Voodoo4 M4800 + Dell Precision M4800 + coreboot/SeaBIOS
Reply 120 of 140, by sdz
@mbandalauk
For now, yes, my focus is on MXM variants. After I'm done with these, I'll likely make these cards in PCIe/PCI/AGP, just for completion's sake.
I could make a batch/batches, but what I really can't do is ship who knows how many packages.
@K4sum1
What do you mean by legacy coreboot setup? The laptop runs mainline coreboot, with patches specific for my use case. I will release everything, but it's not ready yet, and I also need to clean things up a bit.
In the meantime, is there anything specific you want to accomplish?
@Deksor
While it would be really nice, it won't be either cheap or easy doing such a thing.
Last week I finally got time to finish the cards and started testing. I'm glad I did, as compared to the first card I made (and used a lot), some of the other cards had an issue.
Sometimes, the system would just start with a black screen (failure % varied by card). System reboot would not help. Investigated a little, it wasn't the FPGA or the VSA-100. That left the video scaler IC.
Connected an oscilloscope to the scaler IC reset signal, the two power rails (1V8 and 3V3), the crystal, and the SPI bus. When it worked it looked like this:
The attachment Screenshot_20250830-182913.png is no longer available
Top line is the reset line, followed by the 1V8 rail (3V3 not in this screenshot, and part of the SPI bus), crystal, and the SPI clock line.
When it failed it looked like this:
The attachment Screenshot_20250830-182925.png is no longer available
It wasn't even attempting to start. Now, the weird thing, when it got into this state, manually pulling the reset line low and releasing it wouldn't actually reset the IC.
The little blip on the reset signal is caused by the RC on the reset line. Then, the line goes low. This is actually the scaler IC pulling its own reset line low (.....) . The reset line was also connected to the MCU, but that GPIO was set to high impedance.
Now, there is no documentation in the datasheet about power sequencing, ramp up, reset signal, etc. I tried changing how the power rails come up (order and timings) and asserting reset at various points. This only made it worse.
Lastly, I increased the capacitor on the reset line. After this, it would always attempt to load the firmware, which was nice.
What wasn't nice is that after a few power cycles, it again started showing a black screen (always). This was weird, as I was still seeing activity on the SPI bus (which did not happen before, black screen and SPI activity).
Tried another board, it worked for a few power cycles, then permanently failed as the previous one.
Removed the flash ICs and dumped them, random bytes were changed compared to the bin I flashed. The scaler has no reason to write anything in the flash IC. All settings that can be changed are saved in the I2C EEPROM.
The issue was, at power off, as the rails were falling, the RESET line would always be a little higher than the 3V3 line (because of the larger cap on the reset) and the scaler would just start doing crap as its power rails were falling and reset was still high. Tied the flash write protect line low, and now it can't do that anymore and everything works fine.
The attachment 20250901_162435.jpg is no longer available
I have to say, powering on a couple of Voodoo4 laptops at the same time sure is satisfying.
I'll upload everything soon (maybe even today).
Reply 121 of 140, by sdz
I have uploaded the files here: https://sdz-mods.com/index.php/2024/06/04/voodoo-4-m4800/
And also in this post. It contains editable PCB/schematic, pdf schematic, GERBER files, BOM, P&P files, and binaries that need to be flashed (VSA-100 VBIOS, VSA-100 EDID, PCIe-PCI bridge config, scaler firmware, scaler config, FPGA bitstream, MCU firmware).
Reply 122 of 140, by janih
sdz wrote on 2025-09-01, 16:07:
Amazing work! Its so nice to follow your progress on this cool project.
Reply 123 of 140, by sdz
@janih
Thanks! It is pretty much good to go as it is (as described in the first posts, XP only, OEM BIOS).
What's next is to get sound working under 98 with coreboot/SeaBIOS, but all that is currently on hold, and I don't know when I'll start working on it again.
Reply 124 of 140, by Spitz
sdz wrote on 2025-09-05, 13:52:
@janih
My country is still watching You! 😉 Congrats!
shorturl.at/CB6zf
Well... I miss 80/90s ... End of story
Reply 125 of 140, by onethirdxcubed
Some recent software updates that might help with this project:
CSMWrap 3.0 now supports forcing the primary display adapter for Windows 98 https://github.com/FlyGoat/CSMWrap/releases/tag/3.0.0
Sweetlow has written a NVMe driver for Windows 9x: https://github.com/LordOfMice/Tools/commits/m … ster/nvme9x.zip though note that it can only boot from a CHS partition in the first 8gb because that's all that works with the legacy int 13h emulation.
My WDM HD Audio driver is now fairly reliable with Intel chipsets and Realtek codecs as are in this laptop, but still doesn't support power management well (because I still haven't been able to get 98se working in ACPI mode on ANY laptop with HD audio). https://github.com/andrew-hoffman/WDMHDA/releases
Reply 126 of 140, by sdz
@onethirdxcubed
Thanks! I was aware of the NVMe driver and CSMWrap, those are really nice projects.
Your WDM HD Audio driver sounds perfect for the M4800 with coreboot/SeaBIOS. The project is currently on hold, but I will give it a shot when I have some free time. (Have to un-nuke the HD audio, and actually get it working on XP/Linux/whatever first, as it never produced any sound and I didn't investigate the issue).
Windows98 SE runs in ACPI mode on the coreboot/SeaBIOS Dell M4800.
Reply 127 of 140, by sdz
I made some PCI VSA-100 cards, similar to the MXM cards, in the sense that they use the FPGA as a TMDS encoder (so I can fix from the FPGA the VSA-100 bug where the image is shifted to the right by 4 pixels when using NT operating systems).
At 720x400p@70Hz, they had the exact issue as the MXM cards, worked stable for a bit, until they got a bit hot. After that, on some HDMI monitors, the image looked messed up, while with other monitors it looked OK.
I always suspected that the reason for this is that in that mode the VSA-100 outputs a lot of jitter, even more when it gets hotter. Made a simple test with the FPGA, generated an image (just some color bars) and only used from the VSA-100 the pixel clock. When the VSA was outputting the 720x400@70Hz pixel clock, even the color bars were messed up on some monitors. So indeed, VSA-100 clock jitter.
Next, I tried various fixes inside the FPGA for cleaning that jitter (clock and data were both jittery btw, so data sampling was actually OK), including sampling the video data directly with the jittery clock, feed it to a FIFO, and using both available MMCMs to clean the incoming clock (also generate the rest of the needed clocks), then, read the data from the FIFO with the clean clocks and feed it to the TMDS encoder (also fed with cleaned clocks). This helped a bit but did not fix the issue.
So, I decided to look into what the VSA-100 VBIOS was doing when this resolution was set, compared to the other that worked fine, and found the reason why this was happening.
For some video modes, it used fixed 25.175MHz and 28.322MHz clocks, while the modes that worked fine used programmable PLL clocks. I patched the BIOS to use programmable PLL clocks for all resolutions via the DVI path, and that worked. Now, all DVI resolutions worked just fine on all monitors.
During testing, I also noticed that both my card and a reference V4 card with reference BIOS had quite a bit of jitter on the VGA output when using the same affected video modes. Applied the same above fix also on the VGA path, and now that is way cleaner than the reference card with reference BIOS.
Since I was there, I decided to implement other fixes in the VBIOS, here is the changelog:
-Replaced fixed 25.175 MHz and 28.322 MHz VGA clock sources with equivalent programmable VSA-100 PLL clocks.
Applied programmable clocks to both DVI and VGA paths.
Fixed severe digital RGB video clock & data jitter in legacy modes such as 720x400@70 Hz.
Improved VGA signal quality and reduced visible noise in several modes compared to reference BIOS on reference cards.
Preserved the original resolutions, refresh rates, and CRTC timings.
-1280x1024 DVI fix
Fixed 1280x1024@60 Hz failing over DVI in DOS/VESA modes that affected reference cards with reference BIOS.
Prevented the BIOS from incorrectly modifying valid standard timings when 1280x1024 is absent from the EDID detailed-timing list.
Covered VESA modes:107h: 1280x1024x8
11Ah: 1280x1024x16
11Bh: 1280x1024x24
-Dual-output fix
Changed POST monitor detection so DVI is still probed when VGA is already detected. On reference cards with reference BIOS, if both DVI and VGA were connected at power on, only VGA would initialize.
When both cables are connected at power-on, VGA and DVI now initialize simultaneously.
Preserved the existing behavior when only one display is connected.
If there is any interest, I could provide BIOS files for various reference cards with these fixes.
Now back to the M4800. Flashed the patched BIOS, and 720x400@70Hz is working properly on the V4 laptop:
The attachment S1.jpg is no longer available
Since now, with the patched VBIOS, I could actually have VGA working at the same time as the digital video output that is driving the panel, I decided to get that working on the laptop.
This was not easy. The motherboard has a VGA mux IC, that is controlled by the EC, by commands sent over the LPC bus. I should have probably hooked up a logic analyzer to a system with the OEM BIOS, log the LPC bus traffic with and without the dGPU installed, and see what is difference. Being lazy, I went the brute force with reverse engineering the OEM BIOS approach. After 2 days of work:
The attachment S2.jpg is no longer available
Now we have coreboot, V4 as the primary (and only card) with both digital video output and VGA working!
Also re-enabled HDA, and pulled an upstream commit that sent the unmute command to the EC, and now sound is working and audible (XP and above).
Next thing on the list was getting Intel SpeedStep actually working under XP. Coreboot's ACPI implementation regarding this was a bit too new for XP to understand. Downgraded that and now the CPU cores sit at a nice 800MHz under XP when the system is idle (instead of sitting at a fixed 3.x GHz and only clocking lower if it got too hot):
The attachment S3.jpg is no longer available
Reply 128 of 140, by osckhar
Hello Daniel,
Very interesting work- it isamazing.
Yes, I would be very interested in obtaining those BIOS files, if you are willing to share them.
Best regards,
Oscar.
I am not a wizard but I do 3Dfx cards reach anew HW Level. Repair & Mods & Collecting. Working in my own 3Dfx Museum Online based on Lab cards since 2001. www.3Dfx.es - Tweeter oscar_barea I cant sen PM, contact me osckhar@hotmail.com
Reply 129 of 140, by sdz
@osckhar Thanks! Will do.
Some more updates:
-fixed the SeaBIOS bug/quirk where the caps lock LED (probably the other LEDs were affected as well, but I don't have the palmrest connected at the moment) would not work under DOS/W98. Now, it works under all tested operating systems.
-during disk benchmarks under XP, I noticed that the system is a bit stuttery, even if the benchmarks have really good results (>400MB/s). After that, also noticed that when the system is idle, one CPU core has a 50% load, with "System Idle Process" eating all of that. From previous experience, this can mean IRQ issues. Checked with perfmon, and sure enough, there is an IRQ request storm, about 179000 IRQs/seconds. This doesn't happen under Linux, only noticed it under XP. 98 seems fine, but I have yet to confirm.
For XP, as far as I know, there really isn't an easy way to see which IRQ (and which device if the IRQ is shared) is at fault. I had some suspicions that it might be due to the SATA controller when initialized in IDE native mode (have yet to confirm this). I did add back the AHCI mode, and made a compile switch so I can select between AHCI, IDE native and IDE legacy modes. However, I didn't really feel like rebuilding and reflashing the BIOS for these tests.
Coreboot/SeaBIOS don't have a regular PC BIOS setup screen, so I added one (with default values, data saved in nvram etc):
Since I was there, I also added support for identifying the MXM cards (M3800, M4800, M5800, LVDS or eDP models and hardware revision for each) as well as implemented the bidirectional communication protocol through the PCIe-PCI bridge GPIOs that is used for talking to card (that was used in the Control Panel XP application shown some posts back).
Now, from this setup screen, MXM card info can be read and writeable parameters can be configured (can also be done later in the OS).
I might make it look nicer, it's still very much a work in progress.
Reply 131 of 140, by sdz
@Deksor will do! It will take a bit of time, as I have to make them for all the variants out there.
Regarding the IRQ storm under XP, it is indeed because of the SATA controller. It only happens under XP, when the SATA controller is initialized in IDE native mode. IDE legacy and AHCI work just fine. Windows98 or Linux aren't affected by this, and work OK in IDE native mode.
I will investigate more at a later date, as I already spent the last day trying to fix this with no results (made a lot of changes, and now it is configured identically to how the OEM BIOS does it).
Still, not a huge issue, DOS/98 work in IDE native mode, XP and above can use AHCI with no issues. In both cases, the drive does >400MB/s.
Last night I tried onethirdxcubed's WDMHDA driver under W98 (installed in ACPI mode) and it works perfectly! Only issue I had was that when playing sound, moving the mouse would cause the sound to start looping the last 2 seconds or so, and the mouse to stop working. Rest of the system was responsive though. I had HDA and USB on the same IRQ, and after moving the HDA to a non-shared IRQ, it works without issues! Played a bit of Quake2 and it was a really smooth experience.
Edit: coreboot/SeaBIOS repo here: https://github.com/sdz-mods/coreboot_m4800_3dfx
Reply 132 of 140, by sdz
Reworked the BIOS setup screen:
The attachment S4.jpg is no longer available
The attachment S5.jpg is no longer available
The attachment S6.jpg is no longer available
Reply 133 of 140, by sdz
The attachment S7.jpg is no longer available
Re-wrote the control application, it was XP (and above) only before and required .NET Framework. That's no longer needed. Also, the core/memory clocks can now be changed live. Before it was done via registry, and applied by the 3dfx driver (with the card initialized as a secondary adapter, the OC settings would not stick).
The attachment S9.jpg is no longer available
Now with 98 support:
The attachment S8.jpg is no longer available
And for completeness:
The attachment S10.jpg is no longer available
On a different topic:
The attachment S11.jpg is no longer available
Modern Linux with patched xf86-video-tdfx (PLL-related fix and added EXA 2D acceleration (XAA was dropped more than a decade ago)).
It is very usable even at 1080p.
Reply 135 of 140, by sdz
@Tiido thanks!
Tried SBEMU and VSBHDA, couldn't get any of them working. VSBHDA would hang, while SBEMU would do :
This doesn't look right:
Made some fixes* and:
*happy Doom noises*
*Windows98 no longer boots, docking station PS2 Mouse no longer works under Linux. Haven't tested XP yet.
Reply 136 of 140, by sdz
Last 2 weeks were an IRQ/SATA controller/MISC nightmare. I won't go into much detail about the whole process.
I always suspected there were some major issues with IRQs in general (couldn't get external sound cards working, some internal devices worked OK only one some IRQs and everything crashed and burned if they were relocated, and a new one, Windows XP setup would hang at 81% indefinitely (during secondary IDE controller bring-up), but pressing the power button would make the CD spin again and advance to 82%).
It was a long process, *numerous* crashes, boot loops, BSODs, freezes, hangs, fixing something for 98 that then breaks XP, fixing something for XP that then breaks 98 and so on, now the following things work:
-*major* IRQ overhaul, IRQ routing, focused on legacy and modern OS compatibility, fixed coreboot lynxpoint ELCR bug where every firmware (after a point) or OS register write would land in the PCH GPIO window.
-enabled secondary IDE controller for the mSATA drive. It wasn't an issue of port mapping. I replicated the mechanism used by the OEM firmware. When the SATA controller is initialized in AHCI mode, it presents itself as a single PCI device, SATA controller with 6 ports. When configure in IDE (native) mode, it presents itself as two PCI devices, one IDE controller with 4 ports and a second IDE controller with 2 ports.
Replicated that and fixed all the issues that this caused, namely: 1. XP would BSOD at the first stage (fixed I/O BARs as per OEM firmware), 2 XP would hang during copying files (IRQ related, see above), 3. 98 would crash at boot (also IRQ related, the OEM firmware assigns the same IRQ for both IDE controllers, 98 does not like that, assigned different IRQs).
-added mechanism for disabling the second IDE controller from the BIOS setup when the SATA controller is configured in IDE native mode.
-fixed SATA controller bug where when configured in IDE native mode, under XP, it would cause an IRQ storm, system went from 179000 interrupts per second to about 600.
-many ACPI fixes/changes related to SATA (AHCI/IDE). Firmware now generates different SATA SSDT depending on the selected mode.
-fixed battery reporting in Windows 98 via ACPI. Then fixed it again as it cause XP to no longer boot.
-fixed bug where an OS writing the CMOS century byte would corrupt the CMOS checksum
-minor fixes related to how motherboard resources are presented to the OS, specifically to make Windows98 happier.
-sound now works in DOS *AND* Windows98
-Windows XP SP3 vanilla installs without BSOD, no longer needs newer ACPI.sys.
Another issue under Windows98. Running DOS application would work fine, however, when quitting it, it would:
Starting another DOS box would give the same error after that. Shutting down or rebooting the system would result in a system hang with a very weird VGA output (offset, weird colors etc.).
Loading JEMMEX under DOS (FREEDOS) would say this:
Right there is where the 3dfx VBIOS is shadowed. Now, there may be legitimate reasons to execute something from there (really have no clue how DOS boxes work under 98), but it seems to "execute" junk. First, I tested with an OEM card and OEM VBIOS, just to rule that out. Of course my MXM to PCIe adapter no longer works, so here's another cursed setup : expresscard -> M.2 adapter -> M.2 to PCIe adapter -> PCIe to PCI bridge -> OEM V4.
Same exact error.
The VBIOS isn't loaded/executed by coreboot (it can do that, tested it with Nvidia cards, but it errors out with the 3dfx one), so it is shadowed to RAM and executed by SeaBIOS. Coreboot was setting C0000-DFFFF as writeable/cacheable. It can't be fixed from there, as otherwise SeaBIOS wouldn't be able to copy the ROM there. Fixed from SeaBIOS, after shadowing and running the 3dfx VBIOS, that range is marked as uncacheable and the write enable bits are cleared, while preserving only read access.
This fixed the issue under 98 when exiting DOS applications. Also, JEMMEX no longer complains about that range.
Also, with this VOPL3 - Virtual OPL3 FM + MPU-401 bridge for Windows 98/ME (based on Nuked-OPL3) and WDMHDA this laptop has SB and OPL3 emulation working under Windows98.
Windows98 now runs great (Excellent I might say) on this system, same as XP and Linux. Here is a table of what currently works:
| Hardware / function | Win98 | WinXP | Linux |
| USB 2.0 | Confirmed | Confirmed | Confirmed |
| USB 3.0 | X | Confirmed | Confirmed |
| SATA HDD/SSD in AHCI mode | X | Confirmed | Confirmed |
| SATA HDD/SSD in IDE native mode | Confirmed | Confirmed | Confirmed |
| SATA HDD/SSD in IDE legacy mode | Confirmed | Confirmed | Confirmed |
| SATA ODD | Confirmed | Confirmed | Confirmed |
| mSATA | Confirmed[1] | Confirmed[1] | Confirmed[1] |
| HDA audio | Confirmed | Confirmed | Confirmed |
| Ethernet | X | Confirmed | Confirmed |
| Wi-Fi and Bluetooth | X | Confirmed | Confirmed |
| SD card reader | X | Confirmed | Confirmed |
| ExpressCard slot | Confirmed | Confirmed | Confirmed |
| Internal keyboard and touchpad | Confirmed | Confirmed | Confirmed |
| Keyboard lock LEDs | Confirmed | Confirmed | Confirmed |
| RTC date and time | Confirmed | Confirmed | Confirmed |
| ACPI | Confirmed | Confirmed | Confirmed |
| AC adapter and battery state | Confirmed | Confirmed | Confirmed |
| Voodoo3 M3800 variants | Confirmed | Confirmed | Confirmed |
| Voodoo4 M4800 variants | Confirmed | Confirmed | Confirmed |
| Laptop VGA output | Confirmed | Confirmed | Confirmed |
| Laptop eSATA port | -[4] | -[4] | -[4] |
| Docking-station VGA output | Confirmed | Confirmed | Confirmed |
| Docking-station USB 2.0 | Confirmed | Confirmed | Confirmed |
| Docking-station USB 3.0 | X | Confirmed | Confirmed |
| Docking-station PS/2 mouse | Confirmed | Confirmed | Confirmed |
| Docking-station PS/2 keyboard | Confirmed | Confirmed | Confirmed |
| Docking-station Ethernet | X | Confirmed | Confirmed |
| Docking-station power button | Confirmed | Confirmed | Confirmed |
| Docking-station DVI/DP | X | X | X |
| Docking-station COM port | X | X | X |
| Docking-station parallel port | X | X | X |
| Docking-station audio jacks | - | - | - |
| Docking-station eSATA | -[4] | -[4] | -[4] |
| DisplayPort and HDMI output | X | X | X |
| Internal panel | Confirmed | Confirmed | Confirmed[3] |
| 1920x1080 internal panel | Confirmed[2] | Confirmed[2] | Confirmed[3] |
| S3 suspend/standby | X | X | X |
- = not confirmed
X = unavailable in this configuration or unsupported by that OS
Next, I would like to get the docking station serial and parallel ports working. Which won't be at all easy, as there is a SuperIO chip inside the docking station that provides those. That SuperIO is connected to the laptop via a LPC bus, but not to the main LPC bus. No, there is a secondary LPC bus, that is connected to the secondary EC chip (main LPC bus also goes there, and to the main EC)! There are also some docking related GPIOs that must be handled correctly. Already tried some obvious things, and poking at the OEM firmware, with no luck. Will connect a logic analyzer to the main LPC bus and make some dumps on the OEM firmware docked/undocked.
Reply 137 of 140, by sdz
It's not that useful having a W98 laptop with no connectivity, so, by the power of ReactOS (e1000 driver, did not support the i217 but it's in the same family), the Linux kernel (ich8lan.cfor i217 PHY/PCH bring-up), the Windows 2000 DDK and debugging via the Caps Lock LED (that serial sure would have helped):
370Mbps RX, 563Mbps TX. It's possible to increase those, but at the moment everything is really stable. I'd rather poke at the driver at a later date, as those rates are pretty decent already.
As for WiFi connectivity, already working on something. Hopefully I'll have it sorted in a couple of weeks.
Reply 138 of 140, by onethirdxcubed
Windows 98 will run NDIS 2 drivers (DOS Real mode) which are available for much newer Intel chipsets than the NDIS V5 that Win98 uses for some reason. But NDIS2 drivers aren't very fast and break the power management so a lot of people would appreciate your backport from ReactOS.
The Windows 98 kernel debugger doesn't support debugging over IP but you can at least get debug prints using an old version of SysInternals DebugView: https://www.digiater.nl/openvms/decus/vmslt99 … /nt/dbgview.htm
This doesn't load until well after startup so you would need to disable your driver in Device Manager, restart, wait until everything is settled and then enable your driver again.
I'd also suggest looking for a Dell Optiplex Micro or some similar SFF desktop with the same chipset as your laptop, the enterprise desktop systems are often still available with hardware serial ports.
Reply 139 of 140, by sdz
@onethirdxcubed thanks for the suggestions!
"The Windows 98 kernel debugger doesn't support debugging over IP but you can at least get debug prints using an old version of SysInternals DebugView: https://www.digiater.nl/openvms/decus/vmslt99 … /nt/dbgview.htm" I was aware of that, but really didn't want to go that route.
Debugging wasn't that bad, I did initially bring up the driver for 82540EM (also e1000 family) in a VM, debugged over serial. After that, I only had to debug on real hardware via caps lock LED specific i217 bring-up issues.
Another off-topic update (not video related, should really split this up at some point...), but quite important for the M4800 laptop. VOPL3 now supports MPU-401 bridge. Besides OPL3 emulation it can grab 0x330-0x331 (SBEMUL can only use Microsoft GS Wavetable SW Synth) and bridge that to any regular Windows MIDI device (software synth, hardware device etc). Which this setup, SBEMUL (patched) handles only PCM audio.
Which means that now this is possible:
DOOM running on Windows98, PCM audio via SBEMUL + WDMHDA, GM routed via VOPL3 to an USB to MIDI bridge, connected to a Roland SC-55 (also tested SC-55mkII, SC-88 and a Zynthian V5).
I have never fed MIDI to any of those Roland synths, so it's pretty epic that the M4800 laptop is the first to do that.
Now I need to figure out why the laptop's audio jack output is silent (only internal speakers work at the moment), so I can feed that in one of the Roland synths, and mix it there.
