First post, by Thor110
Over the past year or so I have been slowly reverse engineering this game, building tools to fix broken assets, digging through assembly in order to fix bugs and fixing assets to enable modern widescreen resolutions to function.
Unit selection now stretches 2048x2048 rather than 640x640 meaning you can select a lot more units at once.
The project includes an almost full suite of modding tools capable of extracting the games files as well as replacing them. Very nearly and may eventually become a full blown SDK.
This includes fixing things like missing pixels in assets and making widescreen specific backgrounds as well as little things like adding the coast of Europe to the Martian war map.
All five original language releases are supported by the project and the game can now be played at 1920x1080, alt-tabbing no longer crashes the game when in fullscreen, fullscreen users can scale the game to any resolution supported by the monitor, entirely future proofed.
Custom Smackw32.dll that allows for upscaled cutscenes, no longer do you have to watch the crunchy 640x480 videos sat in the top left corner of the screen!
Dynamic scaling to any resolution, including letterboxing to ensure the aspect ratio remains correct.
Custom WINMM.dll so that music now plays from local files rather than from the disc!
Custom launcher which has the same aesthetic as the original games launcher and provides access to lots of new settings and the toolkit, as well as a higher resolution version of the image used in the original launcher sourced from the games installer.
Optional enhanced assets which can be enabled through the launcher.
Multiplayer support is now being implemented through a custom build of the executable supplied to me by someone who used to be in contact with the developers.
Fixes for crashes in the base game, such as when lights are disabled and the player uses the 'infiltration' skill which used to lead to a hard crash to desktop.
Fixes for crashes that occur when viewing the Credits from the menu or finishing the game when at resolutions above 640x480, this used to crash before the end movie even had a chance to play! But now my code intercepts the broken subroutine, prevents it from executing and replaces it with a functioning credits scroll.
Persistence added to the "In-Game Music Enabled/Disabled" and sound options through the WINMM shim, previously these settings didn't get saved to the registry by the executable and so they had to be set every time you launched the game.
Added functionality to allow or disable music playback to continue when the window loses focus or is minimised, available in the launcher.
And a lot more! But check it out for yourself and see.
https://github.com/Thor110/WoWRevived
Slowly but surely the final version of the preservation portion of the project is nearly done.
With just three things left on the main to-do list, it won't be long now!
Felt like sharing this here as I saw a few topics relating to the game! If you want to see pictures and a detailed write-up, check out the readme file on the GitHub page.
Thor110
Reply 1 of 6, by spunky_h0rn
Brilliant - so it's ready to try out? I'll give it a spin this weekend 😀
GA-M61SME-S2 + Athlon 64 x2 4400+ + 2GB DDR2-800 + ATi 3870
GA-6BXC + Pentium II 300 + 512MB PC-133 + nVidia TNT
GA-686BX + Pentium III 550 + 256MB PC-133 + nVidia TNT2 M64
Soon -> Socket A, Socket 7
Reply 2 of 6, by Thor110
Some of what I listed is the upcoming version, which isn't far off of being ready! But there are previous releases available. All in good time as I has just a few more little issues to deal with before the next release.
Reply 3 of 6, by TELVM
Somehow I missed this game back in the time, and it seems to come complete with Richard Burton's voice and Jeff Wayne's awesome music.
The War of the Worlds - Official Game Trailer - 1998
Very interesting.
"The chances of anything coming from Mars
are a million to one, he said ...
are a million to one ... but still ... THEY COME!"
Let the air flow!
Reply 4 of 6, by Rwolf
I played this game when it came out, and it was working fine for me, until I made a stupid mistake: reinforcement overload.
There is a maximum number of units you can have in one sector, and you can resupply from nearby sectors if the battle in one sector goes bad; however I miscalculated the strength of the reinforcement I sent from a couple of neighbouring sectors, and it totalled over the limit at the end location, so the game crashed at the next turn.
Unfortunately the game also did autosave without checking this reinforcement limit at the end of a turn, so the game was always crashing at the next loadup, no way to go back, and I was not into hex editing my saves back then.
Good game otherwise I think, maybe I'll dig it up to try out again later.
Reply 5 of 6, by ZellSF
Can't be bothered to install this at the moment, but I've played this game a few times and am curious about three things about this patch:
1) Does it allow for leaving the tool windows at their original 640x480 and just scaling them? I would much prefer that to sticking them in the top left and covering the screen with AI art. I've tried getting this working in the past with DDraw wrappers but it always made the game too unstable.
2) Why does the preset resolution list not include 1280x720? It's a perfect resolution for these sorts of games. First it sits nicely between resolutions the game is supposed to run at (800x600/1024x768) except wider, second it's a perfect scale factor to both 2560x1440 (21.5% of Steam's users) and 3840x2160 (5%).
3) The game has a registry setting that controls the how long the briefing/debriefing screen shows before advancing. I think it always takes 10 seconds or something, it adds up to a lot of time. Is this setting exposed in the launcher? If you're taking feature requests maybe make it so it'll advance based on key/mouse press instead of an arbitrary timeout?
TELVM wrote on 2026-07-04, 10:54:
The Human side music remixes are fantastic and perfect for a strategy game. Less fond of the Martian side remixes.
Reply 6 of 6, by ZellSF
Additional question, the GitHub page says:
"ADDITIONAL : The launcher will automatically request administrator permissions to ensure registry settings are correctly applied."
Why? There really should be no reason for a video game to request administrator permissions, especially for easily remappable registry keys. Hell if you can't figure out how to hack the game, just use a compatibility shim for it.
