First post, by Tempest
Through some fortuitous luck I happened into two different sets of vintage computer speakers that I intend to use with my DOS/Windows 98/ XP systems. However I really don't know much about speakers so I'd like to ask the group which ones of these would be better: Altec Lansing ACS5 or Harman Kardon HK195. Neither has a subwoofer and to my untrained ear sound about the same (although I really didn't do a thorough test). The AL speakers are very similar to the ones I had on my 486 back in the day (except that one had a subwoofer with it), so looks-wise I'm kind of partial to them. Any suggestions on which would best the best to use? I'll probably plug the set I don't use into one of my other classic computers so they won't go to waste.
--- AtariProtos.com ---
For when excellence and burnished fineries need to gently visit the warmth of your tablery
Reply 2 of 8, by NeoG_
The sound quality of these is nothing to write home about, so it would be more of a visual match. The ACS5 has an early 90s vibe and the HK195 has a late 90s vibe, so you can pair them appropriately.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 3 of 8, by Tempest
Ok if neither is anything special then I'll go with the ACS5 then. I just wanted to see if one was considerably better than the other.
Reply 4 of 8, by NeoG_
Tempest wrote on 2026-07-20, 13:03:
Given that you are the one that will be using them, what do you think sounds better out of the two?
Reply 5 of 8, by Tempest
NeoG_ wrote on 2026-07-20, 13:11:
They sound the same to me, but I'm not really an audiophile. I just want something with a good range that doesn't sound tinny or is going to crackle on me. Sounds like either of these will do.
Reply 6 of 8, by theelf
and the pictures?
Reply 7 of 8, by Tempest
theelf wrote on 2026-07-20, 13:36:
and the pictures?
Best I can do right now. You can see the HK speakers hooked up right now and the AL speakers in front (not hooked up).
The attachment IMG_8061.jpeg is no longer available
Reply 8 of 8, by theelf
Tempest wrote on 2026-07-21, 00:40:
and the pictures?
for the IBM even is a new model, IBM PS/1 Help to identify speakers
