First post, by MaRCer
Radeon x700 pro AGP under XP works fine with driver 7.3. Under 98 and ME 4.11, 5.2,5.9 drivers are installed and after rebooting for a couple of seconds even show the desktop in 16 bits, but after that the screen flashes and a black screen. Official support for AGP version X700 is only in the 6.2 driver, it is installed, but shows in 16 colors and does not allow you to change neither resolution nor color depth. I was able to install the 5.9 driver without the control center once, and it worked, but after I completely reinstalled Windows, the trick no longer worked.
