First post, by Im from Windows
Hi there
Just downloaded "win-xp boot disk" and its a torrent file
The file is only 2KB. so I guess its raw data that needs unpacking somehow
Anyone know how to do this please?
Thanks
Reply 1 of 2, by jakethompson1
If it's a .torrent, it's just a pointer to be loaded into your BitTorrent client so that it can find the servers to download the actual file.
A Windows XP boot floppy could mean one of two things. One, you want to install XP and you don't have El Torito to boot from the CD-ROM, so you have boot floppies instead (is that even supported in XP? more of an NT 4 thing to me). Perhaps you should use WINNT.EXE instead to bootstrap the installer from DOS.
The second is, it's possible to copy ntldr and boot.ini to a floppy to have a "boot disk" for NT based Windows, but it's coupled to the machine it came from and is just a pointer to which hard drive partition from which to load the kernel and supporting files.
Reply 2 of 2, by leileilol
When it comes to XP, it's not just one single floppy. You have to have several to load, and it'd be up to a bare NT console window.
