF-22 version (V5)
Reply 24 of 24, by ChronoReaperX
iF-22 Persian Gulf V5.0 is playable via DDrawCompat V0.6.0 & below. My specs are Intel Celeron 2.1Ghz N2840 + Intel HD Graphics + 8GB DDR3 L RAM. Running natively on Windows 8.1 (and should work the same on Windows 10 & 11).
I've managed to solve the controller part by using a combination of x360ce (to hide the USB controller via the HIDGuardian function) and DS4Windows (with ViGEm + Bluetooth DS4). I am also using a specific DxWnd version & an imported profile (from the SourceForge forum discussing about iF-22) to make the game run on a single core-affinity processor with some colorkey fix. The only compatibility settings I used on the game .EXE is "run as administrator".
It still has multiple problems ranging from occasional freezes (after jet crashes/ exiting a mission), missing transparency effects & textures (becoming black boxes) when using Direct3D rendering, and the menu... which is accessible and working fine but the graphics are broken with white background at the supposedly black button/ link/ text area.
