How about a MR-BIOS ROM file repository?
Reply 540 of 549, by megatog615
Babasha wrote on 2026-06-30, 06:17:
megatog615 wrote on 2026-05-31, 03:07:
Anyone know if there's a MR BIOS rom building program like cbrom or amibcp to create a rom file with option roms? Or does MR BIOS not care and just let you concatenate files into one big binary rom?
You can concate it but in right order and size of BIOS extensions
Right, yeah. I have done this but for some reason the VGA BIOS never initializes. There are POST codes but it stops at a point. I maintained the exact layout of the original Award ROM file, putting the VGA BIOS at the beginning, then another custom ROM added by the board manufacturer, inserted a correct length of empty space(all FFs) and put the MR BIOS ROM at the end.
Reply 541 of 549, by Babasha
megatog615 wrote on 2026-06-30, 09:19:
What is your motherboard? What MR.BIOS and BIOS extensions you use?
Upload it here I will look)))
Need help? Begin with photo and model of your hardware 😉
Reply 542 of 549, by megatog615
https://theretroweb.com/motherboards/s/mis-yamashita-as-3210
Note that the BIOS ROM is for a 27C020 but most of the extra space afforded by one is wasted. The EEPROMs I'm experimenting with are 27C010 compatibles and I'm adjusting the empty space accordingly. I also erased and reflashed the original '020 with the correct spacing and had absolutely no difference so I don't think the positioning of the ROM images matters for this one.
I am using the VIA Pluto MR BIOS dump (located in VIA/VIAtest/).
Reply 543 of 549, by Babasha
megatog615 wrote on 2026-06-30, 18:21:
located in VIA/VIAtest/ - sorry where is it located? What archive or place with MR. BIOSes?
Reply 544 of 549, by megatog615
Babasha wrote on 2026-06-30, 20:32:
From the archive downloadable from here.
Reply 545 of 549, by Babasha
megatog615 wrote on 2026-06-30, 20:46:
I check this BIOS with real VIA 496 mother board (FIC VIP-IO-2) and with virtual FIC and Gigabyte boards in 86BOX - it always gives only 10 44 error on postcard and nothing more
Reply 546 of 549, by megatog615
Babasha wrote on 2026-07-01, 10:33:
Yes this is the same result for me.
Reply 547 of 549, by megatog615
Now I'm wondering why the build for VIA Pluto doesn't work. It's supposed to be for an OrangePC x86 card for Mac. Maybe it's getting stuck waiting for some signal from the software that runs on the Mac? I imagine the thing doesn't start fully until the software tells it to continue. If this is the case maybe it just needs an adjustment in the rom to ignore the wait and continue?
Reply 548 of 549, by MrCrocodile
Has there ever been any signs of Mr Bios for SiS 85C496/497? I have Zida 4DPS motherboard and thought it would be awesome to have Mr Bios installed.
