First post, by rwGast
I ordered two sil3112 boards to use with my 440bx p3 system. Im having a hard time getting a hold of non sata CD drives and I want to use an SSD, so I figured this would be the best bet. Of course I got the cards that you can not flash from the command line, but that is not an issue I have a TL866 programmer, I have already removed the chips and tested them in the programmer, The issue is I do not know what file I am suppose to flash to the card to get non raid win98 compatibility. phils retro has a link to the bin file for 3114, but the 3112 section just has a zip file with tons of different bin files in it. So anyone flash a 3112 for 98 and know what file to use?
Also once I get it all sorted out and flashed, if I am using a sata cd rom through the sil3112, how do I install DOS drivers for that?
