First post, by Skazzaks
Hi everyone,
I’m working on a Windows 95 build with a Soyo SY-5VD / 5VD5 Socket 7 motherboard using the Intel 430VX chipset.
System:
Soyo SY-5VD / 5VD5
Award BIOS VD-1BA1, 11/19/98
Pentium MMX 233
Windows 95 OSR2.x
Goal: 64MB total RAM, ideally 2 × 32MB SDRAM
The issue:
I first tried 2 × 64MB Compaq PC100 SDRAM, P/N 323012-001. The board detected them as 16MB each, which I assume is a chip-density issue.
Then I tried two supposedly 32MB PC100 SDRAM DIMMs, both 16-chip modules with 8 chips per side. These also only detect as 16MB each, so the system still shows 32MB total.
The chip markings I can read:
Samsung KM48S2020CT-GH
Hyundai/Hynix HY57V168010A TC-10
From what I understand, those should be 16Mbit x8 chips, so I expected 16 chips to equal 32MB per module. But this board seems to only detect half of each stick.
Questions:
Has anyone successfully run 64MB SDRAM on a Soyo SY-5VD / Intel 430VX board?
If yes, what exact RAM part numbers worked?
Is this board known to only detect one bank/side of certain 32MB SDRAM DIMMs?
Should I give up on SDRAM and use 72-pin EDO SIMMs instead?
I’m not trying to chase 128MB anymore. I just want a stable 64MB setup for Windows 95 / DOS / early 3Dfx gaming.
Any known-working RAM part numbers would be appreciated.
Reply 1 of 4, by rmay635703
Sounds like normal behavior,
Intel vx doing Intel vx things.
If you can EDO is easier to work with.
Single 64mb VX specific SDRAM IS MASSIVE with a double decker of low density chips on both sides.
8 and 16mb sdram is guaranteed to work, 32mb needs to be double sided low density, it’s getting rarer than EDO simms.
Reply 2 of 4, by Repo Man11
There was a member of Vogons that found a SDRAM DIMM that read as the full 64 megabytes on a VX board, but it seems they're as rare as hens teeth. EDO SIMM memory is (by far) the easiest way to go with the VX chipset.
Reply 3 of 4, by rmay635703
Repo Man11 wrote on Yesterday, 23:20:
I have a massive vx specific 64mb sdram, it’s 5v gets unstable at 66mhz FSB (60 is fine) and is keyed in such a way it only fit one board I had.
Not recommended
Reply 4 of 4, by jakethompson1
Take a look at my post. Re: Can u pls help identify motherboard? Detects 64MB SDRAM as 16MB?
You may be able to take a (much more common) 256MB DIMM, add two pullup resistors on the extra address lines that the 430VX does not drive, and use it as an elusive low-density 64MB one.
