First post, by TheMLGladiator
I've installed the Windows version of King's Quest 7 (patch 2.0) from the collection series under Windows 3.1. The game installs fine but hangs during the opening cutscene for chapter 1. Has anyone tried this version of the game under Win 3.x?
Reply 2 of 8, by Harry Potter
After I first read this post, I looked for and downloaded this game and others in the series. It appears to be a DOS game. When I has my first PC, it had Windows 3.1, and I remember that any DOS program that used SB sound didn't work at all, but I had a nonstandard sound card. Maybe you're having the same problem. Try it from plain DOS.
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 3 of 8, by MagefromAntares
King's Quest VII is one of those games that had multiple releases for different operating systems, there were versions for:
  • DOS
  • Windows 3.1
  • Windows 95
  • Mac OS
The DOS version is one of the more common ones, so you might have to find the release that works on Windows 3.1, with this game it is even more complicated as usual because some releases came with more than 1 version of the game on the same disk, so it is sometimes hard to decide which disk contains which versions.
There is a list on Mobygames listing various releases of this game, but even that list is non-exhaustive:
https://www.mobygames.com/game/135/roberta-wi … bride/releases/
EDIT:
If you still have the box this might help you find which release you have:
https://www.mobygames.com/game/135/roberta-wi … s-bride/covers/
"A process cannot be understood by stopping it. Understanding must move with the flow of the process, must join it and flow with it." - Dune
Reply 4 of 8, by wierd_w
The win3.1 version will work on win95 if you use the windows application compatibility toolkit to change its heap behavior. (It will crash at a few locations toward the end of the game without this fix)
Other than maybe the sound drivers being incorrect, or the video files being missing somehow, I have no idea what would cause an early game hang.
Reply 5 of 8, by TheMLGladiator
The version I am trying to run is from the King's Quest Collection Series, which comes with the latest version for DOS, Windows 3.x (16-bit) and Windows 9x (32-bit).
The main reason I'm trying to run the game under Windows 3.1 is my Windows 98 system is too fast for the game. It is technically an option with slowdown utilities, but my DOS/Win3.x system suits the game better.
Reply 6 of 8, by Harry Potter
Can you try to run it under DOS? Win3.1 is not as compatible with DOS as Win98.
Reply 7 of 8, by NeoG_
I had issues with KQ6 under win 3.1 if the display colour depth was anything other than 256 colours, might be something to check
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 8 of 8, by TheMLGladiator
Did some more testing. There seems to be an issue with running version 2.0 under Windows 3.1 using a Sound Blaster Pro 2. It's likely a driver issue with the digital sound because swapping out the SBPro2 with a SB16 without changing the driver results in the sound still playing but the game hanging in the same spot. It's only after installing the proper SB16 drivers that the game gets past the small cutscene at the beginning of chapter 1.
I also tested the original Windows 3.x-only release of the game (1.4) and it seemed to work fine on the SBPro2.
